bike rack 2010
Discussion in 'Gen 3 Prius Accessories and Modifications' started by carbon fp, Mar 11, 2010.
  1. carbon fp
    carbon fp New Member
    Atlanta
    Has anyone used The Hollywood Racks trunk mounted bike rack for a 2010? I'd like to avoid the time and expense of installing a hitch, but don't want to scratch my car.
  2. Much More Better
    Much More Better Active Member
    655
    163
    Do the hitch. I find the trunk mount ones are a pain to setup each time and the stability questionable. Then there's the paint scuffing issue and the inability to open the hatch once mounted. Do it once. Do it right.
    I have a Thule rack. One bolt and an impact driver makes it a breeze to take on and off.
  3. The Ericsons
    The Ericsons New Member
    59
    Illinois
    Much More Better - What receiver are you using for your bike rack? We've been trying to find one for our 2010. Used one on the 2005 from Coastal, but they don't have one for the Gen III. So far, we've only found 1 1/4" and really don't want to use an adapter that would accept our 2" rack as it would put the bikes out further in the back, right?
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Check out these threads:
    http://priuschat.com/forums/gen-iii...fications/72862-hitch-receiver-bike-rack.html
    http://priuschat.com/forums/gen-iii...-2-trailer-hitch-2010-available-anywhere.html
    http://priuschat.com/forums/gen-iii...s-modifications/65328-bike-racks-gen-iii.html
    http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/67537-bike-racks.html
  5. Much More Better
    655
    163
    I don't have it yet but I will be getting a Curt 1 1/4". My experience with hitch mounted bike racks vs trunk mount is from my Accord. My Thule rack is a 1 1/4" with a sleeve that fits over the stem for 2" receivers. But in your case, it does sound like the adapter would stick the rack out the back even more.
    I too can't find a 2" receiver for the 2010 P.
  6. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Perhaps with a trunk, but Prius has a very different back end.
    It only takes me a minute to connect mine. Once you've adjusted legs, there's nothing to do again but tighten the straps.
    Prius also offers extra stability only possible with a hatchback, no question about that. You can tie down directly to the hatch footings.
  7. KenzoTH
    KenzoTH Member
    70
    Rhode Island
    I have a Curt receiver on my 2010 prius and am using a Kuat 2 bike "Beta" model rack. Go with a receiver and hitchmount and keep the rack off your car body. I use a Thule roof rack on my '05 Camry along with a hitch to carry 6 bikes when needed, but wanted to stay more aero with the Prius and NOT scratch the roof- which will always happen!
    Check out Kuat racks. They are also LIGHT! Mine is 10 lbs! By comparison my Thule Roadway hitchmount 4 bike rack is about 40 lbs!. The Kuat is heat-treated aluminum- the Thule is steel. The upscale 3 bike Kuat "Alpha" model also come in white.
  8. Much More Better
    655
    163
    Hey man, nice rack. If I didn't already have a Thule I'd get one of these. Thanks for sharing.
  9. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    I installed a 1-1/4" Hidden Hitch last weekend. It went on in about 45 minutes - mostly because I did it alone.
    We also picked up a Swagman XTC-2 bike rack. I wanted a platform-type rack because our top tubes are not parallel to the ground. It makes mounting the bikes less of a hassle. Since we have fenders on the bikes, I wanted one with a top tube clamp instead of a wheel clamp. The Swagman seems to have fit the bill.
  10. rjsmit1
    rjsmit1 New Member
    17
    Ashburn VA
    I installed the Curt receiver one evening. If you have a nice carbon framed bike that you do not want damaged by the rack, consider a 1Up USA quick rack. It does not touch your frame. The rack only contacts the bike's tires and with its all aluminum construction, rust is not an issue and it weighs less, too. The rack is fast and easy to attach to the receiver on your car and it is very easy to quickly load a bike on the rack. It is secure - I have driven many miles with my Cervelo RS on the back and have not worried about the bike. The rack is not cheap, but is is well engineered and well made. (I have no affiliation with 1Up USA other than as a very satisfied customer.)
  11. KenzoTH
    KenzoTH Member
    70
    Rhode Island
    Hi rjsmit1,
    What is the weight on a single bike carrier? The site says 22, then 17 lbs... I assume the 17 lbs is for a single carrier? Is this accurate? I also have carbon bikes, and may opt to use this carrier. Do you have any issues with wheel rims getting scratched by the upright arms? Thanks for the referral!
  12. bac
    bac Active Member
    863
    52
    Pennsylvania
    Ditto!
    -Brad
  13. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
