Toyota Split Screen Braking Demo (Toyota Canada Demo)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Mar 8, 2010.
  1. Tideland Prius
    16,501
    Toyota Canada does the braking demo with and without "Brake Override Logic"
    16 people like this.
  2. uart
    uart Senior Member
    4,220
    1,209
    Australia
    So the bottom line is : people who know how to drive and who drive safely are unlikely to end up in a life threatening situation even if that one in 10 million event actually happens to them.
    Thanks for sharing that Tideland.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    For those who aren't familiar with speeds in km/hr, 80 km/hr is almost 50 mph.
    I did this same experiment in my 07 Prius from a little over 40 mph, and the car stops within 3 sec with the accelerator floored.
  4. bwilson4web
    16,122
    Now if we could just add a sound track of screeching tires ... <grins>
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    I don't know if you heard the tires chirp when they tested the Prius, but when I hit the brakes they did lock up briefly and the tires chirped before the ABS kicked in.
  6. Patrick Wong
    18,200
    6,499
    Yes, I also noticed that when doing the demo on my 2004.
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I gotta try this in mine. I tried it at about 20MPH and the engine kept trying to go
  8. qbee42
    3,079
    Remember, with a Prius, the engine can keep going without powering the wheels.
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    I have a Scangauge to read ICE rpm. When I had the accel pedal floored the engine speed was > 4000 rpm - when I hit the brake pedal the engine speed dropped to < 1000 rpm within approx 2 sec - I could not get an exact time because of the lag of the Scangauge updates. The ICE speed drops with the accel pedal still held to the floor but does not stop completely.
  10. Tideland Prius
    16,501
    IOW mgb4tim, you can't brake-throttle start a Prius. The engine won't rev to the redline if you do that. Try that when you're stopped. Press the brake pedal firmly with your left foot and adjust the accelerator with your right foot and see how the engine reacts. It doesn't move the car forward like a normal car. Additionally, the engine will not rev in neutral.
  11. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    The Toyota test is better then nothing but I really want to see Toyota:
    1. disable the brake override feature that cuts the engine, and
    2. disable the power brake assist...
    on a 2010 Prius going 90 mph.
    Seriously, 50 mph isn't pratical enough. 90 is more worse case.
    I've watched one You Tube video demonstrate this using a convention car that had no override but I think it still had power brakes. I don't remember its top speed but it stopped relatively easily with the engine still floored.
    The worse case scenario I think is that the Prius's ECU has a catastophic unduplicatable failure of sorts where the driver claims that the accelerator is stuck; that they can't shift into neutral or nothing happens when they shift; that they push on the brake but nothing happens (because the power brake they are use to has failed; and they don't know how to shut down the engine by holding the Start Button in for 3 seconds.
    I'll bet within the next 3 months Toyota does a campaign (I don't like using 'Recall' unless it is madatory) on all Priuses to change the emergency stopping procedure to allow several rapid pushes or a constant push on the 'Start' button over 3 seconds. That would be helpful.
    I also simply want to know how tough it is to stop the car at high speed if the power brakes for their own reason fail. As far as that goes I wonder how well anyone could control steering if power steering failed on curves where you can safely go through a curve normally at 55 mph say? Does Toyota design for those speeds and torque or do they only have to prove the cars handling under system failures at say 35 mph?
    We have a very serious problem if hybrids and cars full of technology today somehow spook drivers into not reacting properly by applying the brake immediately when any unscheduled acceleration occurs. Once a driver isn't sure what they did or didn't do in an incident and a news media get ahold of the story all bets are off.
    I wish I could trust drivers more but car drivers at least do not train for emergency situations like truck drivers pilots are reqired to do and demonstrate.
  12. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Remember, brake + go-pedal = force-charging. With the throttle
    held down in the conventional car the engine would have continued
    trying to pull too, but only straining against the torque converter
    instead of putting all that energy somewhere useful like the
    battery.
    Like the video says at the end: "always familiarize yourself with
    your vehicle's capabilities ..."
    _H*
  13. Tideland Prius
    16,501
    Maybe that's it. Each owner MUST go through mandatory training on a vehicle. I think we'll call it an owner's clinic. Sounds better than mandatory training.
    Honestly, I don't know anybody that reads the manual any more. So is the manufacturer to blame cause someone doesn't know how to operate a vehicle? Most people go under the assumption that "yeah it's the same or similar to my other car". Heck, I don't read the manual when I get into a rental car BUT I do familiarise myself with all the buttons and controls before leaving the rental company's parking lot. And I mean everything - The common radio buttons (volume, power, seek/track), climate controls, cruise control, wipers, headlights and even ignition key hole (remember some GM cars go ACC, OFF, ON, START rather than OFF, ACC, ON, START)
  14. hitechboy
    hitechboy New Member
    128
    Toronto, Canada
    Why not test the more powerful models that dead were involved at a higher speed? Is this comparing an apple with an orange?
  15. austingreen
    austingreen Senior Member
    13,664
    4,204
    Austin, TX, USA
    shh... how would that help pr?
  16. hitechboy
    128
    Toronto, Canada
    Yes, you are right. I forgot this is Priuschat! Let talk Prius only.:D
  17. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I may have blinked along the way since researching and purchasing my '10. Does the '10 Prius have brake override???? I didn't think it did....
    If so, (I must say) further peace of mind here.
  18. Tideland Prius
    16,501
    Well they would be fitted with larger brakes, no?
    And this is Toyota Canada, not Lexus Canada (I'm not sure how they operate and whether they're separate entities). No Lexus is under the recall notice. Funny eh? Gotta love the media.
  19. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Well, after yesterdays event down somewhere near San Diego it's pretty clear to me that there is a lot more going on here now then drivers not knowing how to react to an emergency. In this case it was a 2008 Prius and once again three things are really happening--going wrong: 1. Acceleration is sticking. 2. The feature all the Priuses have that returns the engine to idle when the brakes are applied isn't happening--the car continues to accelerate. 3. In this case at least the car getting up to 90 mph was going to fast for the brakes to override the engine's torque and this lucky guy from what I've heard used up the brake pads--down to metal against metal?
    I'm suggesting for myself at least not to exceed 55 mph (until this mess is resolved) and react quickly with the brake should acceleration take off--you have a much better chance bringing the car to a quicker stop without going through a set of brake pads then if you are already traveling 70 for instance and don't react quickly before the car gets up to 90 mph.
    It is unfortunate that this driver apparently never tried shifting into Neutral and apparently didn't properly stop the engine by holding in the Power button for at least 3 seconds until his wild ride was almost over.
    I'm going to make up a placard that reads something like: "Do not exceed 55 mph! > Brakes! + Emergency Flashers + Neutral + Power button HOLD 3+ seconds! + Parking Brake + Stand on Brakes With Both Feet" and _practice_ all of it. I find it remarkable that the driver 1) was on his cell phone (Did the CHP really help save his life?) and 2) Apparently was unable to shut the engine off properly until he was around 50 mph.
    Toyota needs to demonstrate or just confirm that brakes alone will not stop a Prius going 90 mph with a stuck accelerator. Until this is resolved fully Priuses should be restricted not to exceed 55 mph. Procedures and Standards need to be set up industry wide so Emergency Stopping works the same basic way across the industry.
  20. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Has anyone hypothesized that the brake problem might actually have been a fuel economy feature? When the problem first occured, Toyota said they were "monitoring what was being said on the Internet". Perhaps that meant it was a feature, and were wondering whether users had realized it. Perhaps by making the brakes that way, they could maximize regen in the first part of pedal depress. And perhaps with the software update, regen is not as efficient...
