Verify Brake ECU Recall Firmware Update
Discussion in 'Gen 3 Prius Main Forum' started by a1a1a1, Feb 9, 2010.
  1. a1a1a1
    a1a1a1 Member
    144
    So Cal
    Does anyone know if there is a way to verify the brake firmware change that is being applied in the recall? If anyone knows how to access a screen in the NAV that reports firmware values, please share.
  2. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    You would probably need a scangauge, and then know how to use it, probably no way to verify it, other than that, or also check the actual ECU, the dealer usually puts a sticker on it with the updated version/date/technician who did it. They also record it on the records of your car as well, so they know the update was done/applied.
    Mitch
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    I think I'm going to actually test it by braking over potholes after the upgrade.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I'm getting mine fixed tomorrow. I have a sure place to reproduce the problem (Phoenix - 75th Ave northbound, left turn lane onto I-10 West has a light that one has to "race" from the eastbound offramp/onramp intersection to make due to short timing, light braking into the turn and through will almost always trigger the problem). I fully intend to validate before and after.
    If I can find another location, I may attempt to video the before and after. We may even have some folks who will be able to video the actual update process, local dealer permitting.
  5. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    It won't be a scientific comparison unless a computer is behind the car applying the brake, as the applied deceleration has to be exactly the same. Moreover, given that passengers cannot detect this perceived loss of braking power that drivers do, I doubt we'll be able to see it in the video.
  6. thbjr
    thbjr Member
    326
    63
    Phoenix
    Rick, It would be real nice if you would sticky your test results tomorrow. I'm sure that all of us will be intrested in the results!
  7. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Rick,
    Do us all a favor. After the fix - if during your test drive, you find the braking issue is NOT resolved...please do not call a TV Station, AP, or Ray LaHood. I'd recommend a collect call to Toyota Japan Headquarters, Mr. Toyoda. I'm sure he'd appreciate the heads up. :eek:
  8. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I wouldn't be surprised if it isn't completely resolved, but is reverted back to Gen II characteristics.
  9. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    If we don't see a post from you tomorrow, after your brake fix, we'll have to assume that you experienced a tragic brake failure on your way home. Please let us know that you're OK, and tell us about your experience. ;)
  10. bwilson4web
    16,310
    Yes, it is called regression testing. After the fix, I'll repeat an earlier test and see if the symptom is gone.
    4 people like this.
  11. HTMLSpinnr
    5,341
    920
    251
    I have plenty of contacts in the right places who are eager to hear either way.
    Unfortunately I wasn't able to reproduce tonight. I know some of the other "Prius Experts" may have video - some have had this done already.
  12. PriusPhile
    PriusPhile New Member
    56
    Indiana
    I have two different test spots (downhill on a drive and a pothole on a secondary road) where I am going to "test" the fix after the software update. I experienced the momentary loss of braking at both locations. Since we have so much snow and icy roads right now in Indy, my car is in the garage until they can schedule the update.
  13. Bruno_S
    Bruno_S New Member
    130
    68
    Please also report any decrease in MPG. My fear is that Toyota will tame the regenerative braking system and MPG will suffer. I do not intend to upgrade the braking system firmware if this is the case.
    2 people like this.
  14. PriusPhile
    56
    Indiana
    Folks on here have assuaged my MPG concerns. Fix is more important than MPG, IMHO. Safety first.
  15. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    I got the firmware fix today, along with the first (5463 miles) oil change.
    I only drove about 30 minutes, and I have not yet noticed anything new and different.
    The dealer said they had never heard of the "Startup Acceleration/Braking" problem.
    Apparently we need to let Toyota USA know directly.
    I left a one-page written description with the dealer,
    and will try to call Toyota tomorrow.
  16. garygid
    379
    Orange County, CA
    My dealer said that there is no way for "normal" owners to verify
    that the firmware has changed - only their "CAN-Buss" machine could do that.
    Maybe our ScanGauge II people can find a way to read the Brake ECU's firmware "version" number.
  17. Russell Frost
    Russell Frost the whatdrives.us guy
    149
    114
    Escondido, California
    I look forward to seeing the data from owners once more than a handful have had the update. That's one of the great things about this forum.
  18. PriusPhile
    56
    Indiana
    Do we need a 5K oil change? I thought it was moved up to 10K...
  19. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    It is quite OT question, but it is up to you when you change the oil - you are the owner.
  20. dsohunter
    dsohunter New Member
    VA
    I think that's exactly what they did:
    "In the third-generation Prius, which went on sale in May, the car switches between systems for the antilock brakes. Because of the uneven pressure in braking during the switch at low speeds, the driver feels the brakes aren't working properly for a fraction of a second.
    The switch in braking was not in older Prius models, and the new programming does away with it, according to Toyota."
    Source: Fox News - Can't post URL yet, just search for Prius Recall
