Factory backup camera useless in rain
Discussion in 'Gen 3 Prius Accessories and Modifications' started by web1b, Feb 17, 2010.
  1. web1b
    web1b Active Member
    817
    52
    Just a few rain drops is all it takes to distort the view to the point it is of no use.
    Seems poorly designed.
    Can it be fixed with RainX on the lens or some kind of protective hood?
  2. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    I used some RainX on mine and it has improved things considerably.
    2 people like this.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Yes!
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    look at it this way, if the back window is dirty, chances are your camera is dirty. I usually have fast food napkins in the glove box (one balled up in the door pull is more like it) which I use to wipe the dirty side view mirror, and when I get out I usually grab it and wipe the camera lens before I chuck it in the trash.
    I don't think there's a design method that can avoid dirt and water collection on the back of a 5-door car, so I won't jump on the design flaw wagon.
  5. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Are you aware of any backup cameras that work any better when they get water on the lens? The places to put it seem to be very limited.
  6. web1b
    web1b Active Member
    817
    52
    It could be protected from water drops better if they designed it with a hood over it or some other way to recess it. Of course, once it already has water on the lens it is too late. The point is that it should not be so easy to get water on the lens and any other camera with water on the lens would be the same. I have had this problem come up when it wasn't raining very hard at all.
    If RainX makes the water run off the lens without beading and making the picture too distorted to use, then that will be a workaround that will help mitigate this problem.
  7. qbee42
    3,079
    Even a hood won't help once the car starts moving. The Kammback design pulls up a lot of water and dirt onto the back of the Prius. About the only thing that would help is a self cleaning design, but then the cost starts to go up.
  8. web1b
    web1b Active Member
    817
    52
    Pulls "up" water while the car is driving forward?!
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I would hardly call it "useless" in the rain.
    First of all, the lens is rarely blurred by a big drop of water directly on the lens. And in any event, I think that for me the view with the backup camera is ALWAYS better than the view out the back window in the rain (even when the lens is covered with a big drop of water).
  10. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I think it rains as much in South Florida as in most places and I don't mean drizzle either.
    I have had only one or two occasions when a drop of water distorted the view. I can't imagine building a hood to deal with that because it invariably runs off soon. The bigger problem is road dust or water and dust combined. While it is raining it is usually easy to see since the water kind of clears the lens of dust and dirty water. I just hadn't focused on this as a real problem.
  11. web1b
    web1b Active Member
    817
    52
    It has been useless for me when it rains. It is not rare at all. Pretty much every single time it rains, I can't see anything but a very blurred and distorted image.
    I park at work outside and even just sitting in the parking lot, drops of water land on the lens and when I try to use it to back out of the space I can't see anything on the screen, so I use the back window instead. I have only found the screen usable in dry weather.
    I will buy some RainX and see if it helps.
  12. taggart
    taggart Member
    249
    Absolutely. Simple aerodynamics.
  13. web1b
    web1b Active Member
    817
    52
    I'm not seeing that happening in my case. Doesn't matter anyway since I'm having the issue on a car that's parked. No aerodynamics involved. Just gravity dripping water on the overly exposed lens.
  14. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    1. How about a micro, mini wiper blade for the lens???:D:D:D or
    2. How about rigging up a small air jet nozzle aimed at the camera lens? (This sounds more doable than the 1st option). You could have a small underhood compressor activated by a dash mounted switch to supply the required air to dry the lens.
    Just thinking out loud.
    Dbcassidy
  15. web1b
    web1b Active Member
    817
    52
    If RainX really works for this, then that will be the most simple fix to try first.
  16. qbee42
    3,079
    Yes. The kammback creates a vortex of rolling air in the space right behind the car. Water and dirt kicked up by the tires is pulled into the vortex and some of it gets deposited on the back of the car. Haven't you noticed how dirty the back of a Prius gets?
  17. qbee42
    3,079
    America's Cup racing yachts have trouble with water on camera lenses. One of the techniques use to combat this is a cylindrical clear cover which can be rotated. The camera lens shoots out of the front, while a squeegee cleans the back. When water spots appear, the cylinder is rotated by a motor, and a freshly squeegeed section moves to the front.
  18. Tideland Prius
    16,542
    I thought that'll be an issue with the lens but so far I've only had one or two incidents where the lens was so dirty that I couldn't use it. Most of the time, I can still see the back even if there is water or dirt on it. (The back of the car gets covered by snow all the time but the camera is small enough that unless ice freezes on it, it's still usable)
    No need. Just do what VW did. Hide the camera behind the rear emblem and when Reverse is selected, out pops the camera as the emblem flips upward.
  19. qbee42
    3,079
    I habitually wipe my lens each time I come back to the car. I just run a finger over it. My habit is a function of our nasty weather.
  20. Lottamoxie
    Lottamoxie Member
    435
    64
    Southeast US
    Such a simple fix for such a simple problem. If only RainX would fix life's bigger issues! Seriously, get a bottle of RainX and you should be good to go!
