Detroit Free Press: Are cosmic rays really causing Toyota's woes?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by a1a1a1, Mar 23, 2010.
  1. a1a1a1
    a1a1a1 Member
    144
    So Cal
    In this NHTSA advisory letter, an anonymous submission is being taken into serious consideration regarding aberrant EMF causing Toyota drive-time failures:
    http://nhthqnwws111.odi.nhtsa.dot.gov/acms/docservlet/Artemis/Public/Pursuits/2010/RQ/INME-RQ10003-39160P.pdf
    "(There is) possibility of cosmic rays disrupting electronics at sea level, essentially flipping a bit from one to zero, or vice versa. This phenomenon is a 'soft' error that is not detectable except through redundant electronic and communication systems. The scientific community refers to such occurrences as 'Single Event Upsets,' or SEUs."
    http://www.freep.com/article/20100316/BUSINESS0104/3160361/1318/Are-cosmic-rays-really-causing-Toyotas-woes
    It could be that automotive electronics need to be shielded or made redundant in the same manner as aviation electronics.
  2. Tom183
    Tom183 New Member
    652
    65
    Maine
    Wait a minute while I get my tinfoil hat...
  3. linuxpenguin
    linuxpenguin Active Member
    352
    182
    Without getting into details, I think it's extremely unlikely for something like this to produce consistent behavior (which would be required for uniformal acceleration). They test these cars under sustained /extreme/ EMI conditions without any noteworthy issues. The vehicle's electronics /are/ heavily shielded for that very reason.
    If cosmic rays were really causing problems, believe me, you'd get DTC codes not any sort of consistent acceleration...
    Toyota Vehicles : Video Library / Toyota
    Andrew
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Cosmic rays are making people dumber by the minutes.
  5. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    In all seriousness, I find it hard to believe that Toyota's engineers built its systems without safeguards at least as good as those used by Ford, Honda, Audi, Chrysler, Nissan, Renault, Kia, etc etc. As good as this all sounds, it doesn't explain the significant difference in complaints between manufacturers and model years. Since they all use similar systems it seems it should be more even.
    NHTSA considers all submissions nowadays. "A Concerned Scientist"? Dr. Anderson, the guy working for the ATAC? Probably.
  6. LeadingEdgeBoomer
    289
    29
    New Mexico
    When I worked at Los Alamos National Lab (at 7000'+ altitude), a supercomputer built with Compaq had many thousands of microprocessors and no memory error correction hardware. Cosmic ray hits can definitely flip a bit in a memory or a processor, but SECDED (single-error correction, double-error detection) parity essentially solves the problem. However, on that scale, the hardware adds measurably to cost. PC vendors don't provide it because profit margins are very small, and no one cares if your browser or email malfunctions once in awhile.
    An IBM report in 1979 considered effects of altitude (increases), shielding (decreases), etc.:
    Effect of Cosmic Rays on Computer Memories -- Ziegler and Lanford 206 (4420): 776 -- Science
    So this is neither new nor speculative.
    See also:
    Cosmic ray - Wikipedia, the free encyclopedia
    and Intel has a patent on a "cosmic ray detector" for every chip:
    www.newscientist.com/blog/technology/2008/03/do-we-need-cosmic-ray-alerts-for.html
  7. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Relatively simple test of the SEU hypothesis: compare rates of unintended acceleration reports per 1000 vehicles between Colorado and Los Angeles. Colorado has significantly higher cosmic ray background levels than at sea level. If there's no higher rate of reports in CO compared to LA (or east coast cities), then the SEU hypothesis is greatly weakened or should be disregarded. Conversely, if the rate is higher in CO, then it should be further investigated.
  8. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    No, I think it's dark matter that's the culprit.
  9. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    And I thought it was gray matter. On top of the head (or in my case, on the side!) and within.
  10. Tom183
    Tom183 New Member
    652
    65
    Maine
    I think you missed my joke - the tinfoil provides shielding (for the 1's and 0's in my head). (otherwise the voices tell me to do ... things...)
  11. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Nope. But some people on here will use any theory to prove Toyota is the fourth member of the Axis of Evil. Oops. I guess Toyota replaced Iraq!
  12. RonH
    RonH Member
    556
    Don't need no fancy ECC memory or redundant computers. A simple background checksum calculation on the flash memory will suffice for fault detection of the code. RAM tests are part of the startup in any embedded system I've seen. Defensive programming is about guarding against much more likely crazy sensors than rogue gamma rays, but are effective against the latter.
    Hope that helps.
  13. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Those cosmic rays are more likely concentrated on Detroit, where they have toasted the U.S. car industry.
  14. DavidA
    2,345
    1,821
    Chicago western burbs
    Some of us got it. Danny has even provided a smilie for it ---> :tinfoil3:
  15. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    I'm not even sure where to buy tinfoil. The aluminum foil hat is really and antenna that transmits your thoughts to the govenmt.
  16. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Oh, so now its not the floor mats, but a steady stream of cosmic rays specifically aimed at that one prius that tells the computer that the pedal is holding steady at wide open throttle.
    Will wonders never cease.
  17. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    Nah. It is your cellular phone that transmits where you are every second or so. From the location information, the government can tell more about you than any tinfoil hat will.
  18. austingreen
    13,672
    4,210
    Austin, TX, USA
    shh. your going to ruin my group photo of people using aluminum hats.
  19. ManualOnly
    ManualOnly New Member
    193
    28
    BINGO! That might explain why Rhonda Smith experienced "divine intervention" when her "possessed" Lexus went amok.
    Shame on you Cosmic Particles! :nono:
