ABS / VSC / Warning lights all on permanently?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pleax, Mar 7, 2010.
  1. pleax
    pleax New Member
    UK
    Hi All.
    Hopefully someone can help me with this one, I don;t really want to go to the shop for fear of getting overcharged for computer replacement that doesn't need doing?
    I have a 2005 Prius and all was fine for first two months.
    Then we had a some snow and pulling off one morning to go to work, the "slippery road" light flashed up as the front wheels tried to get grip and went out of sync. - Not a problem normally as the car is designed to do this...
    The trouble was, all the other warning lights then came up and have been on ever since.
    So I now have ABS VSC and the two Exclamation warning lights on all the time and obviously have no functioning ABS / traction.
    I hoped this was just a logged fault on one of the computers and tried all the various ways shown on this Forum of getting rid of them. Battery off for 20 mins - no luck - connecting the terminals Tc and CG of DLC3 to go into diagnostics etc - no luck.
    Eventually I spent £170 on a V-Scanner that has Can Bus compatibility to be able to talk to the ABS/VSC computers.
    I was hoping to just clear the fault and be done.......
    The codes I got were and are -
    C1203 1/3
    Engine Control System Communication circuit Malfunction
    C1345 2/3
    Not Learning Linear Valve offset abnormality
    C1392 3/3
    Un-Correction of a zero point of the stroke sensor
    I can sometimes clear these faults (but mostly do not clear), but all this does is cause the lights to flash the next time I drive and then go solid again on the next drive.
    The only thing learned from this is when flashing (more like strobing one on at a time) the slippery road light comes on (even when on a straight road) and the engine has now power for about 10 seconds. (Again what the car is designed to do - but why is it doing it?)
    I assume from this, that something is telling the car that the wheel is spinning when it isn't causing (like the original fault) the lights to come on and log the fault.
    With this info and reading about this a lot on this forum, I looked at the ABS speed sensors on both front wheels.
    They both read 1500 ohms approx and show readings on an oscilloscope. (As well as logging separate faults on the V-scanner of ABS speed sensor disconnected) - so I conclude it's not these causing the fault?
    If anyone has any idea with this, it's appreciated.
    I'm looking at selling the Prius, as we're buying a house and need the money from it's sale asap.
    If I get no luck, I will be taking it to the shop but am nervous of getting charged $1800 plus for computer changes that are not required if I get a mechanic who doesn't know what he's doing :(
    Thanks for listening guys...... Hopefully someone has the missing piece of the jigsaw...
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'd pop it round to your friendly Toyota dealer and get them to run a diagnostic on it. Yes it'll cost you for their time and ask them not to do any work without refering to you. Maybe arange a price for the diagnostic before you commence with the work - that way everybody knows where they stand.
    Where abouts in the UK are you? I would recommend my Toyota dealer as they're very fair.
  3. Patrick Wong
    18,210
    6,511
    Unfortunately, this sounds like the skid control ECU needs to be replaced.
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Hopefully that would be a warranty item?
  5. Patrick Wong
    18,210
    6,511
    Well, in the US that would be covered under the 3 year / 36K mile warranty.
  6. pleax
    pleax New Member
    UK
    No warranty :( 110K Miles.
    I've got it booked in with Toyota on Wednesday, they managed to squeeze me in between all these recalls.
    £45 for running the diagnostics.
    Hopefully it's not the skid control ECU - why would a computer just fail? I can understand a sensor giving a funny reading, but can't see why a computer would just fail?
    Fingers crossed, I'll let you know, thanks for the responses anyway :)
  7. Patrick Wong
    18,210
    6,511
    1. A solder connection was marginal and finally came loose after repeated heating/cooling cycles as the unit is powered up and down, and your car sits out in the sun and then cools down each night.
    2. A component within the ECU failed: an electrolytic capacitor dried up, an integrated circuit died, who knows.
  8. pleax
    pleax New Member
    UK
    As I thought!! :)
    Rear ABS speed sensor according to Toyota.
    An extra fault came up at Toyota that didn;t come on my V-Scanner.
    C0215 - Rear Left ABS sensor
    All the above warnings also came out which proves that the V-scanner wasn't making it up, but not sure where to look in the menus for this other message otherwise it may have saved me a trip to Toyota - Though I must admit they were very professional.
    I've got a sesnor on order from the U.S as about 50% cheaper - delivered express by USPS.
    Now for the big question, has anyone changed a rear ABS speed sensor on a Prius?
    It looks like it goes in the centre of the hub.....
    Anyone know how to change one before I get started ripping it apart ?
    Cheers in advance!!
  9. Patrick Wong
    18,210
    6,511
    Thanks for the update. Looks like a special puller is needed to remove the sensor from the hub. Maybe your local machine shop can do this for you.
    If you don't have repair manual info you may want to download that at Toyota Service Information
  10. pleax
    pleax New Member
    UK
    Changed the Sensor - Exactly the same problem occurs :(
    Any one know how to change an ABS computer on one of these?
    Anyone know where it is ?
    Thanks.
  11. beam99
    beam99 Junior Member
    uk
    Before going replacing the ecu, you need to get it checked properly, the vehicle needs to be driven with the diagnoistic tester on the car and look at the data list to see which sensor is not working, it may just be a bad connection on a pin, or a faulty sensor, I put 2 new toyota O2 sensors in a pirus last week both faulty. the 3rd sensor done the job.
  12. Patrick Wong
    18,210
    6,511
    On the LHD models, that is located to the left of the steering column.
    You are supposed to perform various initializations after replacing the skid control ECU, so it probably would be a good idea to have your Toyota dealer do this.
  13. pleax
    pleax New Member
    UK
    Thanks for the info guys, I didn't think about getting them to do a drive diagnostics..
    I will get a quote for this and fingers crossed will get it sorted.
    I read somewhere else that it's possible to reset something on the skid ECU , so maybe it just needs resetting, or needs to re-learn something with the new sensor in ?
  14. atoeli
    atoeli New Member
    Anaheim, CA
    Hello, did you ever get this problem resolved? I have the same problem with my 2007 Prius. I have learned how to reset the code my using the jumper and pumping the brakes 8 times, but it doesn't reset all of the time and even if it does reset, the warning lights come back up randomly. HELP!!!:mad::mad:
  15. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Usually when those codes come on you can try a stroke sensor calibration via tech stream first to see if it resolves the problem. The procedure is in the service manual.
    SFO and andyprius like this.
  16. maqqad
    maqqad New Member
    usa
    Hi the ABS Computer is located under the steering column.
    I do have the same problem but i do have another 05 prius for part i will use it to fix the other one.
