What are the windshield dots made of?
Discussion in 'Gen 3 Prius Main Forum' started by Rebound, Mar 29, 2010.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I have a 2010 Prius II. The top of the windshield is covered with black dots. I am installing a GPS, and I would like to mount the antenna at the top center of the windshield, above the rear view mirror. Are the black dots made out of a metal or metallic substance that would impede the antenna's operation? Can they be scraped off from the inside with a razor?
    Thanks!
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  3. BBaggins
    BBaggins New Member
    26
    Cornfields of Illinois
    I mounted my GPS unit in the location you mentioned. I used the round mounting disk included with the GPS that has the 3M tape on the back. It sticks so good that I can't get it off so I can move it about 1/2 an inch.
    Dennis
  4. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    What dots? Are you not covering your nose when you sneeze? ;-)
  5. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    We have an EZ-Pass transponder attached there and don't have any problems with it reading the tolls.
  6. Rebound
    3,964
    2,613
    Portland, OR
    Thanks everyone! It's obvious that, in the Prius at least, the black dots are a sun shade. They don't border the windshield, they're only in the area of the rear view mirror, where the sun visors don't reach. Ingenious.
  7. ajc
    ajc Member
    340
    pa
    Ingenious? :confused: those cheap bastards at Toyota did not put a tint strip across the top of the windshield. The sun blinds you, never had a car without the top tint on the front windshield.
  8. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I thought they were a ceramic compound.
  9. Rebound
    3,964
    2,613
    Portland, OR
    Gripe, gripe, gripe... I keep a pair of sunglasses in the sunglasses holder. Much better than a tint strip.
  10. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I thought ceramic as well but all I found was enamel... Maybe I'll have to google if they are also ceramic
  11. thegreatll
    thegreatll New Member
    oviedo
    Hahahahah, i have to agree here
  12. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    There is a show called"How It's Made", they did auto windshields once. It's either a thin sheet of black or clear or half tone dots on plastic film sandwiched between two sheets of glass. The whole mess is heated and bonded. TADA..Windshield..
    I have also seen paint on surface, but the new bonded windshields offer much more versatility .
  13. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    On my 2007 Gen II, the dots are raised and bumpy -- I cannot get a suction cup to stick on them. So I think they're painted and not sandwiched between glass.
  14. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    All auto windshields are laminated glass (2 sheets of glass with a layer of plastic--the laminate--fused in between), and have been for a long time (for safety reasons), but that has nothing to do with the dots on the 2010 Prius windshield, which are on the inside surface--you can feel them with your fingers. I imagine they're silk-screened on.
  15. KK6PD
    4,003
    944
    118
    Yeah, that was the other process I mentioned , Paint on surface, a silk screen process. That's why I mentioned I pefered the laminate way, no bumps to interefere wth suction devces!!!
    The new laminate method has black areas along with the clear to provide the desired masking effect, thus no bumps!
  16. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    The little dots are a Toyota-exclusive licorice version of the nostalgic
    candy dots:
    They can be removed by repeated licking...
    although saliva leftover is difficult to remove.
    :brick:
  17. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    My head keeps hitting the mirror. :confused: Do I need to remove it to lick the spots?
  18. stream
    2,977
    452
    Long Island, NY
    :roll:
    I loved those when I was a kid.
