clueless driver spotted
Discussion in 'Local Clubs, Events, and Road Trips' started by hobbit, Apr 12, 2010.
  1. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I hope this wasn't one of the esteemed members of this forum out
    on 495 yesterday outside of Boston:
    Duh. If you want to go that F*-all fast, why not hop in the
    left lane instead of trying to push N other cars in the middle
    by tailgating them? Maybe if you got off that phone you'd be
    more aware of conditions around you...
    _H*
  2. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    It looks like the last three cars are pretty closely packed. You can barely see the roof of an SUV in front of the Crown Vic(?).
    It's impressive how many cars can fit into the middle lane and how few can fit into the right and left lanes.
  3. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    What were you doing when you took this picture?
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i know i'll get flagged for this.. but please get a hobby.
    a lot of prius drivers drive close to the cars in front of them. not all feel like competing in the next lane, as it requires more fuel to keep that speed.
    put your cam down.. or cellphone and drive...
    i would have figured, out of respect, that you would have edited out the license place as most members of this forum would have.
    yankkesrule, ErnestS and pa1555 like this.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I do not know, if there are no cars right in front of me I will not drive the left lane cause you stick out to the cops and in the right you have to keep dealing with the really slow people or the people getting on who refuse to give it gas when merging in...
    It does look kinda close but nothing I don't see every day around here... Doesn't make it right but nothing out of the ordinary.
  6. bisco
    52,390
    must've been drafting.:D or was ten car lengths back and people keep filling in.:rolleyes:
  7. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    That in Southern Cali is called daily driving...
  8. qbee42
    3,079
    Probably uncontrolled acceleration - just trying to use the car in front to keep the speed under control.
  9. hobbit
    4,089
    469
    Bahstahn
    What was *I* doing?
    Heading home after a short weekend roadtrip.
    Tooling along in the right-hand lane at around 60 - 65 MPH,
    maintaining a generous space ahead of myself and fending off
    occasional interlopers to the rear, leaving plenty of safe leeway
    to grab a one-handed shot through the windshield of a situation
    I found fairly laughable. Automatic-exposure cameras with image
    stabilization make this easy and safe, trust me on that. My G9
    has probably been instrumental in beneficial career changes of its
    own share of truck drivers, as it's a good way to collect a lot of
    information in one go for later review. And for "wall of shame"
    shots like this, the subjects generally don't deserve the courtesy
    of plate-blurring, which you'll note that I usually *do* in most
    of my other pictures. Let's remember that driving on the public
    roads is a public activity anyways, and you
    really have no expectation of any sort of privacy when you're
    engaged in what needs to be a *cooperative* activity.
    My, some pretty defensive reactions to this. Hmm, do we perhaps
    see a bit of ourselves in that other Prius driver's behavior?
    Think about it carefully: you ideally want three seconds of
    distance and freedom from any overtones of competitiveness, and
    you'll probably get where you're going *faster* and significantly
    more relaxed as a result of maintaining that.
    _H*
  10. deltron3030
    437
    64
    Lakewood, CA
    If I'm reading this correctly, you're saying " I was taking pictures of other cars while driving at 65....boy is that OTHER guy reckless".
    2 people like this.
  11. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    That Crown Vic, sure looks like it could be a unmarked Mass. State Police car.
  12. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Three seconds is nice, but not realistic in a lot of cases. If every driver had a three second gap on my drive into work today I can't even imagine how long the traffic jams would be on the freeways and surface streets near on ramps.
  13. Ophbalance
    Ophbalance Member
    205
    North Carolina
    Actually, the traffic flow would get BETTER, not worse, especially around merge sections. Instead of having to slow down to a near stop, traffic would actually merge.
  14. fuzzy1
    10,603
    Three second spacing caps the traffic flow to under 1200 cars per lane per hour. In areas commonly carrying 1800-2000 cars/lane/hour, this is a significant reduction in traffic flow capacity.
    But it is smoother and safer.
  15. Ophbalance
    Ophbalance Member
    205
    North Carolina
    My assumption would that higher speeds would be maintained by larger gaps. Therefore, the throughput should remain unchanged (if not better). But that's just my opinion, and it's doubtful there will ever by any way to test this as our general populace is far too dead set on the race for the space in front of them.
  16. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Hobbit should have put the pedal to the metal and passed the guy on the left and took a video of his face and put it on youtube. Can you say Paparazzi ?
  17. fuzzy1
    10,603
    This is easy to compute. In my world, there are only 3600 seconds in an hour, so 3 second gaps limit the throughput to under 1200 cars/hour, even if they are traveling at the speed of sound or the speed of light. This capacity is less than the commonly recorded flow rates where tailgating is normal.
    Do you live in a world with more seconds in each hour?
  18. CDeb
    CDeb New Member
    Sugar Land, TX
    You speak the language of a traffic engineer....
  19. Ophbalance
    Ophbalance Member
    205
    North Carolina
    As Adam would say, "I reject your reality, and substitute my own". I guess the point I'm trying to make is, does the 1800 v/hr actually happen? Or are the slowdowns due to merging problems and backups caused by smaller gaps drag that number down to a more realistic 1200 v/hr anyway? Microsimulation of road traffic, and with an 1800 v/hr causes major backups. 1200 v/hr does not.
  20. dr_d12
    dr_d12 Member
    154
    The middle lane is usually the calm, "sane", and safest lane here, even though it carries more traffic. Also, if you use a "3-second rule", someone will merge in to take the space and you'll constantly be slowing down to maintain a safe distance.
    Most of the time people in the left lane travel too fast so you can't really move over - you might be OK there for a while but then a huge black acura or BMW SUV races up at 30km/h over the speed limit and rides your nice person until you move over.
    If you take the right lane you have to match speed with merging traffic or move left at every major merging intersection. Soon, a huge black acura or BMW will race up at 30km/h over the speed limit, swerve into the center lane, then cut you off to continue speeding.
    Not to mention the semis and scary old ladies that can't seem to see over the dash. Ah, traffic.
