Brakes "stuck" after spraying down GenIII
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by venom700, Feb 22, 2010.
  1. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
    Has anyone else noticed after spraying down/rinsing their car, and then letting the car sit, that their brakes are "stuck?" I've had this happen about 3 times now.
    Yesterday I was heading out of town for the day and I sprayed down my car before I left, including the wheels. When I went to leave this morning in the Prius, I put it in "drive" but my car just sat there. I first though I wasn't in drive, so I tried again, and nothing. I pressed the gas peddle some and the car just stayed still. I tried to press the peddle about 2/3 of the way down and I hear cracking/popping sounds from what sounded like both front rotors and the car finally lurched forward. Then I heard the brakes grind when they were engaged for about a mile of driving.
    Everything is normal now, but this is about the 3rd time this has happened. Is there something different that would cause this to happen versus every other car that I have owned?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, I had this happen last summer after washing and letting it sit for a bit. I now move the car and ride the brakes to clear the water off the rotors after washing.
  3. qbee42
    3,081
    Rust. This is a fairly common problem in damp climates.
  4. Patrick Wong
    18,210
    6,515
    Yes. After washing the car, I suggest taking the car for a short drive. I do this when the car is still wet, get up to ~30 mph, then shift into N and apply the brake pedal gently. This kills two birds with one stone:
    Bird 1) this dries the friction brakes
    Bird 2) some of the water blows off the Prius, leaving less for you to dry off with a chamois or towels, whatever your method is. :D
  5. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    The brake disks on many cars are made of the quickest rusting metal on earth. Mine rust in the time it takes to wash the car. That said this is all normal, and the rust is just surface rust which easily rubs off with light application of the friction brakes. Nothing to worry about.
  6. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    I have had it happen in my other non Toyota cars too.
  7. Flying White Dutchman
    4,376
    313
    yes i have this problem in the past, also with other cars.
  8. qbee42
    3,081
    The only difference, with you being Dutch, is that your Prius has wooden brakes. :p
  9. Flying White Dutchman
    4,376
    313
    yes i know
    the dutch are really environmentally good.:D
    in my case leaving the car standing for a while it wil grow roots.
    try to move with that.....
  10. venom700
    196
    35
    Bethesda, MD
    I mean I have had other cars where they rusted (my BMW was the worst per se) but not to the point that the car had to be forced to move. I mean I had to get the ICE going to make it budge. That's a bit much.
  11. Flying White Dutchman
    4,376
    313
    i think its the MG protection that keeps it from moving.
    so the ice kicks in and needs to move the car?
  12. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    You could spray some WD-40 on the rotors to keep them from rusting, after you wash your car. :peace:
    This has happened to me on all vehicles I have ever owned, but I haven't yet duplicated it on my Prius...
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My thought there is that since the brakes are used less on the Prius, they are likely hardly used at this point and still have a tight fit around the rotor causing it to rust to it. In other vehicles, likely the brakes are already so used that it is not a problem. Just a thought...
    I was surpised too. I could still see the outline of the brake pad on the rotor after I moved it!
  14. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    Happens worse on my Acura MDX; brakes stick after sitting out in the rain sometimes. After I get the car going and apply light brake pressure the surface rust is removed and everything is fine.
    We wash the Prius in a touchless spray wash when we get gas and always drive the car home and things are dry by the time we arrive so this isn't much of a problem.
  15. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I know that WD-40 is technically not a lubricant but the thought of spraying that or any lubricant on the rotors is kind of scary. Having read lots of chicken little posts on this site, I am not sure that many people who post here have either a sense of humor or maybe even sense. They may take you totally seriously.
    The rotors are supposed to stop your car. Lubrication can only hinder that, their main function. I know it will burn off quickly, but while it is on there it will make your brakes slip and become less efficient. Maybe a lot less efficient. There has to be a better way.
  16. Patrick Wong
    18,210
    6,515
    Yes, that would be an extremely bad idea.
  17. johalareewi
    johalareewi Member
    393
    44
    uk
    The rear brakes on my Mk2 Astra used to rust up overnight when it was damp.
    Usually they would free up with a loud bang when I drove off in the morning. But once or twice I had to call out the AA. Not had this on the Prius.
  18. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    This happens to my Honda CR-V. I have actually had the brakes freeze after I washed the car and left it sitting for a few days. When I pressed the accelerator harder, the brakes made a very loud noise when finally releasing and allowing the car to move. Honda dealer says this is "normal." I now drive my Honda around the block to dry the disk brakes after I wash the car. My Prius has not had this severe of a problem.
