Push button under the steering column
Discussion in 'Gen 3 Prius Technical Discussion' started by doobs, Feb 25, 2010.
  1. doobs
    doobs New Member
    Branchburg, New Jersey USA
    Does anyone know what the botton is for?
    You can push it up and it springs right back.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    If it is the button just below and to the right of the steering column under the dash, it is the tire pressure monitor reset button.
    If you change the pressure in your tires, you will need to read the manual and press this button to reset the tire pressure alarm setting.
    From what I understand, if your tire pressure drops about 8 psi below the alarm setting, the tire pressure alarm will display on your dash.
  3. doobs
    doobs New Member
    I think its to the left of center, but I wasn't on the sit so it's hard to tell.
    I will chek and thank you.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Self Destuct, it's in the manual.. Don't push it!!!
    3 people like this.
  5. jayvee
    jayvee Member
    341
    89
    WA
    lol
  6. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    It's been a few hours since doobs has replied.
    Just saying . . .
  7. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    There were two buttons under the steering wheel. The left one is a momentary push that you hold down when you need to reset the tire pressure alarm. The right one is now an empty hole where prior to 2010 was located the SKS on/off button. The SKS now disables itself after around 24 hours I believe so Toyota deemed it no longer needed--unless you are paranoid of EMI with pacemakers in which case you just wish Toyota had left the damn switch in place.
  8. doobs
    doobs New Member
    Self destruct didn't work...
    So you can't get rid of me, sorry.
    Thank you Susan and others for your response.
  9. KK6PD
    4,003
    944
    118
    We were wondering?????:D
  10. AussieDave
    AussieDave New Member
    Melbourne Australia
    On the Aussie version there is also a button under there that allows you to turn of the collision avoidance braking so you just get the warnings and seat belt tightening reaction. No other buttons that I could find.
    David
  11. KK6PD
    4,003
    944
    118
    You didn't see the buttom that dispenses a cold can of "Fosters"..
    I had heard it was a Aussie only option, It's part of the AC system, it only consumes a litte more power than AC alone.
    I did try to purchase the extra pieces needed to try to do a aftermarket install on it!!! Sadly no joy
    :D
    Beer Mate??
  12. AussieDave
    Melbourne Australia
    Your humour is so good but wasted on me as I usually only drink unwooded chardonnay or basket pressed merlot while riding my kangaroo down the bush track we live on taking potshots as koalas and aborigines with my ex British Army Lee Enfield.
  13. orenji
    orenji Senior Member
    5,884
    3,486
    Someone stole my button.
