Speed kills
Discussion in 'Gen 2 Prius Fuel Economy' started by don_chuwish, Feb 28, 2010.
  1. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    When reading about hypermilers creeping down the freeway on the white line at 50mph I always scoffed, thinking it just can't be worth it. Well, I still don't think that 50mph is a good idea, but on a highway run yesterday I had no reason to rush, so instead of the usual 65-67mph I set the cruise at 60 and did the 70 miles. Usually I'd get about 47-48mpg on that run, slowing to 60 for the big climbs and returning to 65 on the downhills. With the cruise set to 60 I saw 53mpg. Really drove the point home for me. On that 70 mile run I sacrificed about 5 minutes on the arrival time.
    - D
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    As much as I condone hypermiling and teach people how to hypermile, I agree that there are limits to the extent it should be taken. 50 on the interstate is scary and for me very boring.
    I will, however, find a semi with a 55 - 60 speed limiter and hang just on the outer limit of their wake. For those concerned, that's usually about 6 - 10 car lengths which is twice the distance cars follow each other at 70 - 75 mph.
  3. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Do you get any slip-stream effect at that distance, or is this to avoid impeding traffic?
  4. TonyPSchaefer
    14,816
    2,501
    66
    Both.
    I try to visualize the slip-stream and try to sit at the farthest point. I can often feel the "bubble" collapsing when I fall back farther. So I edge up into cleaner air.
    About the impeding traffic, many Prius owners have mentioned following slower vehicles for the sole purpose of looking like the victim of the slow moving vehicle. In other words, if I'm maintaining 55 - 60 mph on a wide-open interstate, I'm obviously driving slowly. But if I'm "stuck" behind a semi then others can blame the semi for my slowness. Besides, they can ride my butt all they want, it's not like i could go any faster.
    2 people like this.
  5. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Traffic dictates how far I'll go so I when possible go around rush hour. 50 is usually as low as I go on freeways.
    ________________________________
    In regards to Don mentioning the press on hypermilers, it's a lot like the press on the Prius. ;) Both the Prius and hypermiling have writers that are gearheads and simply won't give fair coverage - even spread falsehoods.
  6. fuzzy1
    10,603
    At 60 mph, the Two Second rule requires 176 feet, which happens to be a few inches more than 12 Prius lengths. When using trucks as protection against speedballs, I prefer to leave twice this distance, reducing stress fatigue.
    But apparently Two Seconds has been unrealistic in so many places for such a long time that when news media interviewed drivers caught by a tailgating emphasis patrol, many had never heard of it. Or that 2 cars lengths was unsafe.
  7. don_chuwish
    823
    190
    Southern Oregon
    Oh I wasn't talking about press coverage of hypermilers, I was going by their own accounts in forums and articles.
    But I was pleasantly surprised to see what a reasonable 60mph can accomplish. Boredom was a bit of an issue tho.
    - D
  8. TonyPSchaefer
    14,816
    2,501
    66
    Without a good audio book, I get bored following semis very quickly.
    Thankfully I can always see what's going on at Facebook.
    JUST KIDDING!!
  9. Chuck.
    2,766
    1,510
    Even so, there are a lot of people talking against hypermiling that have not given it a fair trial, quoting articles that are also slanted against it.
    ....so I feel guilty I have not caused a ten car pile up within the past three years like I'm supposed to do. :p
  10. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    To me, if the Prius requires significantly altering my driving style (including driving 10-15 miles slower than traffic) then the claims of good gas mileage are bogus. You can always come up with "tricks" to get better mileage. One is to only drive inside a building on rollers with no wind resistance and the air and heat off (e.g., the EPA method). Another is to always drive in the draft of a truck, or to never drive in bad (excessively hot or cold) weather.
    I drive normally and accept the mileage I get. With hard-core winter tires and driving the ups-and-downs here in Colorado that can be as low as 37 MPG for a tank average, which is common this winter. In a year of ownership I have never seen better than 42 MPG for a tank average even when driving in Oklahoma on vacation (relatively flat and lower altitude). Therefore, for me this is "normal" mileage. Any attempt to get better mileage would require significantly altering my driving style, giving up heat or air, or giving up some level of safety.
    I used to get this good with my Renault R5 in the 1980's. However, the Renault was a lightweight noisy box with no power anything. To get this good a mileage with a larger, heavy car with luxury features is, to me, acceptable. I will admit, however, the Renault rode SIGNIFICANTLY better than the Prius :D. Gotta love the French and their soft suspensions!
  11. don_chuwish
    823
    190
    Southern Oregon
    Yeah I used to be pretty impressed with my Honda CRX mileage back in the 80s, loved driving it too. But I imagine if I drove that car now I'd be very unimpressed by comparison to modern comfort and build quality.
    - D
  12. TonyPSchaefer
    14,816
    2,501
    66
    That's where the problem is. There's a distinct difference between driving for fuel efficiency and the flow of traffic.
    Let's look at the curve that was developed in the 1970s to determine the best speed for the average (not-hybrid) vehicle:
    Now consider that on the interstate the flow of traffic is between 65 - 70 mph.
    Using these two bits of information, it is not possible for any car to follow the flow of traffic AND realize the theoretically best fuel efficiency.
  13. Chuck.
    2,766
    1,510
    Consider that the EPA rates the Prius at around 45 mpg when the average US vehicle gets 21. Not bad, but 60mpg @ 60mph on the freeway is possible (speaking from experience).
    [​IMG] Source: EPA
    Note the reasons the average American's fuel economy has stalled at 21mpg:
    - Weight increased from 3200 to 4100 pounds.
    - 0 to 60 time has decreased by 5 seconds
    - Fewer manual tranmissions on non-hybrids
    - More trucks as personal vehicles.
    3 people like this.
  14. PriusLewis
    1,002
    84
    Denver Metro
    Thanks, Chuck. I agree with your assessment. In re-reading my own post it sounds a bit irate, although it wasn't meant to. I just don't see the EPA mileage numbers as very accurate (and it might be worse on hybrids).
    I also agree that there is a big difference between 60 MPH economy and 75 MPH. Not to mention my commute goes from about 5300 foot altitude to about 7600 each day. You would think I would gain back coming down what I lose going up, but even my base altitude is probably hard on economy (3 percent per thousand foot altitude loss of efficiency gives a 15 percent loss for the ICE at my altitude, and over 20 going over Monument Pass). I would rather get near 40 and drive "normally" than try to get 50 in these hills and at this altitude.
  15. Chuck.
    2,766
    1,510
  16. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Be interesting to see this on the same grid with a BobWilson4web Prius mpg vs speed graph. First, Prius about 4 times as high at 20 mph and still twice as high at 60 mph.
    Also, the shape of the Prius curve with its lack of gears is striking compared to this non-hybrid beast.
  17. fuzzy1
    10,603
    It would also be interesting to see it with manual and automatic transmissions separated. I know that my manuals don't peak at as high a speed as indicated by this graph.
    I didn't keep consistent fuel logs in my automatic days. Tried to, but it was corrupted by family members who wouldn't cooperate.
  18. Tideland Prius
    16,618
    luckily for me, the highways around me are 80km/h (50mph) limits. Of course the ones out of town are 100-110km/h.
  19. fuzzy1
    10,603
    That rule of 3 percent loss per thousand feet is for power, not efficiency.
    Efficiency actually improves at high altitude, especially in non-hybrids. Mine do better in Colorado and Wyoming than down here at sea level. The altitude difference is less in hybrids because the Atkinson cycle sharply reduces the 'pumping' loss that hurts sea-level efficiency in Otto cycle engines.
    As for 'gain back coming down what I lose going up,' my Prius does exactly that -- IF the downhill is not so steep that it requires friction brakes or engine braking. A number of your hills are too steep for that energy recapture.
  20. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Rain / slush (snow) kills MPG even worse than speed.
    I also like to follow 18 wheeler's, not to draft, but because they don't drive like jerks. A predictable vehicle in front of you means no braking.
    In bumper-to-bumper traffic, it's better in front of them, they don't mind when you P&G, if they can't get past 2nd gear.
