New bluetooth issue
Discussion in 'Gen 2 Prius Technical Discussion' started by ThePackage, Mar 4, 2010.
  1. ThePackage
    ThePackage New Member
    74
    First, I have an '06 with NAV and for the past 4 years, regardless of phones, my bluetooth has worked flawlessly. Just recently, with no changes that I made, every time I start the car, the bluetooth connects and turns on. It never seems to dial a number but the phone is on and waiting to dial. I have to manually turn the phone off at the touch screen.Has anyone experienced the same issue and what is the solution?
  2. qbee42
    3,077
    Have you tried another phone? My first suspicion is that something is different with your phone, not the car.
  3. Priusfromevil
    Priusfromevil Junior Member
    65
    KC
    I've noticed this. My Motorola Q phone's screen comes on when it connects via bluetooth, but the display timeout (on my phone) goes out after 10 seconds.
    Mine has always worked like this. Maybe try the activity timeout setting on your phone?
  4. ThePackage
    74
    UPDATE: I discovered that the problem was my Blackberry Storm. Somehow the Bluetooth software, in the phone, became corrupted. The fix was easy. I removed and replaced the battery which allowed the phone to reset and reboot. Everything is working just as it had in the past. If it happens again, I'll replace the phone.
  5. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Had similar problem with my Google Nexus One. Then rebooted it and worked fine with Toyota BT.
