Hill start assist is kinda cool
Discussion in 'Gen 3 Prius Main Forum' started by randallintacoma, Apr 4, 2010.
  1. qbee42
    3,079
    That would be a good definition, but it's not the one used by Toyota for the Gen II. They used a different approach, as described above.
    I liked the hill holder on my old Jeep C-J5. It was called a clutch; a great big clutch. :D
  2. Tideland Prius
    16,602
    lol... doesn't it burn out the clutch?
  3. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    Hill-Holder is not new. Studebaker invented it, and was first on the 1936 Studebaker President.
    Many manufacturers have had it, under various names.
    Toyota had it on some of their cars beginning in 1995. Tercel, Corolla and Camry had it, maybe others.
  4. qbee42
    3,079
    Yea, you really don't want to hold a car on a hill by slipping the clutch, but it does let you make the transition from brake to gas. The most common technique for hill starting with a manual transmission is to let out the clutch until it just starts to grab, then make a quick transition from the brake to the gas. As the gas goes in you come out on the clutch. You do it all quickly to avoid burning the clutch. It's probably the trickiest part of learning to drive a manual transmission.
    Some countries require drivers to learn a hill starting technique that uses the parking or emergency brake, but I've never heard anyone mention it in the U.S.
  5. randallintacoma
    randallintacoma New Member
    33
    Tacoma
    Curious, which Camry's had this feature. My 2003, 2007 or 2009 did not.
  6. Tideland Prius
    16,602
    Odd. I was taught that in my driving test and I was using an automatic!
    Good to know!
    I'm not aware of those Toyotas with HSA. Which years? (certainly wouldn't expect the bargain basement Toyotas to get it when they didn't even come with a radio! [except the Camry])
  7. Solscud007
    Solscud007 New Member
    59
    Nyack, NY
    I saw "hill start" mentioned in another thread and so i searched and found this. It is a nice feature. Im a MT driver for the past 10 years. small hiatus for a year or two when i wrecked my MT civic and drove a Previa AT)
    My dad taught me the handbrake trick to going up hill. One of the reasons I HATE the foot brake of the prius. Left foot on clutch, right foot on gas, left hand on steering wheel, right hand on handbrake and car is in 1st gear.
    Doesnt get any easier than that. I hate people who get lazy and let the clutch slip or roll back on inclines.
  8. qbee42
    3,079
    Yes. I've watched cars or trucks sit on a hill and slowly move up and drift back. You know the driver is riding the clutch like crazy. It's a wonder it doesn't burst into flames.
    We used to have a manual transmission Subaru that had a "hill-holder" clutch. When you pressed the brake with the clutch depressed, a one-way valve trapped the brake pressure and kept the brakes applied. This kept the car from rolling back when you transitioned from the brake pedal to the accelerator pedal. As you released the clutch, the brakes would automatically release just as the clutch started to bite. It was like your hand brake trick, but automatic. My wife liked it a lot.
  9. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    Oh, good grief...what else does this car do that I don't know about? I suppose this forces me back to reading the owner's manual (again). For me, it's like learing a new software. I can't just sit and read about it and expect to know it all. I just have to eventually play with it.
    This is why driving this car is so much fun!
    Happy Motoring,
  10. ETC(SS)
    7,312
    Kinda seems like the back-up camera to me. Yeah, I guess you need it with some vehicles...but a Prius???
    Hey, whatever.
    I'm glad everyone likes it... :D
  11. peterjmc
    917
    189
    Clarksburg, MD
    I used this for the first time yesterday. Pretty neat! I was so amazed using it for the first time I forgot to push the brake again to hold the car and almost rolled back into the car behind me.
    For those that plan on using it for the first time...
    You push firmly on the pedal to the floor and you will see the icon in your dashboard flicker and a beep to let you know it's active.
    Once active it only holds for approx 3 seconds. This will give you enough time to transition your foot from off the brake and onto the gas pedal. **This is not designed to hold your car parked on a hill. You should use your parking brake for that.
  12. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I've used it five times in 16k miles (just to test it). I imagine my wife has used it once or maybe zero times. To me it's a totally unnecessary feature, but I'm used to driving a manual and got good enough that even with traffic behind me on steep hills I never used the handbrake. In this car, or any auto for that matter, only the steepest of hills combined with a very slow break-to-gas will see the car rolling back much at all. Honestly, I would not pay $20 for this if it was an option, to be frank.
    Man oh man. I HATE when people do that riding the thing back and forth. Each time it's like they are screaming they have no idea how the clutch works, for surely if they realized what it does they would stop that nonsense right now.
  13. Mendel Leisk
    41,824
    Not sure, but I think that 3 seconds is from the time you release the foot brake. In other words, you can do the harder press of brake pedal to activate hill-hold, then sit there however long the light is red, keeping regular pressure on brake. Light goes green, you release the foot brake, and then you have 3 seconds leeway.
    Or did I just mis-read you?
  14. peterjmc
    917
    189
    Clarksburg, MD
    That's what I meant :) It stays active for three seconds after you release the brake pedal.
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Its really handy when you are parked in a tight space on a very steep hill and rolling less than a foot would mean your bumper hitting another car or a tow hitch.
  16. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    I guess this is useful if you don't have use of your left foot.
    Personally, I'd rather they spent the money elsewhere...like on more responsive ABS software.
  17. Tideland Prius
    16,602
    You can always use the left-foot-brake technique in lieu of the handbrake. I use that on the old Prius. After I come to a complete stop, I shuffle my right foot over a bit so that my left foot rests on the brake pedal. When the light turns green, I balance the right foot on the accelerator and left foot on the brake to get a smooth, no-roll-back start. It's like starting off in a manual transmission but the left foot is on the brake pedal instead of the clutch.
  18. s1njin
    s1njin New Member
    106
    Sellersville, PA
    Didn't know I had this feature. Tried it yesterday when I was stopped on a steep incline. Worked as described - felt pretty great about it b/c as stated I wasn't aware it existed. Bragged to my wife about it. Predictably got no love. :rockon:
  19. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I told my wife about this feature (she's the primary driver) and she informed me she'd already figured it out and it was "pretty cool" :)
    What do you mean by that? :noidea: It's a perfectly simple system that's perfectly simple to use (even if it's technically unnecessary imo). How would a driver not "experience it being done the right way" :confused:
  20. Skoorbmax
    2,641
    265
    Western NY
    Mine remains quite impressed with my ability to consistently get better MPG than her :p
