Musty AC Smell in 2010 Model?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KJR, Aug 3, 2009.
  1. KJR
    KJR New Member
    On of my major gripes about my 2008 GenII Prius is the musty smell after you had the AC on and then you need to run the ventilation without AC. Does this occur on the 2010 model?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    This applies to EVERY car on the planet with AC!!!
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Don't keep it in recirc all the time.
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Yes it does, and most have service bulletins on how to deal with it. Usually it is due to mold growing on the evaporator coil and ther is usually a proscess to clean it. At least you don't have legionares diease
  5. KK6PD
    4,003
    944
    118
    I don't even have mold, I vent before I get home, dries the pumbing right out. But then I live in a desert! Somebdy in Florida is not going to achieve the same results as I do!
    That being said, I also agree it's sad when that's the best fix, this side of Lysol!!! Moisture, and A/C go hand in hand...it takes lots of time and money to violate the laws of physics!!!
  6. KJR
    KJR New Member
    I have never had a molding smell issue with any car I've owned until this Prius. I leave my 2003 Honda Element with it's air on an there is a hugh puddle underneath it as the condensation drains off. If I turn the air off and let the fans pull in outside air there is no musty smell. If I start the car in the morning and there is a slight mustiness for about a minute. It's hardly noticeable.
    With my 2008 Prius I can be driving down the road with the AC not in recirculation then turn off the AC to only have fresh air and the musty smell comes through strong and it will last for quite a few miles. After not using the AC for about 1/2 an hour it goes away. Why does the musty smell go away when the AC comes on then comes back when it cycles off? The Pruis doesn't drain as much condensation as other cars.
    I've reported it to the dealership but they report the drain is clear. They sprayed in the vents but it didn't last long. They say this is not a "common" problem yet there are many posts on this site about the problem. I don't think the dealer can fix the problem and Toyota doesn't recognize the issue to issue a recall.
  7. a64pilot
    771
    62
    Albany Ga.
    Usually there is a service bulletin that explains to the dealer exactly how to clean the evaporator and which cleaner to use, and honestly Lysol is sometimes as good. There is also some form of chemical that "boils" as it is applied to the evaporator coil. Any HVAC service person will know what I'm talking about.
    I bet your evaporator has mold growing on it, and that may not be healthy either. It is very common down here in south GA and North Fl., almost certainly because of the humidity
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The Prius A/C is a variable speed electric compressor. Its on almost all the time. In comparison, a regular automotive compressor frequently cycles, with a magnetic clutch in the hub
    It could be the evaporator coil being always wet has something to do with the smell issue in Prius A/C, as my Prius developed a nasty funk after several summers.
    I managed to "borrow" an expensive fiber optic inspection tool off work, drilled a few pilot holes in the case, then a couple of 1/2 holes facing the e-coil
    I used the following EPA certified chemicals, from Nu Calgon
    Nu-Calgon: Products: IAQ Assurance Program
    Neither product requires rinsing. Unlike Lysol, both products are specifically formulated and approved for common e-coil construction (Aluminum fins, copper tubing, plastic case, etc).
    Never, ever use something like household bleach on a house or car e-coil. Although the bleach will absolutely eradicate whatever is growing in your e-coil, it will also destroy the e-coil in the process
  9. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    I've had this problem in other cars. A quick google search of (no I'm not kidding) "air conditioner smells like feet" gave me a lot of ideas. The one that worked was spraying an entire can of lysol into the air vents. Also it's a good idea to turn the AC off about 90 seconds before you park, this keeps condensation from building up and saves energy, as you don't need the compressor to maintain cold air for the last minute and a half.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    One cup of EvapFresh, sprayed on the e-coil, will work far better than, and last much longer than Lysol. It won't leave behind a Lysol stink either
  11. Coby
    Coby Junior Member
    Could you elaborate:
    1. How do you get to the evaporator coil? (from the filter side -- cabin?)
    2. How do you apply "One cup of EvapFresh"?
    Thanks.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Jays right but its difficult to get to the e-coil to spray it.
    The official dealer fix is they have a spray can of foaming cleaner with a special applicator tip. You jam that can into the e-coil rubber drain hose. That hose can be seen right behind the pass front wheel about 2 feet in. You spray the entire can contents up in there. The foamy cleaner soaks the e-coil and cleans it. It changes from foam to liquid and leaks back out. It kills the mold and the smell. Works real good. My dealer offers the service free up to the first 5000 miles. After thats its $100.
    The can, actually 2 cans sell for $25 over the dealer parts counter.
    Comes with the rubber hose attachment.The other can is just perfume that gets sprayed into the front air dam. Pretty intense perfume. I will skip that next time.
    This treatment lasts about 2 years.
    I did mine about 2 years ago and its starting to smell a little again. Turning on the heater with the wicked cold we had this winter has made it worse.
    Here's the deal on preventing the smell. As a previous poster said you must allow the condensate to drain out after a drive. Always use recirc as it filters the air in the cabin and keeps dust out of the car. But about a mile or two before arriving at your destination turn the air off and change form recirc to fresh air to let the e-coil dry out. When you park always leave it in fresh air to vent it.
    If you park the car with a soaked e-coil it will quickly become mold.
    Now this recirc/fresh air procedure only works if you have not contaminated the e-coil already.
    If you have the smell already its to late. You must get rid of the smell using the foamy cleaner that actually cleanses the mold. Then do the fesh air procedure and you'll be good for a few years.
    Spraying anything in the vents does nothing. The vents aren't the issue.
  13. KK6PD
    4,003
    944
    118
    First off..+1 Good Post!
    The right answer!!
    Question however, where does the foam that turns into a liquid run down and drip on when it's done killing mold and gravity takes over??
    How do you recover the leftovers cleanly?
    Serious question, I need to take care of the wifes car, but she wants no mess afterwards!!!
  14. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    I always drive with AC on and never had troubles (even in winter).
  15. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    My Prius is 10 months old and no odor issue.
    My previous car (BMW 545i) had the issue on and off after about a year (it's a very common issue with BMWs), and following advice on a BMW forum, I purchased Wurth A/C & Heating System Treatment, and didn't have the issue after that:
    Wurth A/C & Heating System Treatment 6 oz.
  16. Tarhead
    Tarhead Junior Member
    North Carolina
    The residual gradue drains back out the condensate drain. I've not done it on a Prius but on previous cars. It will gross you out and may require a piece of stiff wire with a hook to unclog the black slime from the drain.
  17. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Exactly.. the foam drains back out the same tube. I have been lucky so far and no nastyness dripping out. Just white liquid.
    I just bought a set of cans yesterday. $24.50 out the door for the 2 cans. It rained all weeked here so I'll catch it next week.
    Don't think I'll use the second can as its just really strong perfume.
    But its sold as a kit as there shrink wrapped together.
    Couldn't drive the car for about 1/2 hour after the perfume treatment but the cleaner works great. It lasts almost 2 years if you don't forget to vent before you stop. That venting procedure works!!! But won't help if your already stinking.
    I did the my house e-coil a while ago too. Man, was it overdue.
    House smells 100% better. Thats a big job too but worth it.
    Mold in your house ac can make you really sick, and at the least make your sinuses go crazy.
    Home Depot doesn't sell the e-coil cleaner anymore. Just a spray can to do the outside condenser. I went to a AC supply warehouse and bought a gallon of anti-microdial e-coil cleaner ands went at it
    using a new bug spray pump up bottle.
    Home Depot does sell this though:
    Coating Filter Charger by Web Products Inc - More Furnace filters at doitbest.com
    This product works really good. It enhances the capture quality of a disposable filter. I use it on my home filters and the cabin filter of my 2007 prius. Has a real nice lemon scent too.
