Prius window tint
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Superdrol, Mar 20, 2010.
  1. Superdrol
    Superdrol Member
    399
    32
    I'm getting 17% window tint all the way around the car next week. 5% brow on the windshield. Does anyone know what the window tint grade is on the thin glass under the rear spoiler.
    I'm worried 17% might not be dark enough. The lowest is 5%. Any recommendations or pics of your guys cars so I can compare ? Thanks.
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In Ohio, darkness of tint is measured by visible light allowed in through the combination of film and the window.
    Non-reflective tint is allowed on the top 5 inches of the windshield.
    Front Side Windows must allow more than 50% of light in.
    Back Side Windows and Rear Window, any darkness can be used.
    Front and Rear Side Windows must not be more reflective than a standard window.
    [​IMG]Manufacturers of film need to certify the film they sell in the state. The sticker to identify legal tinting is required between the film & glass on each tinted window.
  3. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    17% really? That's pretty dark. I don't think you should be worried about it being too light.
  4. yamisoshi
    yamisoshi Junior Member
    64
    Meridian, ID
    I got mine tinted few weeks ago and this is what it looks like. I have the 3M 20% window tint on all windows with a small banner on front windshield. Where I live, the darkest we are allowed to go is at 35%.
    The picture is a bit hard to tell, but I'll try to take better pictures so you can see what 20% looks like. :)
  5. Much More Better
    Much More Better Active Member
    655
    163
    That means your tint is illegal, no?
  6. yamisoshi
    64
    Meridian, ID
    If the dealer sells it, I don't consider it "illegal" ;)
  7. halfmoonray
    halfmoonray New Member
    74
    I got 50% ceramic all the way around including on all of the front windshield. Can still see through all of the windows but blocking the front makes the 50% look darker. Big difference in heat rejection from the front being tinted too.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    My civic is 20% all around, and I find it too light in the direct sun sometimes. Yes it is illegal, but who cares. You may have to sign a "show car only release" form of some type.
  9. Superdrol
    Superdrol Member
    399
    32
    Yeah I know about the Ohio tint law. My car has a licence plate from Ohio but I started working in Indiana so I'll have to update. Indiana is 35% all the way around. 17% is illegal in both states. Ohio I'd probably get a ticket Indiana is pretty liberal about it. I had 35% all around in Ohio and did not get a ticket for it. If you have 5% in Indiana you may get a ticket for it, 17% probably not tho bc you can still see inside.
    The 35% I had before in my corolla and it really was not dark enough for me. If I could I'd get 5% all around then 35% on the windshield.
  10. Superdrol
    Superdrol Member
    399
    32
    Yamoshi could you post more pics ? My car will probably wind up looking similar. 17,20% it's basically the same percentage all the same. Atleast it will match the stock tint. The little thin window on the trunk is 35% I believe.
  11. yamisoshi
    64
    Meridian, ID
    Here are more perspectives. I also tinted the little window in the back hatch. With the original factory tint, the color is a little different (looking from inside out)
  12. Superdrol
    Superdrol Member
    399
    32
    Nice. Did you tint the little window 20% as well ? That color looks nice with the tint. Is it cloudy outside ? I noticed if it is not sunny outside it looks much darker.
  13. yamisoshi
    64
    Meridian, ID
    Yeah, I tinted the little window as well. Since it had a factory tint to it, from the inside, it looks brown (weird). There were high-clouds this morning, so yeah, it appears darker. Even in sun light it still looks dark. I love it. Especially the dark gray interior makes it appear darker as well. Well worth it getting 20%.
  14. CHIZELD
    CHIZELD New Member
    64
    @ Your Lady's House
    Hey yamisoshi, i got the same ride and color and set up as you, lol. I just got the lightest tint (idk the %age) all the way around. I didn't tint the little back window though, and yeah, the colors are different:mad:. Planning on gettin some new rims once i save up, not too sure if i'm goin 17's or 18's
  15. SDM44
    SDM44 SeƱor Member
    199
    Los Angeles
    IMO, since the Prius is a 'glass house' and allows a lot of light into the interior, 20% all around (nothing on the windshield) looks good and it's not too dark, but also not too light, depending on the sun or light above you.
    I've seen a Prius with 15% (or 17% if you will, basically the same thing) and it's extremely dark looking. You can't even make out the silhouette of somebody behind the glass, where as on a 20% tint you can. The 5% difference does make a difference there, but the best thing would be to see the car for yourself in person if you could.
  16. Superdrol
    Superdrol Member
    399
    32
    I'll be getting the 17%, plus a 5% brow. I'd really prefer 5%, but I know I'll get pulled over.
    I can still see inside 17% without too much difficulty but not with 5%.
    5% you cannot see anything even in bright sunlight unlike 17% so that's asking to get pulled over. With the lower you go it makes a big difference, like 35% to 20% to 15%, etc......even small percentage changes in darkness on the lower end really show.
  17. yamisoshi
    64
    Meridian, ID
    Thanks. I'm considering 17's myself. :D
  18. yamisoshi
    64
    Meridian, ID
    Prior to the Prius, I had a Civic with the same 20% window tint. It looked way darker from outside and inside. However, like you said, the Prius is a 'glass house' that makes it a bit brighter. Still, no regrets. I have a lifetime warranty on the tint, so a better trade off than getting something darker and no warranty.
  19. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    I would suggest getting the whole front windshield tinted. I'm glad I did. Not for color - you can barely see it - but for heat and UV protection for the dash. But then I live in Los Angeles so the sun is brutal here.
    Also, before you get your little back window tinted have them hold up the film to the window, or slap it on quickly with whatever they use so that you can look out while sitting in the car. As others have mentioned, it comes with a different tint than the big rear window, why, I don't know!
    I had mine done then didn't like it because it was a worse match than leaving it untinted and had them take it off. So I spent $20 for nothing.
  20. going red baby!
    610
    96
    Los Angeles
    Also, before you get your little back window tinted have them hold up the film to the window, or slap it on quickly with whatever they use so that you can look out while sitting in the car. As others have mentioned, the Prius' little window comes with a different tint than the big rear window, why, I don't know!
    I had mine done then didn't like it because it was a worse match than leaving it untinted and had them take it off. Plus it was too dark and made it harder to see headlights behind me. So I spent $20 for nothing.
