Iphone 3G + 2007 prius = ???
Discussion in 'Gen 2 Prius Audio and Electronics' started by friedrichs, Mar 17, 2010.
  1. friedrichs
    friedrichs New Member
    Tx
    i recently got a 2007 prius and have heard that you can connect the iphone 3g and 3gs to it through bluetooth and have it play music, but i cant seem to figure out how. If anyone know plz leave a comment or has any suggestions for wireless audio.
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    You cannot, AFAIK. Even w/the nav system, the Bluetooth support in the 2nd gen Prius (04 to 09) doesn't support A2DP music streaming. That got added on the 2010 Priuses (w/Bluetooth) and some Priuschat members are doing it w/theirs.
    I've personally gotten it working w/my iPhone 3G thru various BT headphones and a Lexus HS 250h.
  3. RudeBoiM3
    RudeBoiM3 Do it once, Do it Right!
    36
    Apex, NC
    i have an 07 prius and using a 3gs... just get an aux input cable to listen to music. use bluetooth for calls only.
  4. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    What happens if you're listening to music from your iPhone through the Aux port and a call comes in?
  5. Feliciasnh
    Feliciasnh Happy Prius Driver
    Massachusetts
    The music shuts off and the screen flips over to telephone mode, in my experience.
  6. zenMachine
    3,355
    300
    the phone's screen, or the MFD, or both?
  7. ursle
    ursle Gas miser
    1,049
    192
    NH
    I notice the Iphone has a 160k maximum output for mp3 music while the Ipod has a 320kbit maximum, MP3 is bad enough but to cut the possible bit rate in half, well ymmv
    True you need the dice interface to run the Ipod or Iphone (gen2) but still...
    Right, the op is asking about bluetooth, worse yet:eek:
  8. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Where'd you find that spec? I'd not heard that before.
    - D
  9. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    I believe both. (I don't use my iPhone for listening to music much, capacity is too limited. I use my iPod for that.)
    IIRC, iPhone should suspend the current song and the car's MFD should go to the ringing screen.
  10. Feliciasnh
    Massachusetts
    Yes, what cwerdna said :rolleyes:
  11. zenMachine
    3,355
    300
    Got it. Thanks.
    Speaking of iPhone capacity, using iTunes' Smart Playlist feature would reduce the need to replicate your entire library onto the phone. You get a new playlist automatically every time you sync up. Pretty powerful and cool.
  12. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    SPLs
    I'm well aware of smart playlists, have over 2 dozen of them and have been using them since my 4th gen click wheel iPod. I sync 1 SPL w/my iPhone 3G which syncs a VERY tiny subset of my music (my top rated songs).
    My iPhone 3G is only 8 gigs and I reserve most of its space for videos since it's a better video player due to larger screen than my 6th gen 80 gig iPod Classic.
    My music collection is 13 gigs and my podcasts are 11 gigs. Neither will fit on my 8 gig iPhone 3G.
