iPod hookup for 2005 prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by Exy, Mar 1, 2010.
  1. Exy
    Exy New Member
    Michigan
    Hey, sorry about how dumb this message is, but I just unexpectedly found myself buying a used Prius after my ancient Corolla finally gave up the ghost. I've always liked the Prius but I didn't anticipate buying one, but this was a great deal for a car that is a few years old but has been very, very lovingly maintained. (My father owns a Prius, and until now I didn't realize how many people there were who were even nuttier about their Priuses than he is! :p)
    Anyway, the radio in this is the JBL one, I think. It's a 2005 Prius and the radio has a 6-cd changer and a tape deck but no iPod attachment or aux input. I'd be most interested in a simple aux input -- I wasn't particularly thrilled when I tried out my dad's fancier iPod attachment when we went on a long trip to see family. So this seems simpler. But there isn't an aux socket out of the box. Is there an easy way to add it? One idea that comes to mind is if I could get something that plugs in where the tape deck goes in now, since I don't anticipate ever playing an audio CD in the thing. Is there some simple, hopefully cheap thing I could get so I could just plug something into my iPod's headphone jack?
    Let me know if you need any more information, I'm not really familiar with all the Prius models and options, since I just bought this thing today. Sorry if this question is something I could have found the answer to myself -- I've been doing some searching and I can't seem to find anything. Thanks in advance!
  2. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    A wired FM Modulator could be one option.
    http://www.amazon.com/Scosche-FM-MOD02-Modulator-Satellite-Portable/dp/B001QBG614
  3. zenMachine
    3,355
    300
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'd personally recommend getting a tape adapter since you've got the tape deck. You have no chance of getting and FM interference and it's cheaper than the already suggested options.
    I've had to use an FM transmitter on my Z and have tried both an FM transmitter and tape adapter on my former 02 Nissan Maxima. The tape adapter was hands down better.
  5. Boca Prius
    Boca Prius New Member
    I have an 06 with the same sound system. I just installed a DICE. Its works very well with full steering wheel MID integration. It also charges your ipod. Its $153 though the Priuschat store. I received it within a week and its so simple.
  6. zenMachine
    3,355
    300
    Wired FM modulators typically block out the radio frequencies you've set for it (e.g. 87.9) so there is no chance of picking up any over the air interference as with using wireless FM transmitters.
    A tape deck adapter is also a feasible solution, but it may not provide as good sound quality as a wired modulator. On the other hand, you don't have to take your head unit out to install it.
    You will find that each option has its pros and cons, and costs will vary. You will need to weigh which factor is most important to you, i.e. sound quality vs cost vs ease of use etc.
    Below is one more option to think about, this one even has Bluetooth A2DP capabilities. If you plan to eventually get a Bluetooth phone that can stream music as well, you might want to consider this little unit:
    http://www.amazon.com/Satechi-Bluetooth-Hands-free-Transmitter-supported/dp/B000NVYVRO
  7. Exy
    Exy New Member
    Michigan
    I'm not really eager to use either a tape adapter or an FM transmitter, since I've used those in the past on previous cars and was never impressed by the sound quality.
    I'm wondering if there's some reasonably easy way to add an aux input to the radio, and if anyone here has ever tried that out.
  8. zenMachine
    3,355
    300
    There's a difference between an FM Transmitter and a wired FM Modulator. The former is at the bottom of the list when it comes to sound quality. The latter should give you something equal to a strong FM station (since that's what it actually is), better than tape but obviously not as good as a direct Aux line in.
    The DICE unit is the next to best option. The absolute best option, of course, is to replace your head unit with one that has Bluetooth A2DP! :)
    In short, there's no easy-and-cheap method if you want hi-fi sound. But there is an array of options to consider, depending on your budget and requirements.
    My Prius has an Aux, so I've never had to deal with this issue. But it does not have BT A2DP, which is something I've been wanting to add.
    BTW, I've ordered the Satechi for my Xterra, which will give me BT hands-free and A2DP for my iPhone 3Gs. I've read that the FM Transmitter of the Satechi is quite strong. But if sound quality isn't up to par, I have the option to wire up an FM Modulator and connect the Satechi's line out to the new Aux port directly, bypassing the FM Transmitter completely.
    I should receive the unit in the next few days. I'll keep you posted on how it sounds compared to my existing Griffin FM transmitter. I also will try it out in the Prius, using its line out to connect directly to the Prius Aux in port. If it works out well, I may get a second unit so we can have A2DP in our Gen2 Prius.
    The cool thing about the Satechi is that it's portable. We travel a lot, and not every rental car has Bluetooth hands free. But most nowadays have Aux port on the radio. This unit will give us hands-free plus A2DP streaming no matter what kind of car we rent.
  9. zenMachine
    3,355
    300
  10. Exy
    Exy New Member
    Michigan
    Thanks! I think that'll do what I want. Now I have to decide if I'm too scared to try installing it.
    Has anyone ever installed something like that and figured out a way to fish the wire into the console, so I can stash by iPod there?
  11. zenMachine
    3,355
    300
  12. FCBarca
    FCBarca Junior Member
    La Côte
    Yeah, I'm in the same boat as the OP.
    Cassette adapters seem to largely converge on the Sony CPA-9 (Made in Japan) but it's a bit like the unicorn at the moment as the CPA-9C (China) is the prevalent version (And poor quality, apparently)
    FM transmitters sound easy enough in theory but the reviews do seem to always come back to potential hiss or FM interference
    Bluetooth streamers sound like a viable option but I haven't been able to really find any reliable reviews...Plus, would it interfere with the native Bluetooth in the Prius?
    DICE sounds appealing but not sure I have the skills to install this...Plus, there's the matter of convincing my wife the pricepoint is worthwhile :eek:
    The GROM-I2-TOY sounds interesting but wonder who's actually had success with it...Was thinking of asking my local dealer if it's something they can install
    I don't have the Aux adapter and was curious if this is a complicated aftermarket add on since it would seem to be the cheapest/cleanest way to be able to play music off my iphone4
