How do you remove those wheel hubcap rim/halos??
Discussion in 'Gen 2 Prius Main Forum' started by bluemoonseller, Oct 30, 2009.
  1. bluemoonseller
    bluemoonseller Junior Member
    26
    I don't want to break nothing. Step by step guide? Video? I tried pulling them off with force but their not coming off. Someone stole one of them from my prius and my car looks awkward with a missing halo. Thanks in advance.
  2. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    Hook a couple of fingers on it and give a firm pull out. They come off fairly easily.
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    From darelldd at evnut.com:
    Just hook a couple of fingers like this (and use your other hand in an adjacent spot) and yank toward you. Extra style points for not falling on your butt when it pops off.
  4. Doc Willie
    1,717
    144
    Out there, somewhere
    Alternatively, if you look at the edge of the rim, there a slots, 180 degrees apart,where you can insert a 3/8 wide blade (Stanley 716 offset screwdriver if you can find one), and they will pry right off. They will not break.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    You can do it like Doc says but IMO falling on your butt after pulling a trim ring off is like a rite of passage for Prius owners. :)
    Beneathemoon likes this.
  6. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Only if you're silly enough to be standing off-balance when you're pulling on them. My suggestion, sit down first and pull. :cool:
    alanclarkeau likes this.
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    Grab. Pull.
  8. kkayser
    kkayser Junior Member
    49
    A big screwdriver pops them off. They are really tough and you need not worry about damaging them. (except by hitting a curb.)
  9. Melvin
    Melvin Junior Member
    Singapore
    i think these wheel cap are useless to me.
    I threw mine away when the OEM tyres wore off.
    When I change to a new set of tyres I just pull it off and threw it away.
    Maybe its some weight off my car and I will have a better fuel consumption..
    hahahah
  10. patsparks
    10,664
    567
    Adelaide South Australia
    No you wont!
    They protect the expensive alloy rims from gutter rash.
  11. hill
    8,826
    There's always the "sit, grab onto the ring, yell at driver to gun it" method. Take care driver doesn't back over you while returning for remaining rings.
    :eek:
  12. bluemoonseller
    26
    I'm shocked at how easy these are to remove. I park in the public. One of my halos were stolen. So i decided to remove all to match 8D.
  13. Melvin
    Singapore
    Oh My god.
    Why would some one ever want to steal that.
    It must be another Prius owner who had his broken and he came took yours away.
    Anyway it looks good showing the alloy rims.:)
  14. mary2al
    mary2al Junior Member
    57
    SF Bay Area
    I took the plastic wheel covers off my 09 touring 16" (can't believe anyone would leave em on over those cool wheels)
    However now I need the small center hub cap -- any ideas muchly appreciated!
    Danka
  15. Melvin
    Singapore
    Hey did your ride not come with the Toyota hub cap?
    I thought all comes with it?
  16. Boo
    5,051
    488
    97
    Flushing, NY
    In the United States, the Gen II Touring Edition's 16" wheels came with full wheel covers with the "center cap" being part of the wheel cover.
    So people who remove the wheel covers from the Gen II Touring Edition's 16" wheels have to get separate center caps. Usually they get the center caps that came with the Gen II Standard Prius' 15" wheels.
  17. Boo
    5,051
    488
    97
    Flushing, NY
  18. Melvin
    Singapore
    Oh Boo,
    NOw I know
    Because in Singapore the wheel covers are just covering the while alloy rims with a hole in the center.
    Removing the wheel covers does not mean removing the center wheel caps...
    :pop2:
  19. b8b
    b8b Junior Member
    24
    United States
    Do these serve any purpose other then protecting the wheels? Does it effect MPG keeping them on or removing them? TIA!
  20. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Many of us have speculated that they probably reduce Cd a bit, but I have seen no data on it. Maybe run a little round trip test on a calm warm day and report?
