Key Replacement PRICEY !!??
Discussion in 'Gen 3 Prius Main Forum' started by JJWax, Feb 27, 2010.
  1. JJWax
    JJWax Junior Member
    34
    Los Angeles
    2020 Prius Prime
    I've lost a key and need to get it replaced (I still have the second key that came with the car). Just wanted to see if my dealer is in the correct range in terms of price...
    He quoted me $640 parts and labor (labor?). Is that average/typical? Any advice much appreciated.
  2. BlizzardJ
    BlizzardJ New Member
    108
    SG, CA
    Man, that sounds ridiculously high. I'd scour feebay and kraigsfist first high and low for a replacement transmitter fob and then go to the dealer to have a new key cut.
  3. JJWax
    JJWax Junior Member
    34
    Los Angeles
    2020 Prius Prime
    Thanks BlizzardJ - can you do that? Get the cheapest parts you can find online (fob, etc) and then bring them into a Toyota dealer for assembly? I can just hear them saying something to the effect of "we have to order our own parts if we're going to do the work, have to be assured they're genuine Toyota parts, blah blah blah."
  4. BlizzardJ
    108
    SG, CA
    When we all bought our cars, the salesman does one of those "what I haven't covered yet" speeches before sending you off on your merry way. My salesman in particular explained in depth about the SKS and how to replace one for whatever reason. He stopped short of saying that you can buy the fob and the metal key as two separate items but I was under the impression that it would be possible to do it.
  5. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    You should shop for a better price, but eBay is the wrong place. Used fobs cannot be reassigned to a different car.
  6. JJWax
    JJWax Junior Member
    34
    Los Angeles
    2020 Prius Prime
    I'm at dealership now and have talked it down to 300 range...
  7. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    2010 Prius remores are still hard to find elsewhere. If you can wait a bit they should start showing up. As an example of prices here is one for the version II.
    2004-2008 Toyota prius Smart Key Keyless Entry Remote (NEW) Silver Logo
    2004-2005-2006-2007-2008 Toyota prius Smart Key Keyless Entry Remote (NEW)
    FCC ID : No N... Price: $129.95
    Keep in mind you will still have to get it programmed although still having the second remote in your possession makes it a much easier job.
    I found the above at Keyless Remotes from Remote SuperStore
  8. ghshelden
    ghshelden New Member
    Los Angeles
    We lost the key to our 2010 and today the dealer said a replacement would be $500 to $600. Wow!
    Any suggestions by anyone?
    Thanks,
    Geoff
  9. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    that is extortion in my opinion.
  10. justaguy
    justaguy New Member
    136
    california
    wow thats expensive for a cheap looking plastic key with a censor.
  11. Jon S
    Jon S Member
    185
    84
    The Aloha State
    no more expensive than any other keyless remote fob.... check around... they all charge several hundred dollars... my guess if you had to buy all the parts for your car piecemeal you'd probably end up paying several hundred thousand dollars...
  12. Carolina Dave
    Carolina Dave New Member
    25
    North Carolina
    You can buy a laptop cheaper than that. Major rip-off. That little thing isn't worth more than $150.
  13. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I am so tired of these people who think they have the right to tell us what to read and watch. I hate censorship. If I had known that Toyota was pushing that, I would not have purchased my Prius! Down with Censors!
  14. jburns
    829
    111
    Archdale, NC
    Yep some people have zero common ..........
    A. cense
    B. cents
    C. sense
    D. since
  15. bottomfeeder
    bottomfeeder New Member
    Chicagoland
    I have trouble understanding why a smart key itself should be more than an iPod, let alone twice the price. Garage door opener remotes can be had for $25-50, granted they are somewhat simpler, but not $300 less so.
    The electronics in the smart key fob are not complex; some kind of a transceiver chip, another IC and 3 switches and maybe a dozen other simple smc components. Less than $10 dollars of electronics and the plastic housing (the fob itself).
    These are obviously a big profit item for somebody.
  16. LeadingEdgeBoomer
    289
    29
    New Mexico
    Agreed, time will allow secondary sources to offer the fob. My 2001 Audi remote-opening fob with integral manual key was stolen in a break-in, and I had to have all 4 of the manual locks replaced by Audi ABQ for about $1K (they have a marble showroom!). I found a site online and got a replacement remote fob for about $100. My independent mechanic knew how to mate the car with it (or vice versa) for about $50. Audi ABQ said they could not cut me the manual key part of the fob to match the new one, they sent me to the ABQ VW dealer, they could.
    If the 2010 Prius fob with inserted manual key is is someone else's possession who knows where your car is, you'll have to replace the manual locks (3) to prevent interior theft and replace the fob. Try not to lose it until there are other suppliers!
  17. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I suppose it's "worth" whatever you're willing to pay for it, but I am in the semiconductor business, and a part like that costs less than $10 to build.
  18. qbee42
    3,082
    Small volumes and a captive market. Ever buy food at an airport or beer at a ball game?
  19. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    When I was buying, the salesman mentioned that Toyota sells a "warranty" for the keyfob that entitles you to one free fob and key each year. Unfortunately, he also said it cost over $500, and I passed. I try to keep one of the fobs in a safe place.
  20. bjm
    bjm Junior Member
    Chicago Suburbs
    We have multiple drivers and often need to jockey cars our of the driveway in the morning. So I wanted 4 key fobs. When I was buying the car, the salesman told me it would cost over $1,000 for two additional key fobs. Needless to say, I did not buy them from the dealer.
    Instead I bought a couple of key fobs from ebay. They were used; hence, previously programmed to another car.
    I then took all my keys to the dealer to have the two additional fobs programmed. If the fobs were never programmed for another car, the dealer would be able to add them straight away and charge me about $100. But since they were previously programmed for another car, the dealer needed to reseed my computer to add the four keys. This took more time to accomplish, but they only charged me about $200 to do it.
    The dealer was unable to cut the metal keys, because they did not necessary machine. I can live without the mechanical key on a couple of fobs. So in the end I got 2 additional keys for less then half of the dealer's price.
