have a prius 2005, the keyless unlock buttom does not work..?
Discussion in 'Gen 2 Prius Main Forum' started by surf_it69, Apr 8, 2010.
  1. surf_it69
    surf_it69 New Member
    MA
    does any one know how to fix the prius keyless unlock buttom?
    my second keyless key unlock buttom is stuck again. neither lock, unlock, and alarm buttom does not work now.
  2. XxDarkSidexX
    XxDarkSidexX New Member
    Orange County
    replace the battery, buy a bunch dont deal with this ever again
  3. richard schumacher
    7,666
    1,047
    United States
    When you press any button on the fob a small red light should flash in one corner (you do not have to be near the car to test this). If no red light, replace the battery.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    is the rubber sunk into the fob?
    you can pull the rubber out.. then gently place it back into the fob. it won't be as water proof once its done. it is fairly easy to do though.
    there is a lip on the rubber that catches the outer shell of the fob. i've done this a couple times with my spare fob (was my main fob)
  5. proaloth
    proaloth New Member
    I don't know what happened to yours. My prius just doesn't beep. Can anyone help me fix that. I dont have the smart key just the remote.
  6. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I don't think the non-SKS Prius beeps when locking or unlocking the doors.
