Leaving for 3 weeks- any ideas?
Discussion in 'Gen 2 Prius Main Forum' started by seasidetraveler, Jul 28, 2005.
  1. seasidetraveler
    662
    CA
    Hi all!
    I am leaving the states for 3 weeks, and I will be leaving my Prius at home. Is it going to be bad on the car to sit that long? Should I have someone come over and drive it? Anything I need to do to it while it sits?
    THANKS
    PS- I just read about the STORAGE DRAWER on the center console- I was so excited to discover that! HAHA
  2. PaPrius
    PaPrius Member
    132
    I recently returned from a two-week vacation, and the car acted as though I had never left (i.e., it worked fine).
    The only thing I did was shut off the SKS before I departed. The SKS does drain power from the battery, and if you'll be gone for three weeks you should shut off the SKS.
    There is a small button under the dash near the base of the steering wheel (where it meets the bottom of the dash) If you push the button, you'll be shutting off the SKS. (I forget if the goal is to have the button pop out, or depressed; the manual will clarify this).
    Enjoy your time away. In my case, I had so much fun on my vacation that the Prius was about the only reason I was looking forward to coming home.
  3. Kurt
    Kurt New Member
    If you have the "Smart Key System" aka Keyless Entry, you should push the button below the steering column to turn that function off. Other than that just leave it alone, it will be fine.
  4. seasidetraveler
    662
    CA
    Thank you- I figured I would push that button, I had heard something about that before. It is good to hear that yours started just fine!
    I cannot wait for my big trip- I am going to AUS- so that will be fun, PLUS there are Prius' there!
  5. Smooth Operator
    172
    Cowichan Bay, BC Canada
    I left mine in the garage for over a month last October/November. I just turned the smart start off.
    It started first time when I returned.
  6. seasidetraveler
    662
    CA
    So when I return, do I use the little miniature key to open the door?
  7. PaPrius
    PaPrius Member
    132
    I guess the miniature key would work, though I've never tried it.
    I used the remote to unlock the door, turned the SKS on, and then started the car like I normally do.
  8. seasidetraveler
    662
    CA
    Oh so it doesn't disable the remote... Okie dokie! That helps
