HID auto level warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pzer0, Mar 15, 2010.
  1. pzer0
    pzer0 Junior Member
    30
    Portland, OR
    On my way to work this morning, the master warning light came on. I have an 05 Prius with 87k miles. The icon on the MFD indicates a failure in the auto leveling sensor. Dealer is quoting me $636 to replace, which seems unreasonable to me. I should note that this is not a Toyota dealership, but it is the dealership where I purchased the car. I have had the car for just slightly more than 30 days.
    I have found the DIY guide for repairing the sensor myself, and am not opposed to doing so if need be, but $636 seems like a ripoff.
    I've read that you can buy replacement units from Lexus vehicles. Do these mount and connect properly, or does it takesome work to get them to function?
  2. pzer0
    pzer0 Junior Member
    30
    Portland, OR
    Thanks for the link, Jimbo! I'm gonna try fixing tonight, if that doesn't work I'll just buy that one.
  3. Politburo
    Politburo Active Member
    971
    208
    I don't think that's the sensor. I believe the sensor is located on the rear axle.
  4. pzer0
    pzer0 Junior Member
    30
    Portland, OR
    Just wanted to give a quick update... I was able to fix the sensor last night by replacing two springs from a ballpoint pen (the originals were rusted and corroded). Hooked everything back up and it seems to be working.
    A few ?s for clarification:
    is the mechanical arm that attaches to the sensor supposed to be that tight? I could barely move the darn thing.
    How can I tell if the HID beams are in the right position? I definitely see a difference compared to before, and if anything it almost seems like they're TOO high now. I don't want to blind anyone! I'd love something like a "take empty prius parked x feet from wall and top of light beam should be x feet high" kind of thing.
  5. Patrick Wong
    18,214
    6,531
    See the fourth and fifth pages of attached for headlight aim specs.
  6. pzer0
    pzer0 Junior Member
    30
    Portland, OR
    Awesome... Thanks!
  7. johnjamis
    johnjamis Junior Member
    79
    KY
    I did this repair several months ago and my "mechanical arm" was very tight. I tried to loosen it up with lube and repetitive motion, but it remained tight. I think it is supposed to be tight.
