How to get a synthetic extended performance oil filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by thbjr, Jan 6, 2010.
  1. thbjr
    thbjr Member
    326
    63
    Phoenix
    I just had a very intresting and informitive chat with Peter of Champion Labratories this evening. I was on the Mobile 1 Extended Performance oil filters site, here, a synthetic oil filter recomended for use with Mobile 1 Synthetic Oils. With all the talk and concern about if the Toyota paper filter is up to the new 10K filtering task, I thought I'd give Mobile 1 a call, since they list 800-882-0890 on the site for additional question, to see if our filter was in the pipeline. That's how I met Peter. Seems the number is to Champion Labs, who according to Peter, make oil filters for 25 companies/retailer including Mobile 1, Royal Purple, K&N and have made filters for Toyota. He was suprised to learn of the OCI change, and I of course pointed him here, to PC, for more info. I ask him if my intrest in purchasing an extended performance filter for the 2010 Prius could be noted and relayed to potential retailers and he assured me it would be. I also ask him if it would help if more potential customers called, requesting the filter for the new Prius, and the answer was certainly. He also told me that there were a few cartdrige filters already being made for German cars, so if there was enough demand to justify the initial start up cost for a new filter, then one of the companies/retailers that have Champion make filters for them would add our Prius filter to their line of filters.
    Moral to the story, if enough of us CALL the 800-882-0890 number and express our intrest in purchasing an extended life filter for our 10K OCI Prii, we can get one made!
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Did he elaborate why he was "surprised" to learn of the change?
  3. thbjr
    thbjr Member
    326
    63
    Phoenix
    My feeling is his suprise was due to the change being mid year/model. Just as we feel, why wasn't it set at 10K when the first car hit the show room floor, just like in Europe.
    That's what I hope to do also, if an extended performance filter isn't available.
  4. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    You loose from 3/4 to 1 litre (the oil in the filter and housing). It doesn't siphon out of the crankcase. Do it after the car is off for at least an hour and you will be sure most of the oil is in the oil pan, where it can't drain out of the filter mount.
    Note that the oil filter study found most filters were essentially "used up" after 800 mi. Used up meant mostly plugged such that most of the oil was flowing through the bypass. I'm sure this would depend on the engine, and I'm sure he wasn't using a Prius, so YMMV.
  5. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    That is a really good point David. So if you only change your synthetic oil every 10,000 miles, maybe one should change the oil filter every 3,000 - 5,000 miles.
    Keith
  6. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    You could also just get a TRD oil filter; they sell for around $12-$14. In fact, I just received one I ordered (see photo)! :) The TRD part number is: PTR4352090
    2 people like this.
  7. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Looks more substantial, but what can you tell us about the specs of the TRD version that make it not get clogged with particles as quickly? Is it a direct swap for the paper filter (same housing)?
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I second that... just because it is more expensive, doesn't mean it is more effective. Be great if it was though.
  9. pjksr02
    532
    227
    Connecticut
    This TRD oil filter is the TRD oil filter for 1.8-liter engines, replacing p/n 04152-37010 or 04152-YZZA6...
    I submitted my photo, and the part number, as a suggestion of a synthetic "extended performance" oil filter element, currently available.
    Next, I reject the notion that "most filters are essentially clogged by 800 miles." Where did that come from? What clogs all these filters?
    Finally, in general, synthetic filtration media are more efficient filters than non-synthetic media. Does that lead to lower wear? Potentially, but the difference is probably not going to change the useful life of your car engine, in my engineer's opinion.
    Why'd I buy the TRD filter, then? It looks cool! (Too bad it's hidden inside the filter housing [I'm being sarcastic here]). Actually, I wished a synthetic filter media for my second-oil interval, as my engine continues break-in.
    Now, if anyone would like to sponsor me for oil analyses, I'd be happy to send two oil samples for two OCs, comparing filter media types...
  10. ksstathead
    1,244
    245
    Kansas
    If they ARE clogged at 800 miles, then why even have them? I agree with you that doesn't sound right.
    Hope Toyota will comment further on this filter issue. I'd be happy to pay for the synthetic filter in order to have fewer oil change chores. Just don't know if its even needed.
  11. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Cool. Now there is an alternative to paper filters. Too bad I already bought 10 regular toyota filters from ebay recently. Now I have to use them up quick before going TRD.
  12. New_Yorker
    New_Yorker New Member
    517
    69
    I learned long ago about the reality of metal dust and particles created during the first 5000 miles that a new engine "wears in".
    The engine typically 'wears' as much within that initial 5000 miles as it will over the next 50,000 miles. For this reason changing the oil and using a better filtration media, as in synthetic media over paper, is a worthwhile investment IF you are intending to keep the vehicle for a long time. If you're dumping it at 'Lease End', the next owner can worry about how much wear you inflicted on his car. It isn't your problem. You never actually 'owned' the car. The Lease company did, and they couldn't possibly care less once they pass it along.
    I tend to either keep my cars or sell them to relatives, so either way I strive to protect the investment with better products like 100% synthetic oil, and Filters that remove finer particles, and hold them in greater quantity. Incidentally oil filters do not clog in 800 miles, they clog depending upon the contamination of the oil. New engines having more particulate or vehicles used in dusty conditions would need more frequent oil filter changes. Oil filters have also generally gotten smaller on new vehicles. My sisters Subaru Forester has a smaller filter (about a 1/2 pint capacity) than my John Deere Lawn Mower with only 2 cylinders.
    The TRD filter is simply a wise precaution for us who keep these cars and don't off load them every few years.
  13. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I just read something about this somewhere. Oh wait! I remember!
    So, pretty much what I've been saying -- But I repeat myself... :couch2:
  14. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Is Toyota going to switch to longer lasting filters now that the official interval for oil and filter change has been extended to 10,000 miles/1 year?
  15. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    This is great! A genuine Toyota synthetic media oil filer for the Prius. Awesome!
    Rumple
  16. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Isn't the official interval for the oil filter change also now 10,000 miles/1 year?
  17. pjksr02
    532
    227
    Connecticut
    Gosh, let's file suit and demand a recall to require Toyota remedy this situation. You know, in fact, when I changed my OEM paper oil filter element, I noticed it seemed to suddenly accelerate when I dropped it into the local filter recycling bin. And yes, I can duplicate this phenomenon!
  18. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Of course it is.
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I guess my question is are they switching to a different filter now that the interval is 10k miles? I had first oil change at 5k miles so would the current filter (installed before the new interval was announced) last 10k miles?
  20. New_Yorker
    517
    69
    An even Better Question is:, " If the Engine gets damaged by severe wear, or a bearing fails at some point after the warranty kraps out, who pays for it,:eek: and was changing the 4 quarts twice as often a better and less costly maintenance :rolleyes: ? ?"
    Toyota is in the business of selling new cars. Making cars that last so long may be one of those things they kinda wish:Cry: wasn't quite so true. 10K is a lotta wear, a lotta metal particulate suspended in the oil, especially if the filters the usual paper one. Oil's cheap, motors aren't.:yo:
    scona likes this.
