Which has better ride - IV or V
Discussion in 'Gen 3 Prius Main Forum' started by Chucka, Mar 12, 2010.
  1. Chucka
    Chucka Junior Member
    39
    Fairfield County, CT
    Can someone who has recently compared these two in actual driving of the 2010 Prius V and the Prius IV describe the difference in the ride comfort and handling? How much does the tire size have on these two cars? Is there any disadvantage of one over the other (not counting available features)?
    Chucka
  2. Russell Frost
    Russell Frost the whatdrives.us guy
    149
    114
    Escondido, California
    Ride- from a strictly performance standpoint, the differences are negligible in my opinion. Small, noticeable but arguably, not enough to pay for (unless every little bit better is worth it to you). I think V looks a lot cooler.
    Comfort- no differences that I could detect aside from the obvious difference in features which, in my opinion, don't make the V more comfortable, than the IV.
    Handling- see "Ride"
    I bought a IV after driving both. Just one person's view, as always, YMMV.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I've got a V and my dad has a IV. You can tell there is less rolling resistance while driving the IV with the 15" rim and tire combo. Yes, I can actually 'feel' that difference, I was shocked. The ride is a bit 'harsher' in the V but I kind of like that. The wheel also feels firmer in turning on the V. The differences a small, not huge, but it's best to test drive both if ride quality/drive-ability is what makes a car for you. And definitely, the 17" rims look WAY cooler than the 15's... But driving the 15's I can get better mpg definitely.
  4. mitch672
    mitch672 Technology Geek
    1,077
    198
    Randolph, MA
    The handling is far superior on the V, at least compared to my 2004 GenII, which had 15" wheels. Cornering is better, the car "feels" more stable at high speed on the highway, with a crosswind. I would never go back to a lesser model now. There is more rolling resistance on the wider 17" tires, but that is why the car is more stable at highspeed and in crosswinds, it has more road contact. I sacraficed the 2-3 mpg for the improved handling. the V, Gen3 is still getting better mileage than my older Gen2/2004 model...
  5. mmichaell
    mmichaell Member
    241
    chicago
    imho, any stock North American Gen3 (IV or V) is better than a Gen II with 15" tires, from the times I've used a Gen II. Never tried the Gen II touring version however.
  6. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    get a II or III and take the money you would have spent on a IV or V and buy new rims and tires that you like.
  7. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    I've seen it posted many times that the 17's getting less mpg's and I believe those posters. That being said, why do you suppose it's true?
    Is it because the 17" tire/wheel combo is heavier? Wider? The tires themselves have more rolling resistance?
  8. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    You are supposed to get more MPG with 17' wheels.
  9. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The II, III, and IV handling is noticeably better than the Gen2 non-touring also. Less body roll on the '10, whole car feels more solid, not that the Gen2 is bad or anything. But there was a reason some added BT Tech brace (sp?) on the Gen2.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    There is more tire in contact with the road, likely more rolling resistance, bit less MPG's.
    I would think the larger tire wheel combo weighs a little more too.
  11. austingreen
    austingreen Senior Member
    13,703
    4,229
    Austin, TX, USA
    the V's wheels and tires weigh approximately 10lbs per tire more, my 17" wheels and tires weigh approximately 5lbs per tire more. This will not greatly affect mpg.
    The 17" tires have a greater contact patch which improves skid pad and decreases breaking distance. Depending on tires this will increase rolling resistance. Those with 17" tires may also drive more aggressively.
  12. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, you will get less with the 17". Toyota has said this from day one...
  13. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    I think the IV has a better ride ;), but I drive my 2nd Gen '08 more often. As mentioned before, the difference on IV and V ride wise is almost unnoticeable. Get the IV with Solar Panels or V with a little more options.
