Trans stuck in Park/Neutral
Discussion in 'Gen 2 Prius Main Forum' started by the artist, Jun 8, 2007.
  1. the artist
    the artist New Member
    Yesterday before the mishap (reported ealier) the TRANSMISSION stuck in Park or Neutral because
    the computer thought the EMERGENCY BRAKE was not released! Although I push it on and off a few times
    while my foot was on the regular brake.
    I turned the engine on/off a few then finally it let me go into reverse or drive..whoo! A chalenging few
    minutes!!!! I called the expert "SALESMAN" who said he never heard of such a thing!
    Thanks for everyones help
  2. qbee42
    3,081
    I have shifted my 2006 into D with the emergency (parking) break on. Has it been changed for 2007?
  3. hschuck
    hschuck Member
    385
    bay city, ca
    To shift out of park or ready you must press and hold the brake (not parking brake) firmly. If in neutral you can shift to any gear. You can drive off with the parking brake on (not recommended).
  4. NoMoShocks
    1,292
    83
    Camas, WA
    I am not saying this is what happened to you, but I have found for myself that I have a tendancy not to wait for the READY light. I tend to push Start and then imediately shift in to Reverse or Drive and it doen't always take. I usually does on the second try, but a few times, the computer has hung up a bit like I am giving it Spastic Mouse Click Syndrome. A few times, I had to ReBoot it by turning OFF and then ON again.
    I am trying to develope the habit of looking for the READY light before I try to shift.
  5. mmoncur
    mmoncur New Member
    32
    Strange - as far as I'm aware the computer doesn't know the parking brake is on. This has annoyed me more than once as I've tried to back the car up after forgetting to release the brake - So much computerization and yet it will happily try to drive with the brake on, without so much as a beep.
  6. the artist
    UPDATE!!! Guys are right! You must hold down the regular brake before starting the car. I guess
    we old guys are use to pushing down on the gas while turning the key B)
  7. naterprius
    naterprius Senior Member
    1,843
    <div class='quotetop'>QUOTE(the artist @ Jun 8 2007, 03:57 PM) [snapback]458312[/snapback]</div>
    Your car was definitely not in READY. Once stuck in Neutral, you have to turn off the "key" and start over.
    Nate
  8. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Thank Audi for the requirement to put your foot on the brake before you can shift out of park. The "unintended acceleration" syndrome of a few years ago. It's actually a good safety addition to "automatic" cars. Makes it harder for small children to take off in a car.
  9. richard schumacher
    7,666
    1,047
    United States
    Do yourself a favor: read the owner's manual. It will teach you other stuff you need to know about the car.
  10. jrenales
    jrenales New Member
    reno nv
    December 12th 2009
    After researching all the post about shift lever going back to neutral from drive or reverse,with regards to prius 2004 to 2008,some people say its the brakes switch others say you have to replace the shifter mechanism $300 plus labor.
    I have come to the conclusion weather makes a big difference above 100° below 30° this has happened to me three times last year and a half, if it's too hot turn air-conditioner for 15 minutes if it's to cold turn on a heater that run for 15 minutes that is my unscientific research and seems to work, maybe the electrical engineers have fixed the problem with the new 09, 10, models with the shift lever. that's all hope this helps
  11. drkenshin
    drkenshin New Member
    This just happened to my 2006 Prius. I could not get it out of Park or neutral. Turned it off and retried about three times with same results. at the time all the dash indicators were lit up, VSC, "brake", trans symbol, tire inflation symbol, etc. It was not a matter of having foor on the brake before turning on since I've had the car for almost 4 years. I called to get a tow, but tried again before the truck came (about an hour later) and it went into gears no problem. Dealer could find nothing wrong. Have there been more reports of this?
  12. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    Those are classic symptoms of a dying 12-volt battery.
    Their service life is about 4 years on average, so you are due for a replacement.
