pre 2008 models do not have brake override??
Discussion in 'Gen 2 Prius Main Forum' started by Flying White Dutchman, Mar 20, 2010.
  1. Flying White Dutchman
    4,376
    313
    ok
    i found this video when watching the HOAX runaway prius story.
    and this is a toyota dealer telling that he is not aware of a pre 2008 ( same as new late 2007 model ) that got a brake override?
    anyone that can comment on that .. maybe the toyota team?
    i guess that this info is mistaken and all the models starting december 2003 ( first models on the market ) have this brake override and if not i think ( yes it wil cost toyota money ) this needs to be fixed with a software update next time you visit the dealer for regular maint.
    maybe you need to visit the dealer sooner because waiting for maint. on a prius will take a while..... what is there to do beside change the oil:D
    Nate Riesen
    Jon Lancaster Toyota
    608-243-5551
    [email protected]
  2. qbee42
    3,081
    My 2006 has brake override. I believe all Prius have it.
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    My 2007 also has it.
  4. deh2k
    deh2k New Member
    241
    New Hampshire
    Toyota has said that the engine override feature is an essential component of the Hybrid Synergy Drive, and that all cars with HSD have it. That includes all Prius years and models.
  5. Flying White Dutchman
    4,376
    313
    yes also what i know.
    strange that this toyota dealer is not aware of that!
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Lets just say that the lack of knowledge of some car dealers is unbounded.
  7. Tideland Prius
    16,623
    BS. Our 2005 has it.
  8. Flying White Dutchman
    4,376
    313
    thx all for just confirming it ;-)
  9. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    deh2k really answered this:
    The key is that the Prius does not have a SPECIFIC overide system because the function is inherently provided by the HSD. It is something that has always been there and it is not something that is on the car's feature list or something.
    I tried out this system the other day, floored the car and when I got to 80 I applied the brakes. The ICE stopped and the car slowed down - BUT when I released the brakes (with the gas floored) the car sped back up. From what I understand, with a traditional Brake Override System (on a non-hybrid car) that the engine would have been totally shut down. So what the Prius has is somewhat different.
  10. Flying White Dutchman
    4,376
    313
    lots to be not thats mart to have the ICE shutdown permantly.
    if you take the foot of the brake because you want to speed up again.... you can not because the ice is shutdown.
    its better to have the brake bring the car to a stop and then just turn it off.
    and if for safety i need to give some gas again i can not with a ice shutdown so i prefer the HSD way.
  11. dhancock
    357
    40
    Of course, this assumes that the computers that do all of this always work properly!!:eek:
    What is the protection if HSD goes haywire (and leaves no record that it has):confused:
    An entirely seperate Brake Override would provide a redundant backup - just in case.;)
  12. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    If the HSD computer malfunctions and allows the gasoline engine to rev up to maximum RPMs and continue to run even as you stomp on the brakes to stop the car, it will destroy the transaxle due to the way it's geared (cause the MG1 electric motor in the transaxle to burn out).
    I can't think of a better brake override than a destroyed transaxle.
    If that happens, your Prius WILL come to a stop, PERMANENTLY. And will NOT move again without a new transaxle.
  13. dhancock
    357
    40
    If that is so, then if you try to go 100mph won't the transaxle be destroyed?
    Is not the issue that there are an infinate number of ways that the HSD computer could go wild?
  14. justlurkin
    499
    63
    Long Island, NY
    No. The transaxle won't be destroyed when you are going 100mph, because the gasoline engine is directing its torque towards MG2, which is the outer ring gear that is drivechained to the wheels.
    When you brake MG2 / outer ring gear using the front disc brakes down to very low speeds, it forces a runaway gasoline engine to direct more and more of its power to the center sun gear in the HSD (the MG1 electric motor). Remember the HSD planetary gearset is a DIFFERENTIAL.
    The MG1 electric motor has a safety limit of 10,000 RPM. When the gasoline engine is revving at its maximum 4500 RPM while the car is being hydraulically braked to a stop (MG2/outer ring gear going to 0 RPM), the planetary gearset will direct the full brunt of the gasoline engine's power to MG1, causing it to spin at 16,000 RPM. That's 6,000 RPMs over its safety limit. Burnt-out MG1.
  15. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I believe the brake override only works with WOT, not partial throttle.
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Well it is, if you know nothing about computers.
    Do you have any documents (Ideally not documents by a lawyer trying to extort money from a manufacturer) that back up your claim?
  17. justlurkin
    499
    63
    Long Island, NY
    Not just WOT. The override will kick in anytime MG1 reaches the 10,000-RPM safety limit.
    If MG1 is spinning at 10,000 RPM, two things can be done to bring MG1's RPMs down below 10,000 RPM:
    1) The HSD computer commands the gasoline engine to slow down, or
    2) you release the brakes so the gasoline engine is allowed to send its torque to MG2/outer ring gear/drive wheels rather than to MG1/center sun gear.
  18. dhancock
    357
    40
    Actually, I DO know a bit about computers (and real time software development). That's why I made that statement. However, I don't know much about the HSD controller, but I don;t think that it is exempt from Murphy's law.
    I'm not trying to provoke an argument nor am I trying to promote some conspiracy theory or something - but I do believe that it is possible for "phantom" unintended acceleration to occur. I also believe that once these Toyota problems hit the press that all kinds of nuts come out of the woodwork. But issues with folks that don't know the difference between the accelerator and the brake, and out and out idiots who don't understand the difference between "Park" and "Neutral" are also obscuring real issues.
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I confess that my 20 years in software development were mostly in Inventory and Financial systems. Perhaps Real time controller compilers are more lenient than financial language compilers, (RPG, COBOL, PL/SQL, etc.) but I never felt there were infinite ways to write bad code.
  20. sfvb
    sfvb New Member
    17
    Northern IL
    I'm not sure what you mean by "more lenient". If the code compiles, it is syntactically correct, but that doesn't mean it's good. Also, I would say there are infinite ways to write bad code.
