How does accelerator read driver age?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Mar 31, 2010.
  1. bwilson4web
    16,204
    Ergonomics Roundup: Toyota, Apple and HP take on Ergonomics; Canine Ergonomics; Historical Input Designs; Laparoscopic Surgery
    Man, I've got to get one of those sensors that detects:
    • age
    • driver experience with vehicle
    • short people (Randy Newman: [ame="http://en.wikipedia.org/wiki/Short_People"]Randy Newman[/ame]?)
  2. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Just yet another magician's smoke screen by Toyota's PR "shills".
    Neither of the two more prominant SUA instances can be attributed to age. Age might result in short term confusion regarding which pedal to push, has been pushed, but not long term as in the case of CHP officer Saylor's ES350 nor Sike's 2008 Prius.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Wrong, Sikes is 60 years old, which puts him in the group of drivers with 6 times the rate of complaints as compared to 20-30 year-olds, as stated in the OP.
    Although I don't believe Sikes's case is a real SUA and a driver of any age could have pulled his hoax.
  4. qbee42
    3,079
    And Saylor was a floor mat issue.
  5. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Bob,
    The accellerator does not directly read driver's age. However, muscle strength, which decreases with age, can be directly sensed by the pedal being pushed. If the pedal is not pushed "briskly" (as one piece of Toyota documentation says), the system senses the presence of an older driver.
    The ECU then attempts to compensate for lack of muscle strength in pushing the pedal by supplying additional throttle opening.
    The problem is, this sometimes causes the older driver to lighten up further on the accelerator, which causes the ECU actually to overestimate the driver's age, and open the throttle further.
    This causes a feedback loop with the driver constantly lightening pressure on the accellerator and the ECU ordering wider throttle opening, leading to uncontrolled and unintended accelleration.
    Makes sense, don't you think?
    [Insert appropriate smiley/flame symbol here]
    3 people like this.
  6. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Sounds like something that should be posted tomorrow.
  7. kgall
    kgall Active Member
    984
    152
    Yeah, but why wait?
  8. qbee42
    3,079
    The age sensor is also tied into the turn signal. If you drive for 20 miles with the left turn signal flashing, the system assumes that you are a retired person. A Florida license plate makes this the default condition.
    Height is sensed by the mirror, headrest, and seat position.
    If both the height and age conditions are met, the ECU reverses the accelerator and brake just for fun, but only on the first Tuesday of each even month.
    6 people like this.
  9. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    I don't think it's a Toyota smoke sreen. The article is about a GM study.
  10. austingreen
    austingreen Senior Member
    13,672
    4,210
    Austin, TX, USA
    On aqua teen hunger force last night the tree court suggested cutting into the suspects trunk and count the rings to determine age. I think that may work. :) Reading the EDR seems to determine whether the brake was hit seems a lot more straight forward than adding the age and height sensors.
    The quoted GM study was done in the '80s. The author of the article works for exponent. Follow the money and connect the dots. Its a PR move to keep this story out there with the mantra audi. There is nothing wrong with that. Toyota is a big business and has a lot riding on making people feel safe in their cars. Ergonomics, badly designed pedals, incompetent dealerships, and driver error could be the reason for all the unintended accelerations. At the same time they need to really investigate these things unlike the past. It sounds like they are starting to do this.
  11. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    No kidding. The Saylor case was clearly the mats ( human dealer error ) and the Sikes case was clearly a hoax.
  12. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Funny, wwest40 thinks Michael Fumiento is a Toyota shill too. Toyota Hybrid Horror Hoax - Forbes.com
    Google monkey?
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Yeah Sven, and da runnerway Norvegian got busted also too.....
  14. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    The ECU reads your subcutaneous RFID chip to determine your age, sex, and height, as well as your medical history to determine if you are likely to have a seizure, heart attack, or go into a diabetic coma. It then goes through an FDA-approved algorithm to determine whether or not to allow you to start your car.
  15. bwilson4web
    16,204
    Ahhhh, another fan of "The President's Analyst."
  16. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Why not just ask the driver for the input? Make it part of starting up the car or putting it into "gear".
  17. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Oh, you didn't know about the other vision research Toyota's
    been doing? In addition to LKA and auto-park, now we've got a
    pinhole camera mounted at the bottom of the heater housing that
    detects varicose veins in the ankles, and adjusts accordingly.
    All part of "occupant classification", which is why it takes
    a whole separate ECU to handle that.
    _H*
  18. Politburo
    Politburo Active Member
    971
    208
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
