EZPass Transponder
Discussion in 'Gen 3 Prius Main Forum' started by NEPrius1, Jul 24, 2009.
  1. NEPrius1
    NEPrius1 Junior Member
    Northeast
    I am new to the forum after having just purchased a 2010 Prius III. So far, I can honestly say it is the greatest car I have ever owned. I use EZPass daily and need to mount the transponder in my new Prius. I was thinking about mounting the transponder above the rearview mirror in the area of the windshield that has the black dots.
    My fear is that if I use the velcro strips that come with the EZpass transponder, upon removing the velcro strips at a latter date, it may damage the black dots on the inside of the windshield. Does anyone have experience with this and where have others mounted an EZpass transponder on a 2010 Prius?
    Thanks in advance.
  2. MaggieMay
    MaggieMay Active Member
    534
    68
    Gloucester, MA
    This should help: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/65508-ez-pass-placement.html
  3. NedRob
    NedRob New Member
    New Jersey
    Hey, if you are concerned about how your car looks with the EZ Pass transponder properly attached to the inside of your windshield, check out Logo Toll Tags (dot) com Some people don't like the looks of their EZ pass in their windshield, so they either wave it at the tollbooth or let it slide around on their dash. This can cause accidents as people search for their ez pass transponder and can cause the EZ Pass transponder to be read incorrectly or not at all. The EZ pass Holders from LogoTollTags have sports team logos on them from the MLB, NFL, NHL, some colleges and some NASCAR teams. I think they look better than just a blank white spot, but most importantly it is safer for you and the other drivers on the road to have the EZ Pass mounted properly.
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I mounted just below that area (I also have the strip of window tint across the top of my windshield) and the transponder is mostly blocked from my view by the rear-view mirror. Works out nicely!
  5. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    For a different approach I didn't mount mine at all - I keep it in the upper glove box, and I haven't had a problem with it being read yet.
    Depending on what roads you frequent be sure to look for discounts in the EZ Pass program for hybrid vehicles (GREEN pass) - the NY Thruway and PA bridges&tunnels have them, as does the Garden State Parkway/NJ Turnpike (off-peak discount only).
  6. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    I use my EZPass 2-3 times a day. I found this the most effective mount for me.
    Both glove boxes are lined with felt. That is why they are so dark.
  7. Joe166
    Joe166 New Member
    720
    97
    South Florida
    That's great, but what about when you don't want to use the pass. Do you have to leave it at home, sit on it, put it under the seat?
    Actually, our local turnpike authority gives away metallic envelopes that you can put your transponder in and it won't read it, even in that top box. Thank goodness because we get the high occupancy toll lane gratis with the hybrid.
  8. Judgeless
    1,821
    257
    Cleveland, OH
    If I am in the car I use it. I also have a Sun Pass that I only use in FL. That stays at home.
  9. brandonpa
    brandonpa New Member
    49
    Pennsylvania
    I mounted on the dots without problem. There since december and works fine.
  10. Jim05
    Jim05 Occasional Quasi-Hypermiler
    115
    Culpeper
  11. radiocycle
    radiocycle Active Member
    550
    78
    Vallejo, CA
    Well, we have a dash mat and the hook-and-loop material on the transponder sticks like glue to it, so there's no sliding around. We just keep the FasTrak in the glove box and set it on the dash mat, in the middle of the dash, whenever we're going up north where we cross all the bridges.
  12. drash
    drash Senior Member
    2,586
    1,329
    Upstate NY
    And of course I don't have to tell anybody who lives in NY to get a green E-ZPass for your Prius? It saves 10% off the regular E-ZPass rates.
  13. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    And being green colored, they look a lot better too (none of that pasty white stuff). Here's a pic of mine in a black plastic suction-cup mount holder:
    [IMGLINK]http://priuschat.com/forums/members/boo-albums-prius-picture816-green-ezpass-in-black-ezpass-holder.jpg[/IMGLINK]
    The Green EZ Pass can give you a greater discount on the NYS Thruway at all times, and on the NY-NJ Port Authority bridge and tunnel crossings during off-peak hours. But you have to make sure to specify that you want both the NYS Thruway and the NY-NJ Port Authority Green Passes, and both discounts will be programmed into your green colored EZ Pass transponder.
  14. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    The other thing you could do is swap your conventional tag for one of the exterior ones - it gets mounted just above the front licence plate using the same screws that hold the plate to the car - it is available for a few cars that have funky front windshields but when I got my ez-pass (New Hampshire) I got to choose.
  15. flbntz
    flbntz My First Toyota
    48
    Elizabethtown, PA
    Ditto.
  16. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    Colored mine black with a sharpie...took a while but worked out fine.
  17. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I'm in the process of doing a little research into this. It is
    worth keeping the thing shielded between tolling locations, as
    there are some other, uh, "uses" cropping up that want to read
    the transponder. According to the folks at Mark IV, who make
    the units, they are less sensitive along the bottom edge [as
    typically mounted in a vehicle] and thus that's the right place
    to handhold them if you're going to do that instead of mounting
    it. What's not yet known is how effective a small metal box
    to drop the unit into between uses is with regard to actually
    shielding it against trigger pulses, but now I've got a thread
    to post results into once that's determined.
    _H*
  18. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    Hey... that is really good information!! I had no idea that the EZ PASS would pick up by being in the upper glove box. I live in Belle Harbor in Rockaway and use the Marine Parkway Bridge daily. I have my pass mounted behind the RVM. I think I'll try and see if it works tomorrow.
  19. gbarry
    gbarry Junior Member
    79
    S. California
    Do you all get to stop and wave it around to see where it works? In California (FasTrak) you drive under the sensor without stopping. That's a heck of a way to "test" a theory. I'd love to be able to keep it in the glove box, but it's not like I get a second chance.
  20. Boo
    5,051
    488
    97
    Flushing, NY
    I have that same fear about keeping the transponder in the top glove compartment. I don't know if the transponder would be read at those tolls that you drive under at highway speeds.
