Ham radio and Prius
Discussion in 'Gen 2 Prius Audio and Electronics' started by ralphbongo, Apr 12, 2007.
  1. ralphbongo
    ralphbongo New Member
    83
    Ok here is the trouble. I am a ham and want to use my handheld radio in the car. Woops no luck. All the electronice in the car make more rfi (radio frequency interference) then the radio can handle. Its in the inverters that power all the goodies. Inside antenna, outside antenna no difference. The radio is running on its own battery and not hooked into the vehicle at all. Dealer when ask had no answer. Any ideas would sure help. Thanks
  2. viking31
    viking31 Member
    515
    22
    West Central Florida
    Most likely the front end of your handy talkie is weak as many are. They are easily swamped by stray RF of which the Prius emits more than most vehicles. However, just about any single or dual band mobile (2m/70cm) work fine in the Prius. Lots of hams have had good results with VHF and UHF (me included).
    But, HF is another story. Basically it is unworkable due to high levels of noise (S9 or greater on many bands).
    Rick
    #4 2006
  3. hill
    8,918
    <div class='quotetop'>QUOTE(viking31 @ Apr 12 2007, 09:33 PM) [snapback]422319[/snapback]</div>
    Agreed. He didn't say, but I wouldn't doubt he has a Yaesu. Many radio techs joke you can tape over the face plate of them (not vertex though ... which still makes a nice commercial rig) because it receives/transmits over a lot wider area than the typical 2 or 3 khz that you'd expect.
  4. ralphbongo
    83
    <div class='quotetop'>QUOTE(hill @ Apr 12 2007, 08:55 PM) [snapback]422333[/snapback]</div>
    Yep its a yaesu but it's ok on 440 146.155 Sucks big time . I had thought about some beads on the wires to and from the inverters but had to order them from aes in Orlando. I will keep you poasted and thanks.
  5. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(ralph b @ Apr 12 2007, 07:04 PM) [snapback]422298[/snapback]</div>
    There's another ham radio thread over in Prius Technical Discussion at
    http://priuschat.com/Installing-ham-radio-...ing-t30840.html
    I'm running a Yaesu FT-60 dualband handheld with no trouble, I can even scan all the memories without spurious stops. What model Yaesu are you using? I do pick up some crazy qrm on my XM radio occasionally, usually when the ICE is stopped, so not sure what that's about. I wonder how many ham operators lurk in PriusChat? I wonder if we need our own section in PriusChat? 73
  6. chappyfade
    chappyfade New Member
    Kansas City, MO
    I'm a way new ham radio operator (my call sign just hit the FCC database 2 days ago). I've been transmitting on my Yaesu VX-150 HT (2-meter) on 146.79 from my Prius without any issues.
    Chap
    KD0APD
  7. manassascrow
    manassascrow New Member
    manassas
    I have a Yaesu 8R and find the 2m and 70cm bands working fine with a mag mount. Would like to hear about longer wavelength problem or successes.
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I find that with the mobile Diamond antenna, my FT-8800 works great.
    Time to install a full time rig in the car.
    I also have a BC996XT in the car, works just fine!!! Again, an external antenna!
    Welcome to the Group, and Fine Business on the Ticket OM!!
    Next step, Extra Class
  9. grinthock
    grinthock New Member
    I have no issues with my setup.. 2 Astro Spectra's, one in VHF and one in UHF.
  10. KK6PD
    4,003
    946
    118
    Justin, nice clean install, is that a dual band glass mount, or do you have another one on the other side?
    What's the VSWR with those antennas?
  11. grinthock
    VSWR is about 1.3 across the ham band... I have 2 - one on each side -- they are dual band so you COULD use a single one with a duplexer. To be honest, for in the city - it works perfectly well. Not the highest gain - but it works quite well.
    It's totally discrete, people hardly even know there's a radio in the car..
    The bracket was custom fabbed by me to hold the radio heads. This is a NO HOLES install. Not one hole drilled, not one modification. The car is leased so I wanted to make sure I could easily reverse what I did.
    Bracket fab...
  12. IndyDave
    IndyDave New Member
    Indianapolis
    Hey justin great looking setup. I'm thinking about trying to setup a mobile rig in my prius. Could you describe how you've mounted the actual xcvr bodies and how/where you ran the wires up to the face plates?
    Thanks in advance
    - Dave
  13. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    A FT-60R works fine for me. more range with the magmount, of course.
    Your problem is particularly curious because the modulation mode on 2 meters and 70 cm is FM. How does this RFI manifest itself? How far from the car do you have to get before it goes away?
  14. JoesPriusLife
    JoesPriusLife Junior Member
    Bethpage, New York
    Four Touring
    I also use a Yaesu HT it the Prius. The only major interference I found was on 448.500. Otherwise all other noise was covered by the squelch.
