Master warning light + Air bag + VSC + the exclamation point lights all came on
Discussion in 'Gen 2 Prius Technical Discussion' started by doctorman, Jan 11, 2010.
  1. my1gto
    my1gto New Member
    ca
    i have the same problems with my 05 prius. Is it wise to drive it around with these warning on if so how long/far can i drive it. do i need to bring into the dealer asap?
  2. Politburo
    Politburo Active Member
    971
    208
    It is not wise to drive around with malfunction indicators lit when you don't know what malfunction they are indicating.
  3. doctorman
    doctorman Member
    210
    36
    NY 11020
    you have to find someone who can read the toyota codes for you
    either dealer or someone with techmaster and toyota software
    mine was a problem with the Airbag computer , got a new one and installed it myself and all the codes went away.
