Loose grounding sound...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sguerra923, Mar 12, 2010.
  1. sguerra923
    sguerra923 Junior Member
    48
    San Diego
    Hi guys/gals,
    I did some search but really couldn't find anything but I'm having a very annoying buzzing noise that sounds like something you have when you have a loose grounding wire.
    It happens when I brake, even driving at times, and when I turn on the fan I hear it from the front driver side vent (it would stop when I close the vent).
    Anyone else experience this problem?
    Plus, now my brakes squeek sometimes and the center console creeks and vibrates when driving. I'm not trying to be too picky about it but it really gets annoying even when the stereo is blasting.. bleh :confused:
    I like the Prius but dang did I get a dud?
  2. yam
    yam Junior Member
    64
    Austin TX
    Re: Lose grounding sound...
    I get an intermittent sound from the front passenger side. It shows up for a few seconds, maybe once every couple of weeks. I've only noticed when the vehicle is stationary.
  3. Much More Better
    Much More Better Active Member
    655
    163
    I've had it on occasion too. Mine is from the driver's side, almost under my seat. It has always occurred at a full stop, at a red light for eg. It is a grinding sound lasting for 1 sec. It's unlike all the other electronic buzzes that happens after the car is shut off. Those sound normal and deliberate. This grinding is a concern.
  4. sguerra923
    48
    San Diego
    So basically, if I take it to the dealership will they be like ummmm we don't hear anything LOL! Great!
  5. Much More Better
    655
    163
    Pretty much. Unless they happened to have another client who brought in the same problem and they know how to fix it. But what are the chances.......?
  6. qbee42
    3,079
    The grinding or buzzing sound on the driver's side is the brake accumulator pump. The Prius uses electrically assisted power brakes, and the assist comes from an electric pump that runs every once in awhile. Try repeatedly pressing the brake. You will get the buzzing sound maybe every third press or so.
  7. Much More Better
    655
    163
    Actually, it is near the pedals. But I can go for days without hearing it. I got the ABS update on SAT, but I heard it buzz once today, so that is unrelated.
  8. qbee42
    3,079
    The brake accumulator buzzing sound comes from the driver's footwell, down at the level of the pedals. It happens frequently, but mostly it isn't noticeable due to other noise and sound.
  9. poetrythyme
    poetrythyme New Member
    Dallas
    My prius has a loud grinding sound in drive at any speed but never in reverse or at complete stop. This started yesterday and there is no warning signal displayed.
  10. docsnavely
    docsnavely Insert Custom Title Here
    66
    Ocoee, FL
    You should check out the DVD that came with the manual. It details many of sounds the car makes and amplifies them so you can hear them unmuffled by other sounds.
    Check it out, you might be surprised to find some of the sounds you are experiencing...
    Good luck and hope its nothing serious.
