Noise Control (Sound Vibration Damping)
Discussion in 'Gen 3 Prius Audio and Electronics' started by Gwest, Jan 13, 2010.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Nice, the floor on the Gen III is a little different than the Gen II, looks a little bit flatter actually. I couldn't get rid of the stock cloth pads because they were contoured to fit the uneven floor:
    Please keep the updates coming, nice to see someone is going through the same pain/obsession I did!
    - D
  2. Gwest
    Gwest Member
    97
    Redwood City
    I decided I would cover the rear seat again. So the inside of the care has 2 layers of sound blanket[​IMG]
    You can see I stripped everything off the floor so the sound blanket didnt have to be cut @ the interior pieces this is the 2nd layer over everything[​IMG]
    There is a seem @ the drivers seat where the 2 sheets overlap
  3. Gwest
    Gwest Member
    97
    Redwood City
    Don: I guess its good to know Im not alone. Did you happen to take any sound readings Before and After when you did your install. What area's did you do and what material's did you use. Were you happy with the results.
    Someone asked about weight. Im guessing 50 to 70 Lbs of material. The stuff is not light.
  4. KarenC1994
    KarenC1994 New Member
    Tennessee
    I had a BMW and a Lexus before my Prius. Love my Prius so much but I do have to turn the radio up higher! Seems to help with noise issues!!!
  5. don_chuwish
    823
    190
    Southern Oregon
    So far you've got a LOT better floor coverage with the MLV than I do. I'm worried that you'll have trouble getting the carpet back in to be honest! But you should see some good results. A lot of the noise comes from the front wheel wells and it's difficult to get them blocked from inside the car .
    That MLV ("sound blanket" as you've been calling it) is at least 1lb/sqft, the V-MAX is .35lbs/sqft. VB-2 isn't so bad for weight and you didn't use a whole lot. But you can do the math from there based on how much you bought and what's left over.
    I used SecondSkin Damplifier and Damplifier Pro (similar to V-MAX) as well as some VB-2. Then for the MLV I used SecondSkin's Luxury Liner Pro. Paul at Cascade told me that it's the same stuff as their product actually. Cascade, SecondSkin and SDS (SoundDeadenerShowdown) seem to have the best products and customer service based on everything I've read and my contact with all of them.
    I did take readings with a RadioShack sound meter. But I think I messed it up. Reading the directions they advised using "A" weighting for measuring background noise. So that's what I did on the "before" test. Then on the "after" tests I didn't find a measurable improvement. Even after replacing my crappy OEM tires with nice quiet Michelins the sound meter didn't show any measurable change. So I'm thinking I should have used "C" weighting. But I also didn't get nearly as much coverage as you are doing with the MLV, which as Cascade's Paul explains is critical.
    I did the doors, rear cargo area and floors. The doors made a huge improvement on how good the door mounted woofers sound. It's funny, what started out as a project to reduce road noise turned into a stereo upgrade as well. Still a work in progress.
    Full photo reviews here:
    Prius Second Skin - Photobucket
    Prius Audio upgrade - Photobucket
    - D
  6. MikeDS
    MikeDS Member
    298
    Los Angeles
    Don,
    Did you notice an improvement even though you had trouble measuring it? I'm too busy and/or lazy to do the whole car like you guys are doing and I imagine it would cost a lot to have it done, but I am considering doing the doors just to limit some vibration in the door material and cut the direct sound coming through the door.
  7. don_chuwish
    823
    190
    Southern Oregon
    As usual with my DIY projects, once I had it done I'd finally learned enough about it that I wanted to start over and do it differently! But it was fun.
    The main improvement I noticed from just doing the doors was the improved sound from the speakers. Another plus is the more solid "thunk" you get when closing the door - no more tinny ring to it. Road noise seemed a little better but it could have been all in my head. Most of the worst road noise comes from the front wheel wells in my opinion.
    The claim made by Don Sambrook at SDS (Sound Deadener Showdown) is that you don't need full coverage with the vibration damping. Called Constrained Layer Dampener (CLD) these thick foil backed butyl mats can be stuck on with just 25% to 50% coverage of the larger areas of sheet metal and be very effective.
    I did 100% coverage in the door with an inferior product (eDead 80) and wish I'd done less with better. Both from a weight added and effort expended perspective. But as I'm sure Gwest will agree, once you get going it's hard to resist just covering everything!
    In hindsight I like Cascade Audio VB-2 or the thicker VB-2HD for the door inner skin like Gwest did, very tidy and effective without too much weight. The CLD mats on the outer skin are the best choice there. Recommend either V-MAX from Cascade, Damplifier Pro from Second Skin or the CLD tiles SDS sells. Don at SDS is a small one man operation and you need to email him to order, but he's a great help.
    To actually block sound effectively you have to use the MLV (Mass Loaded Vinyl) products in addition to the CLD, like Gwest is doing on the floor. Hanging MLV in a door would be very challenging and prone to disaster if it fell off and blocked the window from going up and down. People do try it though. Another approach is to cover the inner skin of sheet metal with it, or even the inside of the door trim panel. But that gets difficult to make the panel fit back on well. Again, people have done it but it's not to be taken lightly. Hope that helps!
    - D
  8. Gwest
    Gwest Member
    97
    Redwood City
    I took some readings this morning
    The numbers in bold are the numbers after the car has been treated
    LOW HIGH
    Sitting still car NOT running Low 49.0
    Low 50.4
    Sitting Still Running 60.1 63.6
    57.0 63.3
    City Driving 35Mph 49.8 84.6
    45.2 80.5
    Freeway Driving 65Mph 70.9 88.9
    62.0 85.2
    These Numbers are HIGH's and Low's. They don't clearly show how much the sound table went down. The Meter would pick up the spikes and the lows but it wont show or record the average sound table.
    Example The un treated car I remember looking at the sound meter as I was driving down the road and it was constantly in the upper 80's as far as db. Now the car is in the Mid to low 70's I now think I should have taken a smaller short sound reading.
    The material did do its job. I do agree that Prius is not made with trying to be quite on the to do list. Trying to make this car as quite as a Lexus or Benz might be a up hill battle. I wanna do a test drive in a stock V after driving my car around for a few weeks to give you a seat of the pants impression
  9. don_chuwish
    823
    190
    Southern Oregon
    Those are pretty amazing differences when you consider what the dB scale means: "... each three decibel increment affects a 50% change in sound pressure levels. Thus, a 3 dB drop reduces sound exposure by 50%, while a 6 dB drop reduces exposure by 75%. Though reducing the decibel level produced by a sound source from 80 to 77 may not seem like a major change, it would actually represent a 50% reduction in audible sound."
    So in other words, well done! Must feel positively plush compared to before.
    - D
  10. Gwest
    Gwest Member
    97
    Redwood City
    I have been doing this over a bit of time, So the diff was not night and day to me. In fact it didnt seem that it had made that big of a change.
    I was driving down 101 and I hit a section of road that you could realy hear a jump in noise. I had the DB meter running and I looked down at it and it was hovering around 82. That's where it used to hover when I first tested the car. I had become so used to how quite the car had become I sorta forgot how loud it used to be untill I looked over at the DB meter.
    I do feel there is a sound that can spike in the car and you can hear it but the DB meter dosen't pick it up. So I would say the DB meter is not the final judge of weather or not you have made your car quite. Its a combo of meter readings and seat of the pants impression's. I want to jump into a stock V and see if I notice a diff right off the bat
  11. MikeDS
    MikeDS Member
    298
    Los Angeles
    Go test drive one...not that they'd let you take it on the freeway... :)
    I'm torn...I'd love to quiet down my car, but I'm not up for tearing the whole thing apart like you're doing, Gwest. Impressive work!
  12. bottomfeeder
    bottomfeeder New Member
    Chicagoland
    I'd like to compliment the OPs on their handiwork and diligence on jobs well done.
    I think it should be emphasized that it is not necessary to cover every square of metal with damping material, let alone double cover it. The same goes for sound absorbers: It is more important to place it in critical locations that everywhere.
    Damping material is changing the resonant frequency of the part, be it a door trim panel or a metal skin, and it happens when the mass and weight distribution of the part is changed. Ideally, it would make a part completely rigid. This can be done without covering the whole piece. Think about it, the floor pans could be made much more rigid by reinforcing them with appropriate placed rails and using thicker sheet metal or just by making the the whole floor pan out of inch thick plate steel--which is analogous to 100% coverage; overkill, impractical and expensive.
    My guess is that high end vehicles do not have 100% coverage.
    Sound absorption is another matter, once sound waves are created in a space, the appropriate absorptive material can trap them if the waves come in contact with the material. Sound absorptive material could also change the resonant frequency of the substrate that it is attached to, but most often it seems that it is not heavy enough to be effective. The converse is true, too: sound deadening material could absorb sound if constructed properly. It is probably easier, though, just to use two materials.
    I think that many of the companies selling these products have an obvious conflict of interest and are also guilty of being a little thin on true audio & engineering expertise.
    The take home message is to use the materials judiciously and put the savings into better speakers and equalization. Too bad there isn't a glass upgrade for these cars. (But that would add a lot of weight).
  13. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Just running this topic around again as it seems to be relevant and pertaining to a few....
    I haven't done it yet - but am getting ready to when I do my rear speakers (kinda doin it all at once). I had the doors (front) apart - but don't remember (didn't measure) how thick I can go... I'd like to run a thick acoustic foam - anyone with an idea?
    I'm purposely sticking away form Dynamat on principle (cost for what you get). I've got these guys who seem to have a well spec'd product at a great price - but haven't pulled the trigger yet...
    Soundproofing Foams
    Soundproofing Foams
  14. andino
    andino Senior Member
    746
    551
    San Jose, CA
    I was thinking about doing this to my car once it arrived. Depending on the results from the foam that RROLFF posted, I may go that route instead since its probably much easier than laying the dynamatt style material.
  15. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Amazing job. Makes me want to do mine as well. WEll done mate. Can't believe you have the courage to strip out the entire car.
  16. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Don't want to pull your chain. You seem to know what you are talking about. However, so where are the crital locations that we should put the sound absorbers?
    Again very easy said than done. So for people who are intrested in sound proofing their car (Prius 3) where should we put the materials so we don't overkill, being impractical and expensive?
    I don't want louder music to drown the noise. I want less noise. Louder music means more noise to me. It is not a solution.
  17. Rebound
    Rebound Senior Member
    3,991
    2,638
    Portland, OR
    Think about what happens when you tap or rattle a really thin tin pan. Now imagine what happens if you glue a piece of foam in the center, then you tap it. The sound is muffled, even when you tap on the bare metal.
    I'm sure that a genius could figure out exactly
    where to apply dampening material, but it's likely that 50 or 60% coverage will go a long way. I'm dying to try this.
  18. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    Well I am no genius. And if all centre are crital areas then I am sure just say centre and why say critial areas? So the floor of the car the centre is the centre of the car where the centre colum is?
    What about the door? Just 50% of the middle? Hmm I am sure not going to listen to you even I know nothing of sound proofing. I have taken apart of really high end car doors before and they sure have sound proofing all over the door and not just in the middle.
    Very scientific Einstein.
  19. FEINT
    FEINT New Member
    22
    Japan
    Thank you very much for the informative post and progress report!
    I was wondering if you had a guide to removing the door panels and trunk panels? I just don't want to risk breaking any of the fragile plastic parts.
    Thanks in advance!
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    Great post subject:)
    Did the doors on my GMC pickup a few years ago with duramat, used a roller and really rolled it in, after a few years it separated and fell away from the metal and got tangled up in the window, had to remove it, then I had the truck oiled and looked in the doors, not a chance of reapplying now, oily residue great for retarding rust not so great for applying sound deadener...Had the Prius oiled last summer and hadn't added sound deadener to the doors yet, oops...Had done the floors and trunk area already.
    Get out the hair dryer and roller and heat it up and roll it in or it will IMHO separate and clog.
