The deluded statements about Prius brakes NOT being a safety issue
Discussion in 'Gen 3 Prius Main Forum' started by ozboy, Feb 6, 2010.
  1. ozboy
    ozboy New Member
    Australia
    What happens when the pothole you are braking over is right at an intersection? The brakes release & you drive into the path of an oncoming car -I guess you get to test the car's side & curtain airbags...
    So for those who have stated that the brakes aren't a safety issue, would you like your humble pie served with cream or ice-cream?
    2 people like this.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Wow, nobody before ozboy-genius ever considered that...thanks!
    Look, the loss of braking is momentary...most estimate 1/2 second at most. If you're approaching an intersection with a stop light you should already be slowing down a LOT right? So, we've done the math on this a few times using various speeds, stopping distances and conditions...but the bottom line is that depending upon your speed, stopping distance allowed and duration of the transition and assuming you aren't smart enough to push down harder on the brakes when you feel the transition begin that you'd travel maybe an extra 5 feet or so. I certainly hope you're a good enough driver to realize you need to leave a lot more margin of safety than that when driving.
    And, if you do mash harder on the brakes you still have emergency braking and can slow to the same target stop point you'd originally planned to without difficulty at all.
    And....Ice Cream please.
    12 people like this.
  3. ozboy
    ozboy New Member
    Australia
    So that's one.
    Next?
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I agree with Dr. Troll Slayer. Prius Rules. Guzzlers drool.
    Oh I don't want to be diabetic. So neither desserts.
  5. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    LOL
    The Prius club in this forum is the nearest one can get to being in an auto cult. The braking issue is plain and obvious to many casual readers of the posts in this forum. But, everytime someone brings up the defect, the swarm of cult leaders descends on the poor sob, downplaying the issue.
  6. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    From everything, I have heard it happens only during light braking. So if you transition to heavy braking your total stopping distance should not be increased any.
    So if your pot hole is right at the intersection then there will be no difference, you would have been t-boned anyway.
  7. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    You are assuming the transition from light to heavy is instantaneous with no driver or vehicle lag.
  8. macmaster05
    4,050
    730
    It's because we are the best and we drive the best cars that get the best mileage.
  9. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    If I had a Chrysler FSP that I loved, I would defend it against slanderous attacks from trolls, also.
    But I don't.
  10. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    If you get to an intersection fast enough to be in the middle of it because you have (less than 1/2 sec of) a braking delay (and you were already braking any way!) due to a pothole/ice/debris on the tarmac, it means you wanted to be in the middle of the intersection anyhow to test the airbags...
    PS: nevertheless the ABS thing needs to be fine-tuned/fixed. Not nice as it is right now. But after 8000km I am still alive, had no accident and didn't run over any pedestrian/bicycle crossing in front of me (yes, we do have pedestrians and bike riders at crossings in Europe, everywhere! ;) )
  11. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Most of them don't even drive - because they spend all their time on PriusChat. :)
  12. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    No worries... Under this scenario there is a very high probability that the Prius will be hit by an asteroid which will immediately stop the forward movement of the Prius and prevent impacting the on-coming vehicle.
    Keith :)
    3 people like this.
  13. bestmapman
    1,289
    242
    Actually I am not assuming instantanious transition. There will be some time delay. But the point is it is initially "light" braking, when the alleged phonomenom is encountered. When you then apply "heavy" braking will stop you much sooner than if you would have continued light braking.
  14. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    You are assuming they don't already have Macs installed in their Prius.
    I mean, did you see the Wozniak's dashboard ?
    Any unintended acceleration will result in a hazard of flying objects.
  15. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    Yes, heavy braking will stop the vehicle earlier than light braking , I see your point but it is rather moot given that most people would assume a steady braking pressure would result in the same deceleration. But TP drivers are not.
  16. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    Yeah, I have a question, all you "My Car: Other Non-Hybrid" posters, why do you care? Give it a rest, it doesn't affect you, unless we plow into you, and one of us might do that, but most of us don't hang around bridges/motes, where you are mostly found :)
  17. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    OMG do you mean they are TROLLS?
    Now i'm really delusioned.
  18. mitch672
    1,077
    198
    Randolph, MA
    Your words not mine, I only implied it. Not all of them are trolls, just the ones who start these meaningless threads.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It would be interesting if some day someone would quantify this. I know some people expressed that they felt their stopping distance was increased due to the transition. But nobody really knows yet because there has not been any official testing. But that won't stop the alarmist will it?
  20. Canyon10
    Canyon10 New Member
    17
    Vancouver WA
    Interesting! I agree. It is like there is a supreme Prius soul followed by a group of strong believers.... No tolerance for any accusation on the integrity of the soul... No.. shouldn't even discuss about it.
    If there is a question of the supreme soul, the believers would challenge your qualification, it might be that you don't learn the supreme soul well. It is too confidential and complicate to understand if you just get started to learn it. If you face a pothole or on the bumpy road, don't worry, it is the soul that wants to train your capability of emergency response and that is custom designed for you. If you don't know it well yet, just step on the brake as hard as you can each time no matter what speed you are and the supreme soul would come protect you. Remember don't question the soul, always question yourself....
