low fuel indicator light won't turn off
Discussion in 'Gen 2 Prius Audio and Electronics' started by nbinpt, Apr 1, 2010.
  1. nbinpt
    nbinpt New Member
    Olympic Peninsula
    I was in a hurry so I put in only $5 worth. The light kept blinking so later on in the day I put in $5 more. Didn't stop blinking. Then, I don't know why, I put in another $5 this evening. It's still blinking and not registering the amount of gas I put in.
    Help!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In my manual, it says that it may not register amounts less than 3 gallons, I am betting $5 won't buy 3 gallons.
    "When you refuel less than about 11.4 L (3.0 gal., 2.5 lmp.gal.), the fuel indicator may not change." Page 122 of the 2007 manual
    :welcome: I was raised in Montesano, at the bottom of the Peninsula.
  3. nbinpt
    nbinpt New Member
    Olympic Peninsula
    Yes, I read all that. But if you reread my message you'll see that I put in a TOTAL of $15 and it is still blinking.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Does not matter, you never put in more than 3 gallons at once. If you keep adding $5 at a time it can be spilling on the ground and still 'empty'. But if you ever put 4 gallons in it in a single event, all is well.
  5. Tideland Prius
    16,642
    What jimbo said. Adding $5 at a time won't do anything.
  6. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Here, 10 bucks isn't enough to make the blinking stop.
  7. lindy1401
    lindy1401 New Member
    I just recently had the same problem and it did that several times before it stayed on all the time. First time to the dealer...they said I had run it too low on fuel and it had messed up the code. A week later it started again...this time it was the cathylitic converter. $1800...on my 97,000 miles prius...with an extended warrenty that covered it all and even the rental car. Scared the poop out of me...but hopefully I will not have another 2k repair job for a while. Should be hitting that magic 100k this week.
