2006 Prius - Broken AC compressor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by generalenthu, May 16, 2009.
  1. generalenthu
    generalenthu New Member
    stafford, VA
    My Prius is just under 3 years old and has 52K miles on it. The AC stopped working and I took it in to the local Toyota Dealer.
    The dealer says the Compressor is broken and scared the Bejesus out of me that the AC is also used to cool the battery and non-functional AC can potential short the battery causing a fire.
    Further, I was told that the compressor will cause the Hybrid Synergy Drive system to break if it jams.
    The bottom-line is the dealer says I need to plonk down $1800 immediately to get it fixed.
    Is this possible that the dealer is taking me for a ride? I searched the forums, but couldn't find any instances of broken compressor.
    Please help.
  2. generalenthu
    stafford, VA
    The dealer says that the AC can turn on automatically to cool the battery even if I turn it off manually from climate control system.
  3. ibmindless
    ibmindless Member
    206
    Go to another dealer.
  4. generalenthu
    stafford, VA
    Other dealerships are closed for the weekend. Anyways, called the Toyota Satisfaction line and asked for a goodwill warranty extension as it was still <3 yrs. They opened a case file and said an officer will contact me on monday. Fingers crossed.
  5. dogfriend
    7,512
    1,191
    Carmichael, CA
  6. richard schumacher
    7,683
    1,066
    United States
    Don't reward that dealer with your business. You can safely wait a week without A/C.
  7. generalenthu
    stafford, VA
    Thanks Dogfriend. I did come across this link. I think I will wait till I hear back from the Toyota HQ. More importantly I will have to find a good local repair shop who can handle this kind of job.
  8. generalenthu
    stafford, VA
    Just to update everyone, The Toyota Customer satisfaction reps have been AWESOME. Among the nicest ones I have talked to on phone.
    They offered to pay me for the compressor which ran about $ 1060. But the service charge is still around $600, for which I will have to still pay for my pocket :(
  9. macmfrank
    macmfrank New Member
    I just had the same diagnosis (bad compressor) on my 2004 with 78k. Quote was $1300. Where (dealer vs. other) did you end up getting it fixed and how much?
    Thanks - Mike
  10. richard schumacher
    7,683
    1,066
    United States
    Mike, did the A/C ever get any service before this, specifically a recharge?
  11. macmfrank
    Well, not really. I noticed over the past 1.5 years that the AC would intermittently not cool (10-20% of the time). This summer it stopped cooling and I heard the whining sound. I attempted to recharge myself, but I put in too much. However, service said that this was not the cause of the compressor failure. No other AC service to the car since I have owned it (45k).
    Thanks.
  12. Sequestre
    Sequestre TLV (Toyota Loyalist Veteran)
    Greensboro, NC
    Wow, I can't believe a dealer would say this. It's not true. If anything, the compressor can really suck down the battery as it is powered not by the ICE, but by the electric inverter. In gen 1 the compressor is powered by the ICE (belt drive) but still not used to cool the battery.
  13. richard schumacher
    7,683
    1,066
    United States
    Well, it's *partly* true: the traction battery and its controller are cooled by cabin air, so if the cabin A/C is not working the battery system will not get as much cooling as it may need on a hot day. But the battery system won't turn on the A/C by itself.
  14. jimnvicki
    jimnvicki New Member
    Redlands, California
    My wife's 06 A/C compressor is making that high pitched whining sound too, and it isnt blowing cool air any more. I isolated the high pitched whining sound to the a/c compressor and tried to recharge it to no avail. Never had any other issues with it before now, but of course, its the beginning of another southern california summer. The car has 200k on it so I guess it's about time it needed a bit of TLC. I priced out an electric compressor @$771 and I dont have any qualms about installing it myself, but I would appreciate anyone's tips and tricks about the install. Also, does anyone think its a bad idea to try to obtain a used one? Thanks
  15. richard schumacher
    7,683
    1,066
    United States
    The one thing I know is: use the correct Toyota refrigerant oil. The compressor motor wires are bathed in it, and the wrong stuff will destroy them.
  16. dogfriend
    7,512
    1,191
    Carmichael, CA
    Yes, there are numerous warnings in the service manual - the wrong oil can degrade the electrical resistance (insulation) and cause a DTC - if that occurs, you will need to replace all of the affected parts of the system - $$$$$
  17. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    Just make sure you use hybrid oil, the autostores now sell it. I posted this earlier. Also, you need to make sure your hose is new, or was not used with normal refrigerant oil, as it will contaminate the compressor. You also need a vacuum pump.
    I recharged and filled mine. You will need 16 oz of R-134.
