Temperature Sensor Reads Too Low
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusPhotog, Jul 20, 2005.
  1. PriusPhotog
    PriusPhotog New Member
    Kansas
    All morning and afternoon my car sat in an outside garage that averaged probably 90F. I took my Prius out to run a couple of errands and the outside temperature read 86F. Since I knew it was around 103 outside I thought this would be an interesting experiment to see how long it took for the reading to correct itself. 10 minutes later and it read 88F outside. 30 minutes later and it read 90F outside. This was a combination of driving and parking in the sun. I have always noted the outside temperature to be fairly accurate, but something seems very strange. All I can think of is that I gave my car a good hand washing a couple of days ago. Can I easily see the sensor and check to see if it is coated with something, etc.? Thanks for any advice.
  2. weids
    weids New Member
    Edina, MN
    I had the same problem last week. My gauge had always been dead-on but one day (immediately following a car wash) it was off by 10 degrees or so. It seems to be better now. Where is the sensor located?
  3. bobc
    bobc New Member
    361
    Durham, NH
    If you look through the grill, you can see the sensor mounted to the vertical support in front of the radiator.
  4. popoff
    popoff New Member
    560
    western NC mountains
    So that would mean you need to be moving to get an accurate reading?
    Seems like if you were standing still and the cooling fan wasn't running, the radiator would be radiationg heat forward and raise the temp at the sensor.
  5. Jared
    Jared Member
    209
    Long Island
    Mine usually reads about 4 degrees too hot. I believe it is quite easy for the dealer to adjust.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I also noticed my temp. was off after washing it. It took quite a few days for it to get back to normal.
  7. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Mine starts off too hot by about 2-5 degrees when I start driving after leaving it in the sun, but it settles down to the correct temp in about 5 minutes.
