Part Identification
Discussion in 'Gen 2 Prius Technical Discussion' started by KayakerNC, Mar 14, 2010.
  1. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    What is the canister located in front of the driver's side front wheel on my 2008 Prius?
    Appears to be damaged in my recent meeting (crash) with another vehicle that blew through a stop sign.
    :help:
  2. Patrick Wong
    18,210
    6,511
    That is the coolant heat recovery system canister. Its function is to store hot engine coolant. The hot coolant is pumped into the engine upon cold startup, to speed up the engine reaching operating temps. This reduces exhaust emissions during the warmup period.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
    That is the coolant reservoir for the hot coolant recovery system.
    Hobbit has a photo in his training files:
    Prius tech training
  4. KayakerNC
    KayakerNC Member
    399
    Yep. That's it. Thanks a lot.
    Mine looks a little worse for wear.
  5. jelloslug
    jelloslug It buffed right out!
    813
    55
    Greenville, SC
    They are just over $1000 from Toyota and they usually go for about $300 on ebay.
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    For real? For a thermo bottle? What is the keyword or part number can I search with? Not having luck.
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    Toyota makes a really good thermos bottle. I wonder if its lined with platinum?
  8. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
  9. KayakerNC
    KayakerNC Member
    399
    Certainly looks like the repair estimate is going to be big bucks.
    The other driver was cited for a stop sign violation and excessive speed. Amazing how many "Advertisements For Legal Services' I've received in the last few days.
    I miss my Prius, though.
  10. KayakerNC
    KayakerNC Member
    399
    My poor Prius was a Total.
    I picked up my new 2010 Package III yesterday, seems to be peppier and the seats are certainly more comfortable.
    So far, so good.
  11. dogfriend
    7,512
    1,190
    Carmichael, CA
    Better luck with the new one. ;)
