2010 prius and body stiffener
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cobradb, Apr 11, 2010.
  1. cobradb
    cobradb Member
    105
    tn
    has the 2010 prius been modified or changed in order that we dont need the under body stiffener?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. Superdrol
    Superdrol Member
    399
    32
    do they sell those modified mid plates to stiffen the chassis ?
    I already scuffed the plastic underneith in the front from a parking cement block. those are just protective plastic covers right ?
  4. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    The underbody cover panels are to reduce drag under the car by redirecting/guiding airflow. There are many chassis strengthening upgrades available for the 2010. The prius section at the sigma automotive site has a good selection of what's possible.
  5. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    My wife has a Gen II, so I drove both regularly. In comparison, the Gen III's steering feels more tighten down with less steering play. The Gen III handles more securely and doesn't understeer as quickly when corning. This could partially be due to tires, but when I had the stock 15s on mine (which were overinflated), the handling - feel and performance - is definitely an improvement (not sure how the Gen III compares with the Gen II Touring model though).
    Having said that, I am sure if suspension and chassis upgrades were more readily available, you would hear more about Gen III owners modifying their suspension. Deltron mentioned the Sigma Automotive site, and they do carry a large selection of parts. However, their prices are not cheap, and I'm sure there is a wait since these parts will need to be ordered from Japan. Tanabe has been fairly proactive in designing parts for the Gen III (ask Deltron, he knows all about it.. :)), and their prices are more affordable compared to Sigma.
  6. Superdrol
    Superdrol Member
    399
    32
    The 4 point brace underneith is worth considering later on. I'll keep it in mind.
  7. venom700
    venom700 Just call me Brian...
    196
    35
    Bethesda, MD
  8. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    I know - to each their own....but....
    this 'handling' type of mod. Is it REALLY worthy/needed. I can think of dozens of other cars that get really decent MPG and handle much better (stock) than our Prii. I'm quite happy with my '10 V. Handles really well "pushed to the limits", at least mine. When gauged by exit ramps and quick cornering. Just my .10
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Roy, the 2004 to 09 Prius had issues with crosswinds that the brace minimized. I am not hearing that kind of issue/fix is needed with the 2010.
  10. deltron3030
    437
    64
    Lakewood, CA
    I feel like any mod to the '10 prius is basically an enthusiast's pursuit, and by no means a necessity. there are very real positive's that come from these mods, but again, the "is it really worthy/needed" question is answered directly by the owner's willingness to spend money/time/resources on them, and not much more than that.
  11. HI MPG
    789
    133
    93
    Orange County, CA
    As one who has tweaked the suspension, I do agree that it is personal preference. The base Gen III Prius handles nicely when compared to the Gen II. Being an owner who came from the Lexus IS series, I just wanted something a little sportier, thus my preference to tweak the suspension and chassis. Any mods will be at the discretion and disposable income of the owner.
  12. Superdrol
    Superdrol Member
    399
    32
    Did you have to use a breaker bar or an impact wrench to take the bolts off ?
  13. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
  14. HI MPG
    789
    133
    93
    Orange County, CA
    I had the braces professionally installed, and they used impact wrench. However, Venom did personally install his center brace. I think he just used a socket wrench. The key is lifting the Prius to get sufficient space under the car since it's so low.
  15. venom700
    196
    35
    Bethesda, MD
    Yes you can do it by hand, well granted that the bolts aren't somehow rusty.
