Question about running with no gas
Discussion in 'Gen 2 Prius Main Forum' started by Ichiro, Feb 27, 2010.
  1. Ichiro
    Ichiro Member
    335
    SF
    Driving to work the other day on 101 I ran out of gas!!
    SO embarrassing. Luckily the bay area roadside help truck pulled up a minute later to give me a free half gallon.
    Right after the gas engine conked out and the Red Exclamation Mark popped up, I was able to drive about half a mile and safely pull over to the side. I was very surprised to see I could go about 53-55 mph on the traction battery alone. Didn't want to go any further lest I completely drain the battery.
    I thought the max speed under battery power alone was 40 mph?
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    It generally is unless you run out of fuel. There is no speed-limiting mechanism per se for battery power; it's just that the ICE generally lights at >40 MPH.
    Even with fuel, there are limited conditions under which the car may run on battery power, although the ICE is still spinning with no fuel from the injectors. I've seen instances of higher-speed electric-only propulsion when HV battery charge is near 80% (eight green bars).
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I know that in this case you probably wouldn't have made it to a gas station anyway, but if you're really trying to get to a gas station or a phone or something then you'll generally go a lot further if you can keep the speed down at about 20 to 30 mph.
    At about 41 or 42 mph it starts turning the ICE, even if you are running on batteries alone, and this (along with wind resistance) will reduce your range.
  4. hill
    8,794
    Heretical Mode - GreenHybrid - Hybrid Cars
    Yup, there's way more to the HSD than should legally be allowed to know.
    :p
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Hill. Running all electric at greater than 42mph is not what they refer to as Heretical Mode.
    Heretical Mode
    is just where MG1 operates as a motor and MG2 as a generator (with the ICE also inputting power of course). This appears to be heretical from a engineering/physics perspective as you're putting in electrical power at MG1, passing the power through a lossy device (the transmission power split device) and then recovering electrical power from the output. At first sight it doesn't seem to make any good sense, however it does allow for really low ICE revs at moderate speed in some instances where only low output power is required. Kind of like an electric overdrive.
  6. northwichita
    481
    102
    29
    Wichita KS
    I have another question under this heading, what is the parameter that the car uses to actually stop trying to turn over the engine when there is no more fuel. I have not read of accounts that the engine runs rough, it generally just doesn't run any more. Is it safer -concerning the life of the fuel pump- to run out of gas in the prius that the average car? That is, is the fuel pump not trying to pump in the empty tank?
    I remember reading accounts of people testing for tank range by running empty after the low fuel pip, and personally haven't tried it- yet .
  7. hill
    8,794
    yea but aren't 41+mph speeds where one benefits from it (mpg wise) the most?
  8. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah I was wondering the same thing. It must somehow sense that it's empty.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yes I would think so.
    BTW. I think the mode that best describes the OP's situation (full electric over 42 MPH) is often what's referred to as "warp stealth" mode.
