prevent dead battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cees1922, Mar 1, 2010.
  1. cees1922
    cees1922 New Member
    Knoxville, TN
    I have a 2005 Prius with 21,600 miles. Haven't driven it much since we moved into an apt with meals served last August. Drive once or twice about 10 mi or less each week. But, yesterday, it won't start. I had it jump started and was OK. How much driving per week should I do to keep the battery up and not have to worry about getting a dead battery? I am 87 yrs. and don't want to worry about dead batteries.
    Thanks so much
  2. Patrick Wong
    18,210
    6,517
    Toyota's guideline is that a Prius being stored should be made READY at least 30 minutes every two weeks to keep the 12V battery and traction battery charged.
    If your 12V battery is original equipment it may need to be replaced now.
  3. cees1922
    cees1922 New Member
    Knoxville, TN
    Thanks for the quick reply. I didn't think the battery would need replacing now. I have owned it as new for 4 yr. one month and didn't think 21,600 miles was long enough. But, I will be taking it in soon and will ask about the 12V battery. I didn't know there were two batteries. Did I merely recharge the traction battery? Thanks again.
  4. Patrick Wong
    18,210
    6,517
    The 12V battery is the small auxiliary battery that is required to power up the ECUs and start the Prius. With that battery, low annual mileage (like your case) usually means a shorter service life. This is because voltage on the 12V bus is fixed at ~13.8VDC, when the Prius is READY, and it takes a long time to charge the 12V battery at that charging voltage.
    The large traction battery is the one that will power the powertrain when you are driving on electric power. It also powers MG1 (via the inverter) to spin up the gasoline engine when it is time for the engine to run.
    The traction battery has a dedicated ECU that keeps track of the traction battery's state of charge. Based upon the battery's SOC, the hybrid vehicle ECU will allocate more or less gasoline engine power towards recharging the traction battery.
    Hence, the traction battery is able to tolerate very low miles being driven, as long as you drive your car periodically to give the battery a chance to be recharged by the engine spinning MG1.
  5. qbee42
    3,081
    The small 12V battery carries a load when the Prius is powered down, but not when the Prius is Ready. It's not really a matter of miles but age that kills the 12V battery. If you drove your Prius constantly, the 12V battery would last almost forever. Parking it as you do, the 12V battery will suffer an early death.
  6. cees1922
    cees1922 New Member
    Knoxville, TN
    Thanks to both of you. I have learned much about my batteries. I have so enjoyed driving my Prius so far and was shocked to find it let me down, or perhaps that I had let it down by not keeping the battery charged. I will make certain that I drive it at least 30 min each week. Will I ever get the batteries completely recharged or should I expect to replace the small auxiliary battery soon?
    I didn't know about this forum and appreciate your help. Thanks.
  7. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    If you have the smart key option (the one where the doors open when you approach, it has little black buttons on the door), you should disable it if you are not using the car for a while. That will significantly reduce the drain on the battery, and allow a longer interval between needing to run the car. It is a small push button under the dash to the right of the steering wheel. There is one next to it for resetting the tire monitoring system.
  8. Patrick Wong
    18,210
    6,517
    Since your battery is 4+ years old it may need to be replaced soon. If you have access to a battery charger this would be a good time to hook it up overnight, using the 2A position. If not, maybe you can leave the car READY for several hours in an effort to charge the 12V battery.
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The first winter with my '04, I had problems with my aux battery. It was literally a Perfect Storm to kill a battery: commute 15 mins, at -40, headlights on, Max Heat, electric defrost on, etc.
    I finally put in a VDC Electronics Battery Minder
    BatteryMINDer® Plus 12 Volt 1.33 Amp Charger-Maintainer-Conditioner (Desulfator) | All | Battery Chargers by BatteryMINDers.com
    which I hardwired directly to the aux battery
    When I sold the Prius last summer, the aux battery was still in perfect condition. If a Prius is used in something like Taxi duty, and kept in Ready 16-18 hours a day, the aux battery will last a long time
    A Prius rarely driven, especially with those low miles, you MUST use a battery tender. Never leave a conventional battery charger hooked up all the time, you will ruin the battery
    2 people like this.
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I do hope so :)
    I would have thought that all the additional power drain from the meter, two way radio and despatch computer running all the time (even if in Ready mode) would have a negative affect on the 12v battery.
  11. Patrick Wong
    18,210
    6,517
    No. Once the Prius is READY, it is up to the DC/DC converter to maintain voltage on the 12V bus at 13.8V. The output of that unit is fused at 100A. While the Prius is READY, the 12V battery does nothing other than receive a charge.
  12. northwichita
    481
    102
    29
    Wichita KS
    Since the owner in this case lives in an apartment, an extension cord may be problematic, one solution I've read others have tried is wiring a 12 volt solar charger directly to the small battery in the rear ( the cabin 12 volt power plugs are off/ disconnect electrically / when the car is off) .
  13. wag
    wag Junior Member
    Vancouver Isl & Interior of BC, Canada
    Still using original 12V battery which had been very abused for the first couple of years. It sat on the dealership lot for a good six months and needed a jump so I could test drive it. Then I had it down below 9 volts a couple of times after that (a slow learning curve on my part). I took Jayman's advice just over two years ago, purchased a couple of VDC Electronics Battery Minders for my vehicles, and have had happy batteries since.:D
    I don't use the Prius except for trips (cycle and walk locally), so it sits for periods of up to a month and a half without starting. I installed the connections for the Battery Minder under the hood (bonnet) on the Jumper Stud in the fuse box and a ground stud on the side of the Inverter. A simple install that doesn't interfere with anything. Attached pictures should illustrate installation, but if any questions, just ask.
    Wayne
    Ellyg and Rokeby like this.
  14. richard schumacher
    7,683
    1,065
    United States
    Note that it doesn't actually have to be driven to charge the battery. Merely turning it ON as though you were going to drive, but leaving it in Park instead, is sufficient. Do that for 30 minutes once each week and all will be well.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Duffy's Taxi here in Winnipeg is one of the pioneer hybrid taxi operators in North America. Winnipeg is a harsh environment, winter temps can reach -40 C, summer temps can reach +38 C
    About Us - Duffy's Taxi - 1100 Notre Dame Avenue
    I haven't heard of any Duffy's Prius taxi's actually wearing out. They usually get totaled in crashes with stolen cars, or get carjacked in a violent manner
    Do immobilizers lead to taxi carjackings? | Winnipeg | News | Winnipeg Sun
    Pregnant woman involved in taxi crash | Winnipeg | News | Winnipeg Sun
    If you play the following surveillance video, you will notice a Prius holds up well in a crash
    Taxi driver dodges death | Winnipeg | News | Winnipeg Sun
    Winnipeg is a very violent city, with a lot of gang subculture. It's considered the homicide capital of Canada, in addition to the car theft capital of Canada
    Perspective: Chill. Thrill. Kill. - Winnipeg Free Press
    so the fact a Prius holds up considering the climate and crime, is pretty amazing
    Much easier than wiring it up directly to the battery
