Winter MPG Drop!
Discussion in 'Gen 2 Prius Fuel Economy' started by Shaboom1965, Feb 21, 2010.
  1. Shaboom1965
    Shaboom1965 New Member
    Greensburg PA
    I'm new here so please forgive me if this matter has been covered in a prior thread.
    My wife loves her 2008 Prius, which she bought in the summer of '08 when we had to fight to get a brand new one. However, the next winter, her mileage fell from a typical combined 50 plus mpg to low 40's and then went back to the normal 50 plus mpg when the warm weather returned. This winter, it has done the same thing. Is this part of the Prius nature or are we doing something wrong? She drives the car reasonably and it is garage kept.
    Great car by the way. Not a single problem since delivery.
  2. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    Yes, it's true, the MPG drops with cold weather (mine goes from around 50 in summer to the low 40s in winter). But this is true of any car, since an internal combustion engine is much less efficient when cold. You just notice it with the Prius because of the handy MPG display.
    Also, batteries are less efficient (have a higher internal resistance) when cold. But I suspect that the MPG effect of a cold NiMH HV Prius battery is pretty small compared to the MPG effect of a cold ICE.
  3. thelungmd
    thelungmd New Member
    New Orleans, LA
    The air is also denser when cold, hence more drag = less MPG
  4. bc104
    bc104 Junior Member
    57
    New York
    I have insulation on the engine and the grill blocked. It does help a little. Keeping the heat off around town and turning it on when on the highway helps more. But man that's cold!
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep... an engine block heater will help too but it's not nearly as cheap as blocking the grille. As for only turning on the heat while on the highway, I turn it when I need to do harder acceleration or above 42 mph. At that point, the ICE must run anyway.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  7. fuzzy1
    10,563
    In the old days, all cars preferred the summer blend for fuel economy, because it had higher energy density. I haven't kept up with any recent changes.
    As for the higher air density on cold weather, that does more than just increase air drag. It also increases part-throttle engine pumping loss. But this has more impact on non-hybrid Otto cycle engines than the Atkinson cycle engines in most hybrids.
  8. richard schumacher
    7,664
    1,046
    United States
    Absolutely normal. It's happening to every other car on the road, but even more so for them. There's no need to worry or do anything about it unless you want a new hobby :_>
    Well, you do need to check and maintain the tire pressures at least monthly.
  9. WishingStone
    WishingStone New Member
    CT
    I notice a significant drop. During the summer I hit 69 mpg... 54 or so at the lowest.
    However in the winter I struggle keeping 46, and usually I get 45 or so when I get angry, turn off the screen, and stop paying attention. I try to avoid using heat in the car, which helps the mpg I get. Though, most people wouldn't do that. My normal destination is a horse barn where I am outside 24/7, so the cold doesn't phase me anymore.
    Its better than anything else though, so I can't complain.
  10. elcorazon
    elcorazon New Member
    74
    chicagoland
    I get 40-46 in the summer and 30-37 in winter. Sucks but it's the way it is. My Honda Odyssey only got 14 last tank. Gets 25 in the summer on the highway.
    I do think the winter difference is more dramatic in the Prius than in other cars I've owned, though.
  11. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    While's definitely worse than other cars, do remember that the drop in the Prius isn't quite as bad as it looks.
    50 to 40mpg is 0.02gpm to 0.025gpm.
    That's an extra 0.005gpm.
    33.33 to ~28.57mpg is 0.03gpm to 0035gpm.
    25 to 22.22mpg is 0.04gpm to 0.045gpm.
    Mpg is deceptive.
  12. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    You can say that again!
    Traditional cars actually see a really big efficiency drop in SUMMER, consequently appearing to have less of a drop in the WINTER.
    So, it totally how you look at it. Most just accepted that without question, since there were no other choices available in the past.
    Overall though, it's the annual average that tells the real story. Prius shines when you see that big picture view.
  13. enerjazz
    enerjazz Energy+Jazz=EnerJazz
    256
    144
    Fairview, TX
    Show me the data . . . . . and here it is:
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    I try to explain this to people all the time and it seems they just don't get it. All they see is a 10mpg drop and they freak out.
  15. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    What I really care is the $ I spend, not data behind.
  16. F8L
    19,011
    4,083
    Grass Valley, CA.
    If all you were to read is your gas receipts you would sleep easier. The rest of us mpg freaks have to use sleep aids. LOL
  17. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Grille Blocking will help improve the MPG during cold weather. The foam in the grille helps keep the ICE warmer and at the optimal operating tempature.
    Welcome to Priuschat! and hey! your in PA too! (y)
