Highway Speed: How Fast is Fast?
Discussion in 'Newbie Forum' started by mcamp52, Apr 12, 2009.
  1. mcamp52
    mcamp52 New Member
    32
    Central Florida
    I have a "new" 2005 and took a 100 mile trip on the interstate for the first time this weekend. I am used to driving cars with tachometers and using that as a way of driving conservatively, without really winding up the car.
    On this trip a did a lot of cruising around 70 mph and avoided the temptation to go any faster. Overall, I averaged 47 mpg and I'm cool with that.
    But for future reference, does anyone know at what point the Prius is really "wound up" and running to fast? It's not like I want to drive like crazy but I do want to have a feel for not over taxing the car.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    It's fairly linear, you'll see the MPG drop, RPM rise with increasing speed.
  3. Tideland Prius
    16,621
    As Efusco said, it's fairly linear. If it's revving up there, you're probably cloes to 100mph.
  4. KCPrius
    KCPrius Member
    133
    Overland Park, KS
    I've taken several road trips and set the cruise at 80 and the engine does not seem to be straining at all. Mileage is in the high 30's at that speed. For what it's worth, I don't like to do a "cruise control pass" of slower moving vehicles going close to the same speed as me, so I will occasionally take it up to 90 to 95 mph. I don't keep it there long, but it still doesn't sound like it's straining at all.
  5. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    You might be interested in the little rundown on steady-state
    highway observations that I just posted over at CleanMPG.
    I try to never go over 3 grand...
    _H*
  6. qbee42
    3,080
    Mostly the problem is aerodynamic drag. With aerodynamic drag the power requirements go up by the cube of the speed. I wouldn't say it's linear, except in the most crude approximate sense that mileage drops with speed.
  7. Habeepbeep
    Habeepbeep New Member
    Tampa
    I've had my prius for 5.5 years and have driven up and down the East coast dozens of times. I usually set cruise control at 80-85 when I'm driving on I75 but in one case (fleeing a hurricane) I have reached 97mph. My prius seemed to do just fine and did not have much strain on it (granted it was a few years old at that point). I'm not recommending speeding, I'm just letting you know my own personal experience.
  8. richard schumacher
    7,666
    1,047
    United States
    Go as fast and hard as you like. The computers limit engine RPMs in all circumstances.
  9. mcamp52
    mcamp52 New Member
    32
    Central Florida
    Thanks everyone. Great answers.
  10. danl
    danl New Member
    231
    Boston, MA
    Too fast for me is anything above 65mph. Only because my commute to work consists of mainly a 2 laner with a 45-50 limit.
  11. Eoin
    Eoin Active Member
    593
    116
    Long Island
    How fast is too fast? Simple. If you get a ticket, that's too fast.
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I spend a lot of time cruise controlling at 61 MPH (by the speedometer) on perfectly flat ground. 1900 RPM with the throttle 25% open. 69 MPH is closer to 2200 RPM. Once it quits being flat and/or you can't keep a constant speed, RPMs are all over, 980 RPM to 5000.
  13. F512M
    F512M Member
    415
    Laguna
    Ha, ha, ha I guess that's one way to look at it.:D
  14. puppeto
    puppeto New Member
    Ringgold, GA
    Depending on terrain depends on where I stick the cruise. Here lately I've been down in the flatland of southern Mississippi so I've been setting to 63 to keep the MPG's up around 55. Further north into the mountains I don't bother with cruise and just feather it up and down hills.
