2010 Prius braking rolling noise? (Just got my Prius today!!!!!!!)
Discussion in 'Gen 3 Prius Technical Discussion' started by tyrus13, Mar 13, 2010.
  1. tyrus13
    tyrus13 Junior Member
    25
    First of all, let me say that OMG I AM SO EXCITED!!!!!!!!!!!!!!!! :D
    This is my 1st Prius ever. Perhaps I'm a newbie that don't know anything, but when I was parking the car earlier (the street was very quiet), when I step on the brake I can hear some sort of rolling noise coming from the back of the car. And this noise has been consistent. I moved forward/backward many times just so I can brake, and I have been able to produce the noise every time I brake the car. The noise is like a mechanical/machine/robot sound where something is rolling into another or something like that. The noise is very soft. It's probably only audible when it's dead silence out.
    Is this normal?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Check to see if you haven't run over the neighbor's dog. Just kidding... but you might just take a peak underneath to see if anything is there.
    Welcome aboard and try to relax. This car makes all kinds of odd noises. If anything is wrong, Toyota will fix it.
    Cheers and welcome aboard.
  3. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    Mine makes no noise.
    Look in (and under) the cargo and spare tire area for something
    loose that is moving or rolling around.
  4. tyrus13
    25
    Will do. Thanks for the advise!
  5. Superdrol
    Superdrol Member
    399
    32
    I just got a new prius a few weeks ago. I love the car as well. My car makes though noises with the brakes as well it could be just bc he car is new. My corolla did that when it was new and same with the Camry. It goes away after the car gets broken in or you can have them lubricate the brakes as well. It's normal.
  6. Wiserone
    Wiserone Member
    111
    B R O O K L Y N
    Lubricate the brakes? Eh?
    Maybe the noise is just the brake regen?
  7. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    does it sound like a subway train slowing down?
  8. tyrus13
    25
    Took it in to the dealer. Turns out it's just the full tank of gas sloshing around when I step on the brake pretty hard. When I let the car roll to a stop, I don't hear it.
    Thanks for the advise guys!
  9. lsun22
    lsun22 Junior Member
    sacramento
    i just got a new 2010 prius a month back. when i brake, it doesn't make a noise. but if i'm stopping, it'll make a whirrling type of noise as i let off the brakes just before i come to a complete stop... i assumed it was something to do with the spooling of the regenerative braking system.
  10. Jolly Paul
    Jolly Paul Member
    162
    28
    Did you stamp your feet and angrily demand they fix it? :D
    Dealers LOVE that kind of thing.
  11. Codyroo
    Codyroo Senior Member
    1,826
    514
    Pleasanton, Ca
    This is what I hear in mine, most prominently when I'm at low speeds and coming to a full stop. I thought this was the regenerative brake or the regen brake switching to friction brake. Maybe it is just the electric engine winding down (sounds like a BART train stopping or starting *subway train for those not from the bay area)
    Thoughts?
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Inverter.
  13. socratesthecabdriver
    283
    31
    greece
    i noticed that noise also its a new sound i never heard any car make before , then again its not like other cars. i think its supposed to be there!
    one thing though, you got to be a engineer to understand this car!
  14. tyrus13
    25
    No, I think you gotta be an auto engineer. I'm a chemical engineer and I barely understand the car.
  15. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    In the UK it comes with a DVD which lets you hear and describes the new noises it will make.
    It doesn't talk about the high pitched sounds from the motor controllers and motors themselves, but i can perhaps only hear them because i'm still young... :D
    I quite like the new noises. :)
