internal failure at the skid control ECU
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sosmans, Mar 15, 2010.
  1. sosmans
    sosmans New Member
    NA
    Hello,
    I am assuming i am not the first one to report this issue.
    but last week my prius 2004, 89000 miles, started with the brake light, ABS and warning light on nd rmained so afterwards.
    I took it in for a diagnostic test with toyota.
    the codes read C1311, C1377. as an internal failure at the skid control ECU.
    they quoted parts and labor for $2625.
    I figure thats an outrageous amount.
    so i have the part number 89540-47130 and the diagrams of the components. Has anybody tried to put a newer version of ecu in an older prius.
    For example purchasing a used one from a 2007 prius....I understand that some software updates and the like needs to occur.
    I read in the forum in which some vsc issues were fixed by battery unplugging v12, and other simple tasks.
    During the diagnostic was the codes reset or was the problem really minor. It no longer shows up but i am wondering if this a fake fix or the issues really does not exist.
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Check all the "ABS MAIN" fuses. Then the ABS relays [there are
    four, I think -- two for main ECU power and two for the pump
    motor]. Make sure your 12V is solid before beginning any of
    this, of course.
    _H*
  3. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    1377 is capacitor malfunction.
    This could be a good test vehicle of the braking backup mechanism. Do you still have hydraulic braking capability ?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    Let me put starts and asterixes and exlamation points on this post. If you 12v is the original one it is likely at the very end of it's expected life. And check the fuses that Hobbit mentioned.
    While it might be the ECU failure it may also be a false error report due to a low 12v battery--a frequent occurance in Priuses the age of your vehicle.
    You could have the 12v tested to determine if it may have reached and unacceptably low voltage to confirm.
  5. sosmans
    sosmans New Member
    NA
    yes and i started driving as normal. It does not feel any different than before. But i hope i am not wrong. so i am thinking that some fuses must have been replaced and the ecu failure may have resulted from that. i will have further things in a day or two.
  6. richard schumacher
    7,663
    1,040
    United States
  7. gfshay
    gfshay New Member
    ca
    2005 Prius 69,000 miles. Red triangle warning light. They say I need a new ECU skid control for $2200.
    Anyone able to get toyota to pitch in on the cost or cover under warranty? They say it is out of warranty.
  8. Patrick Wong
    18,200
    6,479
    What DTC was logged? Any driveability issues or warning lights on besides the master warning light?
  9. gfshay
    gfshay New Member
    ca
    "multiple trouble codes
    hybrid control b2799, u0129, cruise control u0129,abs/vsc/trac c1300,c1310/ emps u0121/ a/c b1421/ immobilizer b21794/ gateway b1200,b1207,b1271. traced found no communication to skid control ecu. recommend replace ecu"
    That's what the invoice said. Sounds like ECU needs to be replaced on many of the 2005
  10. Patrick Wong
    18,200
    6,479
    Thanks for the details, diagnosis seems plausible. If you can DIY maybe you could buy a salvage unit.
  11. gfshay
    gfshay New Member
    ca
    what is diy?
  12. gfshay
    gfshay New Member
    ca
    Toyota national asked if I wanted to go to arbitration
  13. Patrick Wong
    18,200
    6,479
    do-it-yourself
  14. tam85
    tam85 New Member
    illinois
    I
    diy means.. you can do it by yourself without bringing it to the car repair station..
  15. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    Get in touch with Steve Woodruff at <[email protected]>
    He may be able to get you a used one. He could also possibly test yours if you remove it and send it to him. If you can't remove it yourself, you could bring it to your local garage to have it removed, and the replacement installed. Off course, if you are in the bay area, you could bring it to Lucious Garage www.lusciousgarage.com/ they should be much less expensive then the dealer.
  16. Mark_
    Mark_ New Member
    New Zealand
    You are not the only one - I too have experienced this - read my post for further info (search on Skid Control ECU under GII forum)
  17. Fbpk
    Fbpk New Member
    London
    Hi
    My 2005 T4 prius has got a problem and error codes are C1313 AND C1373 and car will require a new skid control ecu and part number is
    T89540-47120
    Problem is Toyota Dealer in London are asking 1900£ for this repair though I bought this car in 4500£ 7 months ago. I can not see this part anywhere on internet available either new or used. Can I get some help please.
  18. Fbpk
    Fbpk New Member
    London
    Unfortunately installing other skid unit dint work, toyota gemca asked me that MAY be skid unit ecu I provided was not functioning alright as they dont have any way to check whether its working or not. Then they said.. May be its because of some problem in Wires to gear box OR something wrong with Skid unit relay. To figure this out I need to pay cost of 4-5 hours of labor @ 130£ per hour...one more interesting thing,they said Even if they would have used the New part and it dint work, I had to pay 1900£ still. Now they suggested me to try Relay change first, then wiring, then going for a BRAND NEW skid unit. I am really confused and frustrated as I have spent 320£ with No results at all.
    I went through other forum and followed the procedure to check battery at Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    and found problem in my battery.
    This problem started when I left my car unattended for a month in November to Dec in London and temp was very low. Battery was flat when I returned and I jump started it instead of changing the battery.
    Results for battery are
    1- Battery 11.9v , IG off
    2-Battery 11.3v, IG on
    3-Battery 14.1v, IG on, PKB ON.
    Any suggestions please?
  19. Patrick Wong
    18,200
    6,479
    Start by replacing the 12V battery to ensure that all ECUs have a source of reliable power upon start-up. I agree with the suggestion that you should replace the relay next.
    You may end up spending much more than 320£ before you are done, as the skid control system is not easy to figure out and the dealer tech will rely upon parts swapping at your expense, to see what works.
    dave77 and PriusGuy32 like this.
