strange things with electrics!
Discussion in 'Gen 2 Prius Main Forum' started by sulou, Feb 25, 2010.
  1. sulou
    sulou New Member
    Scotland
    I've had my gen II for 6 weeks, and the electrics seem to be playing up! Twice when I've started the car the radio has come on ( it wasn't on when I last drove it), the A/C has come on when I've only changed the temperature ( I'm very careful not to touch the A/C button) and today, the odometer changed to tripA! Anyone got answers??
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Sounds like you have a poltergeist :D
    Seriously though, you don't have any teenage kids do you? Who might just happen to borrow your car without your knowledge? :rolleyes:
  3. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Not sure about the radio, but if you have the HVAC system on auto, when you change the temperature the computer will kick in the AC under some conditions.
    However, the most common issue is the 12V battery might be going. This has been known to cause the most bizarre happenings as documented in a large number of threads on this board.
  4. a_gray_prius
    2,927
    783
    IL
    There is also the remote possibility of a fault or short in the electrical system.
  5. sulou
    sulou New Member
    Scotland
    Thanks for replies...when I bought it the ( Toyota) dealer changed the 12v battery because it had been in the showroom for a few months. They replaced it with Prius battery but for one for a Prius with 'a smart card' - could it be giving too much voltage and damaging the circuits?
  6. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    A 'smart card'? Do you mean a Smart Key? Prius' with the smart key, if left for lengthy periods (like on a showroom floor) could drain the 12v battery, potentially damaging it. The dealer should disable the Smart Key system (switch under the steering column).
    A new battery would not push too much voltage and shouldn't damage anything. Batteries usually go the other way - reducing voltage as they die.
  7. sulou
    sulou New Member
    Scotland
    Thanks- I did mean smart key!! - but my car never had one - the dealer put a battery intended for a car with a smart key into mine as that was all they had in stock. I think I'll go back to the dealer incase there is a fault in the circuits - before my warranty runs out! cheers:)
  8. richard schumacher
    7,664
    1,046
    United States
    There is no direct drop-in substitute for the Toyota battery. Get the correct battery with the correct original cables. If the dealer did some hacking to make an incorrect battery fit anything could happen because of poor or intermittent contact.
  9. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    The battery intended for SKS cars is larger capacity tho, correct? If there's nothing wrong with how it can be installed I'd probably prefer one.
    - D
  10. ceric
    ceric New Member
    1,114
    Fremont, CA
    It is unlikely that a battery with larger capacity (CCA) could be worse. It should be the other way around.
    I would check the connectors of the battery. A loose connector could cause random reset depending on surrounding humidity and vibration, etc. If anything, tighten the connectors, which only benfits, no harm.
  11. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    There is no possible way for an "incorrect" 12V battery to damage the circuits in your car.
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Unless somehow the connectors were not seated well. The advice I got was to loosen the connectors a little bit, make sure they seat well, then tighten.
  13. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I wasn't aware the GII Prius has two different sized 12V batteries. I thought they all use the same one?
    The GI Prius DOES have two different size 12V batteries.
  14. Patrick Wong
    18,200
    6,500
    G2 has two different battery sizes. The smaller one, 28Ah capacity, is for Prius w/o Smart Entry / Smart Start. The physical size is the same as the Classic original equipment GS battery; the only difference is that the battery terminal polarity is reversed.
    The larger battery, ~35Ah, is for Prius w/ Smart Entry / Smart Start.
  15. a_gray_prius
    2,927
    783
    IL
    The installation instructions for an Optima Yellow Top battery I saw on here note that there is little clearance for one of the terminals. If the wrong battery was installed, this might cause grounding issues?
