Long trip speed issue..
Discussion in 'Gen 2 Prius Main Forum' started by kylecaulfield, Feb 10, 2010.
  1. kylecaulfield
    kylecaulfield New Member
    IL
    Hi All-
    Just wondering if anyone had this issue before. I had to drive from Chicago to salt lake city in about 20 hours a few months ago. Fun trip! My prius was fine until about hour 16 when I started to go into Wyoming. I don't know what was causing it... the non-stop 80 MPH driving or going higher altitudes but the car started to have some weird problems. It was about 4am at that point and I could not get the car to go over about 75 MPH. Even if I nailed it for 10 min. it would not budge. It was also slow to accelerate but not anything crazy and may have just been in my head. At that point I had about 65k miles on my 2006. I pulled over to see if it needed a break and when I got back on the road same thing. Also, on the way back I went through Yellowstone, amazing trip but my car would not go faster than ~15MPH up the steep hills. Granted it now had my wife and 2 year old son in the car.... I have never driving this area before so I don't know if it was normal. Any ideas?
    Thanks
    Kyle
    EDIT: I also remember on the trip out there the battery level was normal, but going up the mountains it was down to one bar. Of course I enjoyed getting a full charge as I coasted down.
  2. Patrick Wong
    18,210
    6,511
    Hi Kyle,
    I don't think this is normal. A few thoughts:
    1. Did you replace the engine air filter at the 60K mile service?
    2. If yes, you might check to see if there's anything blocking the engine air intake.
    3. If the battery was at one bar, then the powertrain won't be able to deliver much power as MG2 won't be able to provide much help to the gasoline engine.
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    This was a few months ago? What has happened since?
    It may be that your higher speed driving/climbing was pulling more power than the ICE could muster and eventually pulled the battery down to the point that the ICE was the only remaining power source. You can get the battery back up any time just by putting it in neutral, I think. That should cause the ICE to run and recharge the battery.
  4. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
  5. Patrick Wong
    18,210
    6,511
    Actually, shifting into N will prevent the traction battery from being recharged, as the MGs are electrically disconnected.
    If you desire to recharge the traction battery, one way to do that is to shift into D, hold the car stationary by depressing the brake pedal hard with your left foot, then floor the accelerator pedal with your right foot. Since the car is not moving, power from the gasoline engine will flow into MG1 which will quickly charge the traction battery.
    However this procedure is not recommended by Toyota, so use at your own risk.
  6. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    +1 on Patrick Wong's comments.
    If you had ben driving continuously at "hour 16," perhaps you weren't
    thinking really clearly at that point... driving on internal auto-pilot...
    done that on many an occasion...
    I would suspect an unfortunate, but anticipatable, conjunction of
    conditions that resulted in the car operating at the edge of it's
    performance envelope, including but not limited to:
    * relatively high altitude
    * probability of frontal or cross winds
    * High speeds
    I would guess that the little 1.5L four-banger was working really hard
    to provide the power called for by the HSD to met the "go-pedal"
    requests. HSD threw in some HV battery power to make up the
    difference... and as virtually all the ICE power was being use to move
    the car, little or none was diverted through the PSD to MG1 to
    generate power to put back into the HV battery.
    The only thing in the three variables under the driver's direct cotrol is
    the speed. Reducing speed by just 5 MPH can make a huge difference
    in the power needed. As speed increases, the retarding forces created
    by aerodynamic forces on the car grow as a square function. The real
    problem is that the power needed to overcome the those forces goes
    up as a cube function. At high speeds, small velocity increases require
    huge power increases.
    * A doubling of speed creates four (2x2) times the retarding force on
    the car.
    * That same doubling of speed requires that the ICE/HV battery
    provide eight times (2x2x2) the power.
    The Prius is a super little car. That said, it is not a LITTLE SUPER CAR,
    the normal conditions and limitations of aerodynamics, physics, mechanics,
    etc. still apply.
  7. kylecaulfield
    IL
    Wow! Such fast response! I was going to come back in a few weeks but it looks like this is the forums to be in ;-)
    1) Yes the air filters were changed. Usually the dealer scams me into doing whatever services they can talk up. ;-)
    2) I will check tonight when I get home. The trip was only for a weekend (left thursday night, got home sunday night) so I couldn't take care of it there. Since there were no dummy lights on and the car drove fine home another 1600 miles I did not think to bring it in later.
    3) This is what I was thinking when I was going up the mountain. On the way home it was very very steep switchbacks... on the way there it cut threw the mountains but still got some height.
    Since then the car has been fine, driving fine and will go fast. The car even drove fast when it was in nebraska on the way home so it had something to do with the Wyoming area.
    PS -- I still love my car and it amazes me every day almost; even with all of the drama going on with Toyota I would buy another prius (or any other toyota) in a heartbeat.
    Kyle
  8. Patrick Wong
    18,210
    6,511
    That's a great quote!
  9. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Wyoming has the same effect on me - puts me right to sleep as soon as I cross over from Colorado :D
    I have driven the Colorado mountains (7,000-8,000 ft altitude) and although the battery depleated, and the poor little ICE was roaring its little heart out, it hauled me, the wife and two grown kids at highway speeds (if it had a tongue, it would have been hanging out when we got home). the mileage was no better than a conventional FWD, and the power was worse - obviously the Prius isn't built for this, but it took it and did its best. I've never seen 15 mph up ANY hill - I've never seen less than 55, probably, even in the Colorado mountains.
  10. donalmilligan089
    239
    22
    virginia usa
    It is hard to recognize the steep climb as you were going over the continental divide, I once pulled a mobile home with a fire dome v/8 desoto and stopped and examined the tires, motor and everything else . When I got back in tha motar really lugged getting rolling again. I stopped for gas and spoke to an attendant and he knew the problem ,as every one experiences this . The land scape is so flat that you cannot see the upgrade which is quite steep
  11. fuzzy1
    10,588
    Too bad you didn't have a Scangauge set up monitor battery and inverter temperatures. Is there any chance they were getting hot and going into a protective lower-power mode?
