Firefox went temporarily insane
Discussion in 'Fred's House of Pancakes' started by daniel, Apr 28, 2010.
  1. daniel
    14,487
    1,518
    Spokane, WA
    I am using Firefox 3.6.3. A few minutes ago I was here on Prius Chat, with several tabs open to different threads, when suddenly, and without apparent input from me, all text in the open window turned to little empty rectangular letter-size boxes. I looked at the other tabs, and they were all the same. Images were okay, but the text was gone. A refresh made no difference.
    I quit and re-launched the program, and now all is well.
    Just thought I'd put that out, so if it happens to anyone else you'll know you're not the only one.
  2. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    2 people like this.
  3. Darwood
    Darwood Senior Member
    5,259
    268
    Stupid Firefox...
    My website displays perfect on IE, but the drop downs don't work on Firefox. I can fix it so it does, but then it makes it look goofy on IE.
    grrrrr....
    Most our clients are MS shops, so Firefox isn't nearly as important.
  4. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    I've had issues with Firefox on PCs (but not Macs) since an update (don't remember the number) last winter. Lost my auto pager add-on. Freezing. Noticeably slower to boot up than IE. Noticeably slower than before in all functions.
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    my drop downs work with firefox...
  6. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Sounds almost like a display driver issue, but if everything else works...
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    My only issue with Firefox, which I use at home, is that links often do not work.
    They just don't. I click, nothing happens.
    In IE, they work. Go figure.
    I'll stick with FF for most things, though.
  8. qbee42
    3,074
    I also find differences between Firefox on Windows and Firefox on Linux. Some sites will work with the Windows version but not the Linux version. So much for the idea of web browsers being compatible.
  9. TonyPSchaefer
    14,816
    2,497
    66
    Are you talking software or user? :p
  10. qbee42
    3,074
    Hmmm, you raise a good point.
  11. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    Might be AdBlock, sometimes it has the HAL persona take over ("I can't let you do that, Dave").:eek:
  12. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Firefox has its quirks. It likes to hoard cpu cycles. Yesterday, it was up to 90%, according to Task Manager -- when I could get TM to finally start. Nothing's perfect.
  13. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    As a consulting engineer, my advice is this:
    Heavy
    Drinking
    That will be $18,321.46 please
  14. TonyPSchaefer
    14,816
    2,497
    66
    I was going to pay you but I spent all my money on booze.
  15. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I tried heavy drinking a couple of times way back when, and it made me feel worse, not better. Any other suggestions? :D
    Oh, and as a pretence for keeping this on topic, Safari seems to work just fine.
  16. qbee42
    3,074
    The browser, or an exotic trip to Africa?
