inport form japan
Discussion in 'Generation 1 Prius Discussion' started by uddinsamsu, Apr 6, 2010.
  1. uddinsamsu
    uddinsamsu New Member
    castelbar ireland
    2003 Prius
    hi everyone i buy prius which 03 inport form japan , and who have in desbord on tv all japaness languge so pls any one let me know how to change that to english thx
  2. bwilson4web
    16,392
    We need the first five characters of the VIN to identify the specific model of Prius:
    • NHW10 - 1997-2000 Prius, Japanese only
    • NHW11 - 2001-2003 Prius, Japanese, North America, Europe
    • NHW20 - 2004-2009 Prius, same and more countries
    • ZVW30 - 2010-current Prius
    Thanks,
  3. uddinsamsu
    castelbar ireland
    2003 Prius
    hi thx for that, what u means by that? that thes number u means NHW11-0085251 if u can halp me on that
  4. bwilson4web
    16,392
    Good! This means it is an NHW11.
    Now there are two displays, one in the upper dash and the other a flat screen in the console. I suspect the one in the upper dash does not have a lot of Japanese and you can operate the car without a problem. Is the flat screen in the console the one that is giving you trouble?
    Now to answer your question, the language is built-in to the screen. I don't think anyone knows how to change the language once the car is sold. I suspect you will need to find the part from an English language version and have it swapped.
    It would be more useful if you could provide photos of the parts causing the language problem.
  5. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    Isn't toyotas made in japan has a vin number that starts with J.
  6. uddinsamsu
    castelbar ireland
    2003 Prius
    yes it is made in japan i think bec is inport form japan? and what number u means by j?
  7. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    The beggining letter of the VIN number starts with J if the car is from japan otherwise it is from assembly lines outside of japan. US assembly lines starts with a number (usually 5).
  8. Patrick Wong
    18,210
    6,514
  9. Kimoy
    Kimoy Member
    168
    24
    Chicagoland
    That's what I said. I'm just not getting on what bob Wilson is saying that we need the first five numbers of the vin number for identification
  10. Patrick Wong
    18,210
    6,514
    Yes, Bob might be referring to a chassis number stamped into the bulkhead, which is not the same as the VIN.
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Also the Prius imported into Ireland will be a RHD Prius from Japan.
    Many second hand cars are imported into Ireland and the UK from Japan. Apparantly Japan has a very strick test when the cars get to 10 years old and as such many are pretty much worthless in Japan when they get to that age. However, as they are RHD, certain models are still worth exporting to other RHD countries as personal imports. Whilst it isn't cost effective to import any old Jap car, it is worth importing certain high demand models (even old ones), such as the old generation Prius, Mitsubishi Shoguns/Pajero's, Lexus Soarers, Mazda Eunos Roadsters, Nissan Skylines etc.
    The legislation to import a second hand car from another country is fairly lax here in the UK and Ireland. I believe uddinsamsu is importing his Prius from Japan - hence the Japanese text on the Prius computer.
  12. uddinsamsu
    castelbar ireland
    2003 Prius
    hi that all number i can find Model- za-nhw11-aeeeb
    Engine- 1nz-fxe
    Frame no- nhw11-0085251
  13. uddinsamsu
    castelbar ireland
    2003 Prius
    Engine- 1nz-fxe
    Frame no- nhw11-0085251 that all i can get
  14. uddinsamsu
    castelbar ireland
    2003 Prius
    can any told me is that can change to english thx
  15. uddinsamsu
    castelbar ireland
    2003 Prius
    Engine- 1nz-fxe
    Frame no- nhw11-0085251 that all number i can get
  16. Patrick Wong
    18,210
    6,514
    Re: import from japan
    The good news is that you have an NHW11 model, which is much better than NHW10.
    The bad news is that it probably is not possible for you to change the multifunction display from displaying Japanese characters. You could try to purchase a replacement MFD from a salvage yard, from a car originally shipped to an English-speaking country.
    Maybe it will work in your car. Maybe it won't. No guarantees as there may be conflicts with other electronics in the car.
  17. uddinsamsu
    castelbar ireland
    2003 Prius
    thx, hey do u have any idea how long battery life for that car
  18. Patrick Wong
    18,210
    6,514
    My 2001's traction battery died after 61K miles and five years. However this is not representative.
    In general, I would say that if the battery is subjected to high ambient temperatures (90+ degrees F), that will reduce battery life. If the car is driven frequently over hills & valleys (thus subjecting the battery to wider charge/discharge swings) that will reduce battery life.
    The battery is known to suffer from electrolyte leakage from the individual modules. Thus, on average, I would expect the NHW11 battery to last for at least 8 years / 100K miles (which happens to be the battery warranty in the US.) Any service life beyond that is a bonus that you may, or may not, receive.
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Just to add to that... the leakage issue was resolved in NHW20 and ZVW30 uses the same modules as NHW20. Internal resistance was lowered as well. Gen2 and Gen3 packs should last longer.
  20. omarschaudhry
    omarschaudhry New Member
    Hi Bob,
    My car is Prius ZVW30, Model "L" , year 2010, Japanese Domestic Model.
    I like to change the language from Japanese to English for the Flat Screen in the console. Am attaching its picture as well.
    Please advise.
    Thanks.
    Omar
