Delete One-Touch phone number?
Discussion in 'Gen 2 Prius Main Forum' started by PeeDeePrius, Jul 15, 2005.
  1. PeeDeePrius
    PeeDeePrius Junior Member
    52
    Greetings, all..
    I may be as dense as a brick, but I can't seem to figger out how to delete a one-touch phone entry. Somebody hep me..
    BTW, Blast the fact that you can't xfer a phonebook from a Moto v710.
    Anybody tried a workaround with a PC. Hmmmm. I bet it knows it's not a fone....arrgh.
    TIA!
    PD
  2. RMunroe
    RMunroe New Member
    48
    I want to be on the reply list for this too.
    Does anyone know of a way to manually add names/numbers to the phone book, since the v710 won't transfer the info.
    Failing that, how do I add names/numbers to the 18 one touch phone lists?
  3. mcitron
    mcitron Junior Member
    26
    You cannot manually add numbers to the phonebook. There is just no way.
    You can add numbers to the one touch by selecting from the outgoing and incoming numbers. This will add the phone number but NOT the name. That means the button box will look blank but will still be functional when the car is moving. By tranferring from a phone or bluetooth PC and phone you get the advantage of getting the name also so when the car is moving you still know what that button does.
  4. tag
    tag Senior Member
    2,526
    Chicago
  5. Fredatgolf
    Fredatgolf New Member
    339
    Pinehurst
    Tag, you are an amazing Moderator. (IMHO, of course.)
  6. mcitron
    26
    I have also been successful with a bluetooth iPAQ and a bluetooth phone in combination, where the phone alone could not transfer.
  7. PeeDeePrius
    52
    Gang,
    Thanks for the great info, but I still don't know how to delete a 1-touch number...
    pd
  8. mark_hamrick
    mark_hamrick New Member
    103
    Littleton, Colorado
    I believe you can just rewrite over the one you want to delete...check the nav manual
  9. jrfaris
    jrfaris Member
    352
    Windward Oahu
    This is what my Nav Manual says (maybe yours does too!)
    "Delete the one touch dial -
    from the Telephone Settings Screen
    Touch the “Delete†switch of “One
    Touch Dialâ€.
    Select the desired number from the list.
    If you want to delete all the one touch dial,
    touch the “Delete All†switch.
    Touch “YES†switch.
    Touch “NO†switch and the previous screen
    appears."
    A little confusing but the pix in the manual help....
  10. PeeDeePrius
    52
    Well, Dang. Could not have been easier. Doh!! Even read the manual!! Must have missed it.
    All wasn't lost, tho. Got some other great info in the process.
    Thanks, all..
    mutter mutter mutter....dangmanual.......mutter mutter...
    :oops:
