squiggly line icon coming on & brief odd sensation
Discussion in 'Gen 2 Prius Main Forum' started by toofnold, Apr 3, 2010.
  1. toofnold
    toofnold New Member
    Morganton, NC USA
    My wife is working seven hundred miles from home & just called with the following: On her 2007 Prius she's had the following occur two or three times. she's driving along foot lightly on the gas in D,C. traffic when the squiggly line icon comes on the dash display accompanied by a brief sensation of skidding/slipping. Her impression is that the whole concurrence is very small fraction of a second. got any idea's what to do with this ?
    Paul
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    That's usually just the traction control, but shouldn't be happening with steady speed driving. the VSC can show the same icon + VSC icon and 3 beeps. So, unless the roads are really wet/slick or it's happening when trying to accelerate on slippery terrain I don't know why she'd be seeing that.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Yes its probably like eFusco says but I would also have her check all the tires for proper air pressure too. One or all may be very low.
  4. Patrick Wong
    18,210
    6,514
    If road conditions are not obviously bad (standing water or snow) then I'd suggest looking at the tire tread depth. How many miles on the tires? Maybe the car needs a new set.
  5. qbee42
    3,081
    It sounds like it's doing exactly what it's supposed to do. When traction control is activated the little squiggly line icon is displayed.
    The real question is why is your wife's Prius losing traction? As mentioned above, tires are the first place to look, unless you know the road was broken or slippery.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    If the tires are the original Integrity tires, they are probably getting really bad by now. I could break the tires loose on dry pavement when I got about 30k on them.
  7. toofnold
    toofnold New Member
    Morganton, NC USA
    First, THANKS to everyone who responded. I've spent the last hour on Skype
    having her check tire pressure, tread condition, the side walls, etc. I had her
    check fluids, front end feel, etc. at the end of the conversation she commented
    on the deteriorating condition of the roads surfaces after the long hard winter.
    It seems the roads are falling apart, big chuck holes appearing, road surface
    coming away around previous repairs. in general the roads are going to hell &
    need many repairs..... I think that the general consensus that the car's systems
    are performing as designed are correct. We currently own two Toyota's & will own
    more as the need arises
    Thanks again
    Paul
  8. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    Yep, mine does that on bad roads also.
